How to connect to Box Application
THANGHA
Hi everyone
I want to update or get files in Box, so i need connect to Box application.
I think can use VBO Box API from DX.
But, i don't know yet how to get the value of Client ID, Client Secret in Authenticate action.
Can you help me where i can refer?
Thanks & regards!
THANG HA
SE
FPT Software Japan
ewilson
Hello @THANGHA1,
Theres a note in the user guide regarding the process for obtaining credentials. See this link on Box's developer site:
https://developer.box.com/guides/applications/
Basically, you need to sign up for a developer account and then create an application registration.
Hello @ewilson,
Thank you so much for answer.
I don't have much experience with Box, but i'll try hard.
Sorry but I have one more question.
If i want login to Box Drive, i recognize that i can use VBO Box API ,is that correct?
Best regards!
THANG HA
SE
