SAP GUI automation does not work as expected after migration from v6.6 to v7.0.1
27-06-22 11:46 AM
Recently we have upgraded our environment with Blue Prism version to 7.0.1 from 6.6.
One of the existing process, which involves SAP automation runs very smoothly in Blue Prism version 6.6 and the same code with exact same SAP settings does not work with Blue Prism version 7.0.1.
I have followed the steps mentioned in this article : https://portal.blueprism.com/system/files/documents/User%20Guide%20-%20SAP%20Integration.pdf
Existing application module elements are not matching and I can not spy elements newly because none of the spy modes are recognizing the required fields.
Error screenshots FYR:
Please guide me with your valuable suggestion to over come this issue which is a high priority task
Thanks in advance
Vasant
27-06-22 11:00 PM
Hi Vasant
If none of the spy modes appear to working with SAP it could be that sap scripting is turned off in SAP. If you look at the options and check if scripting is on and if not you would need to enable it to identify sap elements.
29-06-22 04:36 AM
Hi Vasant
Further to Michaels's reply, if you check in SAP as shown, if greyed out, then scripting is not enabled in SAP.
