Status: New
Single Click Option to Retire and Unretire all schedules in the control room. This option can come in handy during prod deployments and many other situations.
2 Comments
Walter.Koller
Level 11
I generally support this idea to easily un-/retire schedules.
Although I would prefer to have another status for schedules for this purpose.
Currently there is no difference between schedules that are not needed anymore but cannot be deleted and temporary disabled schedules.
Maybe it is a good idea to use 'retired' for moving schedules out of sight because they are not needed anymore. And have some new status like 'disabled' for schedules that are still valid but must not run for some time period. Those 'disabled' schedules would be listed similar to schedules still being active but visibly marked as not being executed.
diane.sanzone
Level 7
Agree With Walter that unless there's a better way to "disable" permanently retired schedules, there would need to be a special holding place for the bulk retired schedules so you can unretire them and only them.
