Global Send Key to Bring MS Edge Foreground
Lily.L
Hi guys,
I run the bot in the control room. After launching Ms Edge, the window is hiding.
I have tried many ways to bring the window foreground but have been UNsuccessful.
I try Global Send Key ALT + TAB to switch between the control room window and Ms Edge.
However, the Ms Edge is not always pop-up. Even, when the Ms Edge pops up, the window is closed immediately. I have used the retry stage to re-launch, but it's happened again: pop-up then closes immediately.
Can someone please suggest ideas to bring Ms Edge foreground or what else I can do with Global Send Key ALT TAB?- Thank you!
Here's the screenshot
Mia Mikela
7 REPLIES 7
Try Minimise then Restore (or Maximise)
John Carter
GastonSalguero
Hi!
Try map the Window (Full) with Win32 and then in a Navigate Stage, call an "Activate Application" to that element.
Let me know if this works.
Gaston Salguero
Hi, I have tried to minimize & maximise, to spy full window and have activated the application, etc... However, those steps are not working.
Mia Mikela
Mia Mikela
Mia Mikela
harish.m
Level 12
Hi Mia Mikela,
Try below code  in c#
https://stackoverflow.com/questions/11512373/findwindow-and-setforegroundwindow-alternatives
29929.pngI would do some thing like this
in the global code:
[DllImport("user32.dll")]
private static extern bool SetForegroundWindow(IntPtr hWnd);
 In the code stage:
Processname here you need to pass as input parameter as 'msedge'
Process[] p = Process.GetProcessesByName(processName);
foreach(Process p1 in p){
IntPtr wh = p1.MainWindowHandle;
SetForegroundWindow(wh);
Namespace imports:
1) System.Runtime.InteropServices
2) System.Diagnostics
Harish Mogulluri
Lead developer
America/New_York TX
Hi Harish, thanks for your suggestions. However, I dont know C++ and I'm not allowed to change C++...
Mia Mikela
