Hi Gowtham Bopiah,
I have faced similar issue what @Micheal Charron mentioned in the conversation. It would be better to cross check where chrome is installed in each VM and make sure it is consistent and if necessary update APP modeller.
If that is not the option you are looking . As @Micheal Charron mentioned you might need read registry and determine the path
below is the link from digital exchange
https://digitalexchange.blueprism.com/dx/entry/9648/solution/utility---windows-registry
Harish Mogulluri
Lead developer
America/New_York TX
Original Message:
Sent: 08-17-2023 15:09
Subject: Site Launch Issue
Hii Harish
Vi is using blueprism 7 extension and its enabled , not sure how to check if it is pinned
Gowtham Bopaiah
Original Message:
Sent: 08-17-2023 14:06
Hi Gowtham Bopaiah,
Check whether Blue Prism extension is enabled and pinned in the browser
Below is BP extension compatability.
https://bpdocs.blueprism.com/en-us/browser-compatibility.htm?tocpath=Blue%20Prism%20products%7CBlue%20Prism%20Enterprise%7C_____2
Harish Mogulluri
Lead developer
America/New_York TX
Original Message:
Sent: 08-17-2023 13:20
Hii Harish , the problem is blueprism is unable to launch a site in chrome . using launch action ,iam using BP 7.0 , but while trying to launch in different machine the code works
Gowtham Bopaiah
Original Message:
Sent: 08-17-2023 13:07
HI Gowtham Bopiah,
Can you provide some more details, like screenshot might help
Also when you refer chrome in VI? are you referring chrome in Blue Prism 6?
Harish Mogulluri
Lead developer
America/New_York TX
Original Message:
Sent: 08-17-2023 07:57
Hii ALl,
In Bluprism through launch function while iam trying to launch a site in chrome in Vi(xxx) , its throwing SE(unable to launch ) but if i try the same, code same env and config in different VI(yyy or ZZ) ,its working fine no issue in other Vi , iam getting this issue only in xxx VI . Can u please provide any solutions or lead's on this
Thank you
Gowtham Bopaiah
