MS Edge JavaScript not working BP 7.3
Erika_Papp
Dear All,
I use MS Edge (122.0.2365.92) and Blue Prism version 7.3
When I use the insert and invoke actions to run JavaScript it is not working at all. Is anybody experience the same behavior?
Thank you.
Walter.Koller
Level 11
Do you have WebDriver installed?
I assume you know about the limitation with BP and Edge v120?! I am not sure if later versions of Edge don't have this issue anymore.
[BPE] BP-17972 - Insert/Invoke JavaScript functionality does not work for browser automations spied using Microsoft Edge with the Edge 120 WebDriver : (blueprism.com)
The workaround suggest to downgrade WebDriver version to 119. It would be interesting to know if this workaround is still required with Edge v>120
