FabianBluePrism
Status: Delivered
It would be a great enhancement if we could have the ability to select the number of aborts we can release by data selection or amount. Right now you can only select all or one at the time and when we have some type of error that result in a lot of aborts it can cause the system to slow down.
3 Comments
Karen_Hunter
The current interface groups by Process | Version | Step | Business Area | Work type and then displays Status | Queue | Work Object Id | Error.
This request includes the ability to filter the aborted item by Work Object Id date range so that you can easily select that population.
Another candidate filter might be to find all items with the same error message.
I am interested in feedback on other ways you might need to search | sort | filter this population to be able to more easily select like items that need to be resumed in the same action.
Karen_Hunter
Process Monitor Improvements are in scope for the 24.1 release.  One new filter under consideration for aborted items includes the ability to identify the objects with "like errors" in the selected step.  Please contact your Account Representative and mention this enhancement request if you are interested in providing early customer feedback on the proposed design and priority of new/changed functionality.
Status changed to: Delivered
Karen_Hunter
Please evaluate new Management Console Process  Monitor and Unlocker enhanced functionality.
