03-02-26 11:26 PM
The above read stage is failing in BP 7.3 with the following exception.
| ERROR: Internal : Failed to perform step 1 in Read Stage 'Read Records' on page 'Generic - Read Table (Recognize Text)' - The constructor to deserialize an object of type 'BluePrism.CharMatching.EmptyFontException' was not found. |
Any help with this issue would be awesome.
04-02-26 12:39 AM
Hello TrevorMclellan21!
Please check if the article above helps.
04-02-26 05:25 PM
Hi Leonardo,
Thanks that article was helpful. So it seems like BP 7.3 no longer allows the font field to be left blank. Is this correct? It will be a large change required to provide a font for each of the elements so I am wondering if there is any way to get BluePrism 7.3 to allow for no font to be provided?
