04-06-22 04:39 AM
06-06-22 09:35 AM
SELECT processname,CONVERT(DECIMAL(7,2),Sum(
IsNull(DataLength(sessionnumber), 1)
+ IsNull(DataLength(stageid), 1)
+ IsNull(DataLength(stagename), 1)
+ IsNull(DataLength(stagetype), 1)
+ IsNull(DataLength(processname), 1)
+ IsNull(DataLength(pagename), 1)
+ IsNull(DataLength(objectname), 1)
+ IsNull(DataLength(actionname), 1)
+ IsNull(DataLength(result), 1)
+ IsNull(DataLength(resulttype), 1)
+ IsNull(DataLength(startdatetime), 1)
+ IsNull(DataLength(enddatetime), 1)
+ IsNull(DataLength(attributexml), 1)
+ IsNull(DataLength(automateworkingset), 1)
+ IsNull(DataLength(targetappname), 1)
+ IsNull(DataLength(targetappworkingset), 1)
)/1073741824) AS session_log_size
From
BPASessionLog_NonUnicode
GROUP BY
processname
ORDER BY session_log_size DESC
04-06-22 08:07 AM
SELECT A.processname,COUNT(A.logid) AS log_entries
FROM [Blue Prism].[dbo].[BPASessionLog_NonUnicode] A INNER JOIN [Blue Prism].[dbo].[BPAProcess] B
ON A.processname = B.name
GROUP BY A.processname
ORDER BY COUNT(A.logid) DESC
04-06-22 08:15 AM
SELECT A.processname,COUNT(A.logid) AS log_entriesFROM [Blue Prism].[dbo].[BPASessionLog_NonUnicode] A INNER JOIN [Blue Prism].[dbo].[BPAProcess] B ON A.processname = B.nameGROUP BY A.processnameORDER BY COUNT(A.logid) DESC
04-06-22 08:51 AM
SELECT processname,
Sum(
) session_log_size
From
GROUP BY
processname
04-06-22 09:05 AM
SELECT processname,Sum(IsNull(DataLength(sessionnumber), 1)+ IsNull(DataLength(stageid), 1)+ IsNull(DataLength(stagename), 1)+ IsNull(DataLength(stagetype), 1)+ IsNull(DataLength(processname), 1)+ IsNull(DataLength(pagename), 1)+ IsNull(DataLength(objectname), 1)+ IsNull(DataLength(actionname), 1)+ IsNull(DataLength(result), 1)+ IsNull(DataLength(resulttype), 1)+ IsNull(DataLength(startdatetime), 1)+ IsNull(DataLength(enddatetime), 1)+ IsNull(DataLength(attributexml), 1)+ IsNull(DataLength(automateworkingset), 1)+ IsNull(DataLength(targetappname), 1)+ IsNull(DataLength(targetappworkingset), 1)) session_log_sizeFromBPASessionLog_NonUnicodeGROUP BYprocessnameORDER BY session_log_size DESC
06-06-22 09:12 AM
06-06-22 09:35 AM
From
GROUP BY
processname
06-06-22 09:49 AM
06-06-22 10:04 AM
SELECT processname,CONVERT(DECIMAL(38,2),Sum(
CONVERT(DECIMAL(38,2), IsNull(DataLength(sessionnumber), 1))
+ CONVERT(DECIMAL(38,2), IsNull(DataLength(stageid), 1))
+ CONVERT(DECIMAL(38,2), IsNull(DataLength(stagename), 1))
+ CONVERT(DECIMAL(38,2), IsNull(DataLength(stagetype), 1))
+ CONVERT(DECIMAL(38,2), IsNull(DataLength(processname), 1))
+ CONVERT(DECIMAL(38,2), IsNull(DataLength(pagename), 1))
+ CONVERT(DECIMAL(38,2), IsNull(DataLength(objectname), 1))
+ CONVERT(DECIMAL(38,2), IsNull(DataLength(actionname), 1))
+ CONVERT(DECIMAL(38,2), IsNull(DataLength(result), 1))
+ CONVERT(DECIMAL(38,2), IsNull(DataLength(resulttype), 1))
+ CONVERT(DECIMAL(38,2), IsNull(DataLength(startdatetime), 1))
+ CONVERT(DECIMAL(38,2), IsNull(DataLength(enddatetime), 1))
+ CONVERT(DECIMAL(38,2), IsNull(DataLength(attributexml), 1))
+ CONVERT(DECIMAL(38,2), IsNull(DataLength(automateworkingset), 1))
+ CONVERT(DECIMAL(38,2), IsNull(DataLength(targetappname), 1))
+ CONVERT(DECIMAL(38,2), IsNull(DataLength(targetappworkingset), 1))
From
GROUP BY
processname
NOTE: If you have very small values even 2 decimal precision will show you 0.00 and won't suffice in that case try with some parameter like (38,12). You need to experiment here and see what fits your use case according to your data
