Hi Supratim,
Can you check if all the excel actions that you are using belongs to the same Excel VBO or not once. I would suggest use all the actions from the same 'Excel - Extended' VBO. If you use different actions from different business objects to interact with Excel, you are most likely to face this error that you are currently getting.
Website:
https://devneet.github.io/Email:
[email protected]----------------------------------
