Piotr__Wieczerzak
- Mark as Read
- Printer Friendly Page
12-04-23
10:32 AM
Status:
Reviewed
I have few business cases when I think will be good to improve scheduler process.
1st Case
Bot should work every 5 minutes, but only during first 5 days in the month, every month. Business days are calculated based on USA calendar. Bot is now in deployment process and first run will be in May.
1st Case
2, Case - main rule is that bot should work every 1h during first 5 Business days every month, but there are some months that should work few additional dates (Jan, Apr, Jul, Oct). this is done manually , but based on Polish calendar
3rd case - again every 5 minutes within below days. USA Calendar Every month bot has two periods of work (5 days , then break , and next 4-6 days).
January- 11, 12, 13, 16, 17, 20, 23, 24, 25
February- 10, 13, 14, 15, 16, 21, 22, 23, 24, 27, 28
March- 10, 13, 14, 15, 16, 21, 22, 23, 24, 27, 28
April- 12, 13, 14, 17, 18, 20, 21, 24, 25, 26
May- 10, 11, 12, 15, 16, 22, 23, 24, 25, 26
June- 12, 13, 14, 15, 16, 21, 22, 23, 26, 27
July- 12, 13, 14, 17, 18, 20, 21, 24, 25, 26
August- 10, 11, 14, 15, 16, 22, 23, 24, 25, 28
September- 12, 13, 14, 15, 18, 20, 21, 22, 25, 26
October- 12, 13, 16, 17, 23, 24, 25, 26
November-13, 14, 15, 16, 22, 23, 24, 27, 28
December- 12, 13, 14, 15, 18, 20, 21, 22, 25, 26, 27
Also, would be good to manage some exceptions, that normally bot will be working first 5 BDs, but in some months more days.
After adding periods, would be good to have simulation of calendar - based on created rules (first 5BDs), country calendar (USA), press one button and will display in which days bot will be working, or will not be working,
Now I can only create on monthly schedule that bot can work ex First BD day, but just one time? Or I have create own calendar and have to exclude as holiday over 200 days.
The only option which I am aware is to create dedicated calendar for this bot (with holiday of all not green marked days) and then schedule it every few 5 minutes/1 hours. Every year in November I am receiving expected calendars for next year. And then I am going to calendar, and adding a lot of holidays, day by date. Example of my calendar:
This is very time consuming and manual work.
Do you think about possibility to add to monthly scheduler - that bot can run within first 5 BD every 5 minutes/1 hours? or maybe via periods - first period 1-5 BDs, next period 9-12 BDs, and also every 5minutes/1hour. Also, would be good to manage some exceptions, that normally bot will be working first 5 BDs, but in some months more days.
2 Comments
