Date range filters don't work currently when leveraging the Blue Prism REST API v7 for GET requests. The only current workaround is to change the API server to the UTC timezone, region and format. This is not a workable solution for the vast majority of clients. Without this fix, every single transaction will be returned which can often lead to overflow issues, making the API request unusable. A working filter is imperative to retrieve appropriate data.
