adding a number to text problem
oskarjennische1
hi. i have a string that looks like "AB00000001" that i want to add a +1 to.
by using Trim("AB" & ToNumber(Right[number];8))+1) i get AB2, but i miss all the zeros in between. how do i solve this? i have been trying to solve this for a very long time..
thanks in advice
oskar jennische
7 REPLIES 7
MichealCharron
Level 7
@OskarJennische
You can use an old padding trick to accomplish this where there is no padding or formatting functions available.. With the following formula:
Left([number],2) & Right("0000000" & ToNumber(Right([number],8))+1,8)​
What it does is:
  • grabs the first 2 letters (I know you hardcoded the "AB", I just made it a little more dynamic)
  • grabs the last 8 digits, converts it to a number and adds 1 to it (as you did)
  • concatenates 7 zeros to the start of your new number
  • grabs the last 8 digits removing extraneous zeros
  • concatenates the 2 letters to the zero padded new number
Micheal Charron
Senior Manager
RBC
America/Toronto
Micheal Charron
RBC
Toronto, Ontario
Canada
AndrzejFidos
Can it happen that you exceed the number 9 and with the next calculation loose one zero and etc. ?
Andrzej Fidos
thanks. i tried this but i get this error: "incorrect number of parameters to funktion 'Right'"
it seems like it is complaining on the outher right function
oskar jennische
yes, that will happen. the program  will add +1 for each customer that is created. it will be upwards of hundreds of customers added at some later point
oskar jennische
I'm not getting an error.
Micheal Charron
Senior Manager
RBC
America/Toronto
Micheal Charron
RBC
Toronto, Ontario
Canada
i found the problem. i cannot use comma sign "," i need to be using ";" for it to work
oskar jennische
Depending on local settings you need to either use ";" or ","
Andrzej Fidos
