Status: New
Hi Team it's very difficult to resize choice stage when there are more than 10 conditions. Once we make any changes then it's again resizing or rearranging th branches of choice stage. It's a pain to resize everything. Blue prism should remember the previous saves or there should be an option to remember or not.
PFA for the same
7 Comments
AndrewPascal
Agreed. It's crazy that BP rearranges your diagram every time you edit the choice stage!
MalakDudhia1
Yeah, Blue Prism team should work on it. One of most headache issues.
This idea is a perfect example of why the minimum count of likes on any idea should not be the condition to evaluate.
Hi @Amy Tsaousi Could you please have a look into this. It's very much required​
SivaMaddula
I agree, Blue Prism team should work on it.
Hi Team do we have an update on this issue? It has been there from a long time if we can fix it in the upcoming version that would greatly help the developers, please.
david.l.morris
Level 15
I don't use Choice stages for this very reason.
