Alerts for offline Resource PC
04-04-18 09:27 PM
Do we know if there is any Check or Alert in placed to lookup offline Resource PCs in BP v.5?
Thank you in advance!
Shirley
05-04-18 03:01 PM
Hi Shirley - Login Agent has the Checked Logged In process
07-04-18 01:51 AM
Thank you for the suggestion John_Carter.
However, when a Resource PC is offline, it will not let any process assign to it (or any scheduled tasks to be created). Hence, I was trying to see if there's any type of Alerts available from Blue Prism to flag offline Resources.
12-04-18 06:39 AM
The only automatic 'alert' is the Control Room UI. You could use the HTTP interface to run a process on resource PC1 that pings resource PC2, and then raises an alert/email/whatever if it does not receive a response.
