Error while spying: "No window found for process with PID: xxxx"
CarolinaSoeiro
Good morning everybody,
I'm trying to use UI Automation to spy the search bar (or adress bar), however it throws me a strange error. No window found for process with PID: (and a bunch of numbers)
Can someone explain why this error throws?
Carolina Soeiro
5 REPLIES 5
ewilson
Hi @Carolina Soeiro,
Which browser are you trying to spy? Have you installed the Blue Prism extension for that browser? What version of Blue Prism are you using?
Hi @ewilson
I'm experiencing this same problem. In UI Navigation Mode I had successfully spied some elements on a webpage and when I run the process today I get this same error message and code. As far as I know, there was no update to the webpage itself.
​I'm using Blue Prism 6.5.1 and Chrome 106.0.5249.119.
I am currently refactoring some code and breaking up the object into smaller ones - I'm not sure if attaching has something to do with it? I had to change the title page because the object wasn't attaching (sorry if this is a red herring, I couldn't even find what a PID error is).
Gracie Devine
@ewilson
Never mind, I changed the title of the page to be a wildcard in application modeller and that seems to have solved both the attach and PID issues. Just for my own edification though... what's a PID?​
Gracie Devine
Hi @GracieDevine1,
PID = Process ID or Process Identifier​. Basically every process running on windows has an identifier associated with that the operating systems uses to keep track of things.
Hi Gracie,
Here's more about the PID:
https://learn.microsoft.com/en-us/windows-hardware/drivers/debugger/finding-the-process-id
Happy coding!
Paul
Sweden
Happy coding!
Paul, Sweden
