Capture 3.1- Intermittent issue with Password censoring
Neel1
Hello - while using capture 3.1 i noticed that on some day- Password feed in target application are censored and some time it not. Snapshot can be find below.
this is also not an known issue with 3.1 version.
4945.png4946.pngsometime this
@Tom Chiles @Joe Farr - Any advice on this?​​
Neeraj Kumar
Technical Architect
Best Answers
joefarr
Hi Neeraj
Is Application Modeller spying enabled? It needs to be to obscure the password.
Alternatively, it may be due to how the element is coded. If it's not identifiable as a password field, then Capture will likely not be able to obscure the input. You can obscure it manually in the Step Action though:
Cheers
Joe Farr
Senior Product Specialist
Blue Prism Limited
joefarr
Hi Neeraj
Cheers
Joe Farr
Blue Prism Limited
Hello Joe - First option worked for me. I will monitor it now. thanks for your reply.
Neeraj Kumar
Technical Architect