SELECT processname,CONVERT(DECIMAL(38,12),Sum(
CONVERT(DECIMAL(38,12), IsNull(DataLength(sessionnumber), 1))
+ CONVERT(DECIMAL(38,12), IsNull(DataLength(stageid), 1))
+ CONVERT(DECIMAL(38,12), IsNull(DataLength(stagename), 1))
+ CONVERT(DECIMAL(38,12), IsNull(DataLength(stagetype), 1))
+ CONVERT(DECIMAL(38,12), IsNull(DataLength(processname), 1))
+ CONVERT(DECIMAL(38,12), IsNull(DataLength(pagename), 1))
+ CONVERT(DECIMAL(38,12), IsNull(DataLength(objectname), 1))
+ CONVERT(DECIMAL(38,12), IsNull(DataLength(actionname), 1))
+ CONVERT(DECIMAL(38,12), IsNull(DataLength(result), 1))
+ CONVERT(DECIMAL(38,12), IsNull(DataLength(resulttype), 1))
+ CONVERT(DECIMAL(38,12), IsNull(DataLength(startdatetime), 1))
+ CONVERT(DECIMAL(38,12), IsNull(DataLength(enddatetime), 1))
+ CONVERT(DECIMAL(38,12), IsNull(DataLength(attributexml), 1))
+ CONVERT(DECIMAL(38,12), IsNull(DataLength(automateworkingset), 1))
+ CONVERT(DECIMAL(38,12), IsNull(DataLength(targetappname), 1))
+ CONVERT(DECIMAL(38,12), IsNull(DataLength(targetappworkingset), 1))
From
GROUP BY
processname
06-06-22 07:29 PM
SELECT processname,CONVERT(DECIMAL(38,2),Sum(CONVERT(DECIMAL(38,2), IsNull(DataLength(sessionnumber), 1))+ CONVERT(DECIMAL(38,2), IsNull(DataLength(stageid), 1))+ CONVERT(DECIMAL(38,2), IsNull(DataLength(stagename), 1))+ CONVERT(DECIMAL(38,2), IsNull(DataLength(stagetype), 1))+ CONVERT(DECIMAL(38,2), IsNull(DataLength(processname), 1))+ CONVERT(DECIMAL(38,2), IsNull(DataLength(pagename), 1))+ CONVERT(DECIMAL(38,2), IsNull(DataLength(objectname), 1))+ CONVERT(DECIMAL(38,2), IsNull(DataLength(actionname), 1))+ CONVERT(DECIMAL(38,2), IsNull(DataLength(result), 1))+ CONVERT(DECIMAL(38,2), IsNull(DataLength(resulttype), 1))+ CONVERT(DECIMAL(38,2), IsNull(DataLength(startdatetime), 1))+ CONVERT(DECIMAL(38,2), IsNull(DataLength(enddatetime), 1))+ CONVERT(DECIMAL(38,2), IsNull(DataLength(attributexml), 1))+ CONVERT(DECIMAL(38,2), IsNull(DataLength(automateworkingset), 1))+ CONVERT(DECIMAL(38,2), IsNull(DataLength(targetappname), 1))+ CONVERT(DECIMAL(38,2), IsNull(DataLength(targetappworkingset), 1)))/1073741824) AS session_log_sizeFromBPASessionLog_NonUnicodeGROUP BYprocessnameORDER BY session_log_size DESC
SELECT processname,CONVERT(DECIMAL(38,12),Sum(CONVERT(DECIMAL(38,12), IsNull(DataLength(sessionnumber), 1))+ CONVERT(DECIMAL(38,12), IsNull(DataLength(stageid), 1))+ CONVERT(DECIMAL(38,12), IsNull(DataLength(stagename), 1))+ CONVERT(DECIMAL(38,12), IsNull(DataLength(stagetype), 1))+ CONVERT(DECIMAL(38,12), IsNull(DataLength(processname), 1))+ CONVERT(DECIMAL(38,12), IsNull(DataLength(pagename), 1))+ CONVERT(DECIMAL(38,12), IsNull(DataLength(objectname), 1))+ CONVERT(DECIMAL(38,12), IsNull(DataLength(actionname), 1))+ CONVERT(DECIMAL(38,12), IsNull(DataLength(result), 1))+ CONVERT(DECIMAL(38,12), IsNull(DataLength(resulttype), 1))+ CONVERT(DECIMAL(38,12), IsNull(DataLength(startdatetime), 1))+ CONVERT(DECIMAL(38,12), IsNull(DataLength(enddatetime), 1))+ CONVERT(DECIMAL(38,12), IsNull(DataLength(attributexml), 1))+ CONVERT(DECIMAL(38,12), IsNull(DataLength(automateworkingset), 1))+ CONVERT(DECIMAL(38,12), IsNull(DataLength(targetappname), 1))+ CONVERT(DECIMAL(38,12), IsNull(DataLength(targetappworkingset), 1)))/1073741824) AS session_log_sizeFromBPASessionLog_NonUnicodeGROUP BYprocessnameORDER BY session_log_size DESC
