WendyChanSSCINC
Status: Reviewed
Regarding EQM inbound email contents, our client found that when the email body has over 10k chars, those content length after 10k will be truncated. This is confirmed with development team on the limitation.
Our client needs a search of Ref id in the email body text, so that the workflow logic will link the email in source to the work with same Ref id. In the case when email go back and forth, it will become a long email thread. This long email body text has been truncated and unable to return the Ref id for further processing.
This limitation is impacting the business operation, client requests an enhancement on the EQM capture component and allow configuration.
1 Comment
CHJESSON
Suggested solution: Keep the 10K limit as the default for backwards compatibility, but add the ability to set an "override" length in the Chorus Configuration Console/WM7. That length could then be either a new alternative value greater or less that 10K, or a "don't truncate at all" value of 0 or -1.
