22-01-21 03:53 PM
Hi ,
need to go visible cell in a column in Excel after applying filters.
Ex: Age column filtered >25 then i need to go first visible value after filter.
KMMPost
Murali Mohan Konanki Automation Associate
S&P Global
UTC
8096961984
KMMPost
S&P Global
UTC
8096961984
22-01-21 04:52 PM
I don't think there's a way to do this with the stock VBO. I'd check this post for an example of how to do it in VBA, which could be adapted to a code stage in Blue Prism.
Nicholas Zejdlik
Range("A1").CurrentRegion.SpecialCells(xlCellTypeVisible)
will return a range of visible cells, then you can use the Intersect()
function to determine if a specific cell or range is contained within the range of visible cells. Since this method would not require moving the active cell around, it should be pretty quick to loop through potentially thousands of cells to see if they are visible or not.------------------------------
Nicholas Zejdlik
5 REPLIES 5
22-01-21 04:52 PM
Nicholas Zejdlik
Nicholas Zejdlik
23-01-21 05:10 AM
Thanks Nicholas. It helps i will check.
S&P Global
UTC
8096961984
S&P Global
UTC
8096961984
25-01-21 09:02 AM
Hi Murali,
Just in case that doesn't work out. An alternative method would be to create a Windows based object to attach to Excel, then use GSK to press the down arrow (once you've selected the header row).
Not as elegant as using VBO, but may give you simpler alternative.
Ben Lyons
Product Consultant
UK
Ben Lyons
Product Consultant
UK
Ben Lyons
SS&C Blue Prism
UK based
SS&C Blue Prism
UK based
25-01-21 08:34 PM
Hi, Murali,
I am attaching an action from our Excel VBO (Filter Worksheet & Get Filtered Row Numbers) which enables to set up a filter criteria (using Collection) and then returns collection with row numbers which met the filter criteria. Hopefully, it will help you. If you need more explanation send PM.
Zdeněk Kabátek
Head of Professional Services
NEOOPS
http://www.neoops.com/
Europe/Prague
Zdeněk Kabátek
NEOOPS
Europe/Prague
08-03-21 04:42 PM
Thank you Zdeněk Kabátek.
S&P Global
UTC
8096961984
S&P Global
UTC
8096961984
