ML Capture model- Decipher 2.1
KrishnaElapavul
HI ,
When I accessed Capture Model from Admin panel , I am not able to see value in new documents  available to start ML training .
this is not appearing even for new and already trained models.
Can you please help is any thin missing and how to verify
Krishna Elapavuluri RPA Solution Lead
TEchnology Consultant
DXC.technology
5 REPLIES 5
Ben.Lyons1
Hi Krishna,
Before I can provide assistance please can you provide some information?
- What have you tried in order to resolve this? I wouldn't want to suggest things you've already tried
- Have you checked our troubleshooting page in the online help?
- What was your success rate prior to enabling the additional ML Capture model?
- How many documents have you set as the training count?
- Have you followed our best practice guidance in the online help?
- Is this in development or production?
Ben Lyons
UK based
Ben Lyons
SS&C Blue Prism
UK based
Hi Ben thanks for reply
  • I  followed as per Online help but not able to  seenew docuemnt number  on the scree, it shows always N/A
  • Success rate is 80-85% prior to ML
  • After enabling i have processed around 1000 Documents
  • Yes followed best practice as guided
    • One Docuement-Type-->One DFD; Assigned to one Capture Model
  • It is in Production Env
DXC.technology
Hi Krishna,
Thanks for the update, I have a few things you can check. From our troubleshooting help page.
Also, have you tried ticking the "Mark for Training" box? It may take a few moments for the update to start.
Ben Lyons
UK based
Ben Lyons
SS&C Blue Prism
UK based
Hi Benn
I have verified from all the directions and found all exist as per the trouble shoot guide
But I see some errors in capture log  Any Idea ?
2022-11-18 00:18:08.1085 [7440-4] INFO | Model training failed: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
   at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
   at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)
   --- End of inner exception stack trace ---
   at System.Net.FixedSizeReader.ReadPacket(Byte[] buffer, Int32 offset, Int32 count)
   at System.Net.Security._SslStream.StartFrameHeader(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
   at System.Net.Security._SslStream.StartReading(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
   at System.Net.Security._SslStream.ProcessRead(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
   at System.Net.Security.SslStream.Read(Byte[] buffer, Int32 offset, Int32 count)
   at SsiServerCommunication.Clients.SsiTcpClientSession.PerformRequest(Stream stream, BinaryCommand request)
   at SsiServerCommunication.Clients.SsiTcpClientSession.GetCaptureModelTrainingInfo(String captureModelId)
   at SsiDataCaptureClient.DataCaptureLogic.DataCaptureWorker.PerformCaptureModelTraining()
   at SsiDataCaptureClient.DataCaptureClient.DoWorkImpl(Object sender, DoWorkEventArgs e)
Thanks Krishna,
I would recommend raising a support ticket so we can investigate.
Ben Lyons
UK based
Ben Lyons
SS&C Blue Prism
UK based
