Automate Salesforce on chrome/chromium edge browser with BP v6.2.1
ankitbass
we are using BP v6.2.1 and wanted to spy Salesforce Lightening on chrome/chromium edge browsers. Any leads on how to make the bot less error prone. OR any DX asset/connector anyone knows that could ease up our spying on salesforce on chrome/chromium edge browser.
ankit bass
sme
s and p global
lookman
Hi ankit.
There are DX assets for SalesForce that you should take a look at although I'm not certain if they are compatible with v6.2.1.
The other thing is that Chrome/Chromium support has really improved in newer versions of BP. Is it possible to upgrade and take advantage of the improvements?
jack
Jack Look
Sr Product Consultant
HI Jack,
It would be impossible for us to upgrade to a new BP version. However, if you could guide me to the DX assets then i can try those.
ankit bass
sme
s and p global
Hi ankit.
That is unfortunate that you cannot upgrade and take advantage of all of the improvements. Regarding the DX, simply put "salesforce" in the search box and you'll see a couple of pages of possibilities. You'll have to look over the descriptions to see if they suit you needs.
jack
Jack Look
thanks Jack. Let me search on DX
ankit bass
sme
s and p global
