sukanyakamiredd
Status: Delivered
while opening this site there is a problem in login, at every time we are facing this problem, at that time we have to do forgotten password. so it is a time taking process. so prevention of this problem is save our password when we created then when we are login match the password digitally.
2 Comments
HarshitRawat
Level 8
i dont think this counts as an Idea though
There was an issue with the portal login and has been confirmed by the support tea,
NorahAlsudani
Community Team (Retired)
Hi Sukanya,
Sorry to hear you are having issues logging in. The Portal and Community log in has the ability to remember your password.
If you are still facing issues logging in, please can you send an email with a screenshot to:
support@blueprism.com
Best regards,
Norah
