OLEDB - How to insert records from collection into AccessDb by using OLEDB
saagarmutyala
Hi Team, How can we insert records into AccessDB by using OLEDB connection. Here, the scenario I have records in the form of "Collection". I want to export this collection to Access DB
HI Sagar,
You can configure the connection using OLE DB and execute the query to insert the rows into access DB.
HI
You had a collection.Same collection format only access db also there.
Create new page under OLEDB vbo "give name as Insert collection into access db"
Inputs are Collection and connectionString="Provider=Microsoft.ACE.OLEDB.12.0;Data Source=mdb file location"
Code:
Dim moConnection As New OleDbConnection(connectionString)
moConnection.Open()
' Iterate over each row in the collection
For Each row As DataRow In Collection_DataItem.Rows
' Construct the SQL insert command for the current row
Dim insertQuery As String = "INSERT INTO [table name] ([Payment Total], [Invoice Number], [Amount Paid], [Remit ID], [Payment Reference], [Creation Date], [File path]) VALUES " & _
"('" & row("Payment Total") & "', '" & row("Invoice Number") & "', '" & row("Amount Paid") & "', '" & row("Remit ID") & "', '" & row("Payment Reference") & "', '" & row("Creation Date") & "', '" & row("File path") & "')"
' Create the command object
Dim oCommand As New OleDbCommand(insertQuery, moConnection)
' Execute the insert command for the current row
oCommand.ExecuteNonQuery()
Next
' Close the database connection
moConnection.Close()
Update as per needs. Above fields are my requirement. and its working.
