Filter Collection Criteria for Colored Excel Rows
daultani
I am trying to filter my excel with only non colored rows(Basically rows except Red color)  with below Criteria:
Seems like this is not working.
Can anyone suggest the criteria what should I use to get only non colored rows?
Thanks in advance.
Bhawana Daultani
10 REPLIES 10
EmersonF
Hi @BhawanaDaultani I believe that the criterion will be "RGB" look like this
Criteria1:=RGB(255,0,0)
Emerson Ferreira
Cons, Intelligent automation
Avanade Brasil
Recife
+5581988869544
Sr Cons at Avanade Brazil
@EmersonF, Thanks for your reply.
I tried above option too but still no result found.
I just have to write RGB(255,0,0) in Criteria field Value? or am I missing something?
Bhawana Daultani
Hi @BhawanaDaultani, maybe you has not put the input "Operator", to RGB filter method (enumerator excel xlFilterCellColor) is the number 8.
So:
Criteria:= RGB(255,0,0)
Operator:= 8​​
Leonardo Hermínio
Hey @BhawanaDaultani the solution of @LeonardoHermín1 work to me!​​​
Emerson Ferreira
Avanade Brasil
Recife
+5581988869544
Hi @LeonardoHermín1,
Unfortunately I am getting below error:
"AutoFilter method of Range class failed"
Bhawana Daultani
Please, can you show the code in the code stage 'Filter'?
Leonardo Hermínio
Input as
@LeonardoHermín1- Let me know in case you need more information.
Bhawana Daultani
Hi Bhawana,
Did you get how to pass colour Code criteria Dynamically?
I am also facing the same issue I am not able to send colour code dynamically as of now If I am hardcoding RGB(255,255,0) is working fine.
@EmersonF, please help me if you know how to pass dynamic colour code.
Amlan Sahoo
Senior RPA Consultant
WonderBotz
Amlan Sahoo
Hi @_Amlansahoo
You can follow the following approach by extending the MS Excel VBO business object with a separate action built using the below workflow:
The code stage will look something like below:
Dim ws As Object
ws = GetWorksheet(Handle, Workbook, Worksheet)
ws.Activate()
ws.Range("A1").AutoFilter(Field:= Field, Criteria1:= RGB(R,G,B), Operator:=8)
If you want, you can make range dynamic as well. However, my example I am assuming the table begins from the cell "A1". Now, when I use this action, you can see I am able to dynamically pass the RGB values (23,23,23) and it filters accordingly:
WonderBotz India Pvt. Ltd.
