Hi
@SamLima,
When you set the '
Retry' flag as True then only the items whenever they are marked as exception will generate a new cloned item in 'Pending' state having the 'Attempt' value incremented along it.
So essentially with that being said, if you set the '
Attempts' more than 1 in the queue setting but let say you forget to set the Retry flag as
True in your workflow while using the '
Mark Exception' action, then the queue setting for the attempt won't be considered and basically item would just be marked as exception and no new item acting as it's clone would be generated automatically in the queue.
This flag in a way decides if the retry logic as a whole needs to be followed or not. If yes, then it will check from the queue settings how many times do I need to retry in such a case and if no then the item won't be retried at all no matter how many attempts we configure in the queue settings.
Also, to answer our second question, if you set the Attempts field as blank and you set the '
Retry' flag as True then even in that case retry logic would not work since it will be considered that '
Attempts' value is 0 and we need to do a retry attempt at all so the item would be just marked as exception and the flow would proceed ahead.
Website:
https://devneet.github.io/Email:
[email protected]----------------------------------
