How to automate release management using azure devops
AshishSoni
Hello All,
I want some guidance on how we can achieve the release management automation using azure devops?
Please feel free to help.
Ashish Soni
ewilson
Hi @Ashish Soni
Check out the following on the Digital Exchange. It's not specific to Azure DevOps, but it may give you some pointers that will help you to design a solution.
https://digitalexchange.blueprism.com/dx/entry/3439/solution/blueprism-autodeployment-guide-for-devops
