02-04-21 12:31 AM
using System;
using System.IO;
using System.Security.Cryptography;
using System.IdentityModel.Tokens.Jwt;
using Microsoft.IdentityModel.Tokens;
using System.Security.Claims;
namespace AaaSDocumentation
class SignToken
static void Main(string[] args)
try
// reading the content of a private key PEM file, PKCS8 encoded
string privateKeyPem = File.ReadAllText("...");
// keeping only the payload of the key
privateKeyPem = privateKeyPem.Replace("-----BEGIN PRIVATE KEY-----", "");
privateKeyPem = privateKeyPem.Replace("-----END PRIVATE KEY-----", "");
byte[] privateKeyRaw = Convert.FromBase64String(privateKeyPem);
// creating the RSA key
RSACryptoServiceProvider provider = new RSACryptoServiceProvider();
provider.ImportPkcs8PrivateKey(new ReadOnlySpan<byte>(privateKeyRaw), out _);
RsaSecurityKey rsaSecurityKey = new RsaSecurityKey(provider);
// Generating the token
var now = DateTime.UtcNow;
var claims = new[] {
new Claim(JwtRegisteredClaimNames.Sub, "YOUR_CLIENTID"),
new Claim(JwtRegisteredClaimNames.Jti, Guid.NewGuid().ToString())
var handler = new JwtSecurityTokenHandler();
var token = new JwtSecurityToken
"YOUR_CLIENTID",
"https://AAAS_PLATFORM/idp/YOUR_TENANT/authn/token",
claims,
now.AddMilliseconds(-30),
now.AddMinutes(60),
new SigningCredentials(rsaSecurityKey, SecurityAlgorithms.RsaSha256)
// handler.WriteToken(token) returns the token ready to send to AaaS !
Console.WriteLine( handler.WriteToken(token) );
catch (Exception e)
Console.WriteLine(e.ToString());
Console.WriteLine(
new System.Diagnostics.StackTrace().ToString()
}02-04-21 05:15 AM
03-04-21 09:53 PM
05-04-21 11:43 AM
The function you are trying to use is compatible with .net 5.0+ that is why you are getting the mentioned error.
05-04-21 01:53 PM
05-04-21 02:05 PM
Hi Sheela,
You can try the GitHub - jwt-dotnet/jwt: Jwt.Net, a JWT (JSON Web Token) implementation for .NET for creating a token.
17-05-21 06:55 AM
