06-11-25 02:08 PM
Hi all,
I’m setting up Blue Prism Hub mainly because I need the Authentication Server to enable API access to our Blue Prism environment.
I’ve been looking through the install script (Install-hubv5.ps1) and the config files, but I’m still unsure about a few things:
Do I need to create the SQL databases myself?
Should I create empty databases for each Hub component before running the installer?
Or does the installer create the databases automatically?
Where do I put the database names?
There’s a DbName field under SQLServerConfiguration in the config file. Is that the name of the database the service uses?
I also saw an Optional → Databases section. Do I need to fill that in for each service?
If I want to install another service later, do I just run the installer again?
For example, if I install AuthServer now, and want to add Dashboard later, do I just update the config and re-run the script?
Will it only install the new service or will it try to reinstall everything?
I’m not very experienced with SQL Server, but I can create empty databases and logins myself if needed. Just want to be sure I’m doing this the right way.
Thanks!
