How to call page dynamically
16-01-18 05:05 PM
Is there any way I can dynamically call a page in BluePrism. For example suppose I need the Page component to call the page whose name is stored in a variable.(Those who might be familiar with UiPath may be aware that there we can specify the workflow name as a variable inside invoke workflow component)
16-01-18 08:21 PM
No you can't do that in BP.
19-01-18 12:22 AM
You can do it with a choice. If the value of the variable changes dynamically, you can evaluate with a Choice stage and continue the process with that page.
22-01-18 01:21 PM
Thanks John and Melissa.
The solution wont solve my problem cuz I need to call the pages using a loop and the name and no of pages are only known at run time.
22-01-18 02:22 PM
However the value inside that variable will be assigned based on some conditions only so in BP rather than having a variable to get value based on some condition and using that variable to invoke the process page , you can directly call the page instead when that condition satisfy .
I guess If you had a variable to store page name and invoke that on run time the benefit only would be that you can do the work with only one page stage ,Isn’t it correct ?
