gmunden
Status: Planned
This is functionality that exists in Legacy Processor workspace and would be very helpful to add to Modern Processor workspace.  Currently, all columns in the history have the same width and the width cannot be adjusted.  This is a challenge because the Comments column can have lengthy test, which is very hard to read if only a couple words can fit on each line.  We should be able to adjust the column width and the system to remember preferred column width.  Also, the Comments column should default to being wider than the other columns.
2 Comments
Clararaj
Will be added to the plan for next year
Clararaj
This Feature is being planned for 24.1
