Duration calculation logic for Ten days period
sandeshtope
I need to calculate the "Ten Days Duration" (TDD) codes for a given date, covering the current, previous, and next 10 TDDs. The TDD format is Year+TDD and follows this cycle from December 21 of each year to December 20 of the next year.
TDD Mapping:
Dec 1 – Dec 10, 2024 → 202435
Dec 11 – Dec 20, 2024 → 202436
Dec 21 – Dec 31, 2024 → 202401
Jan 1 – Jan 10, 2025 → 202502
Jan 11 – Jan 20, 2025 → 202503
Jan 21 – Jan 31, 2025 → 202503
Can anyone suggest something for automating this calculation ?
Nandhakumar
Hi @sandeshtope ,
Can you pls help me to understand the mapping further?
TDD Mapping:
Dec 21 – Dec 31, 2024 → 202401    - This shoud be 202501 right?
Jan 21 – Jan 31, 2025 → 202503    - This shoud be 202504 right?
also can you pls proide the mapping for couple of months to understand the mapping pattern
Hi @sandeshtope
As per the calculation you have mentioned, if we start from December 21 and end at December 20 then for leap year we will be left with 6 Days at the end, and for the non leap year it will be 5 Days at the end not 10 Days...
Just wanted to know how the calculation should be?
If we go by exact 10 days difference then date range will differ each year it will not remain constant as you mentioned from December 21 to December 20.
If possible please can you share more details as requested by @Nandhakumar
Sayeed Bin Abdullah
Senior Consultant - Automation Developer
Wonderbotz
