Info: === Logging started: 11/9/2022 14:28:28 ===
CommonData: Message type: 0, Argument: 1033
CommonData: Message type: 1, Argument: Blue Prism Hub
ActionStart: Action 14:28:28: INSTALL.
Info: Action start 14:28:28: INSTALL.
CommonData: 1: 0 2: 1033 3: 1252
Info: === Logging started: 11/9/2022 14:28:32 ===
ActionStart: Action 14:28:32: INSTALL.
Info: Action start 14:28:32: INSTALL.
InstallStart: 1: Blue Prism Hub 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35}
ActionStart: Action 14:28:32: FindRelatedProducts. Searching for related applications
Info: Action start 14:28:32: FindRelatedProducts.
Info: Action ended 14:28:32: FindRelatedProducts. Return value 1.
ActionStart: Action 14:28:32: WixSharp_InitRuntime_Action.
Info: Action start 14:28:32: WixSharp_InitRuntime_Action.
Info: SFXCA: Extracting custom action to temporary directory: C:\Windows\Installer\MSI4746.tmp-\
Info: SFXCA: Binding to CLR version v4.0.30319
Info: Calling custom action WixSharp!WixSharp.ManagedProjectActions.WixSharp_InitRuntime_Action
Info: Action ended 14:28:35: WixSharp_InitRuntime_Action. Return value 1.
ActionStart: Action 14:28:35: AppSearch. Searching for installed applications
Info: Action start 14:28:35: AppSearch.
Info: Action ended 14:28:35: AppSearch. Return value 0.
ActionStart: Action 14:28:35: LaunchConditions. Evaluating launch conditions
Info: Action start 14:28:35: LaunchConditions.
Info: Action ended 14:28:35: LaunchConditions. Return value 1.
ActionStart: Action 14:28:35: ValidateProductID.
Info: Action start 14:28:35: ValidateProductID.
Info: Action ended 14:28:35: ValidateProductID. Return value 1.
ActionStart: Action 14:28:35: CostInitialize. Computing space requirements
Info: Action start 14:28:35: CostInitialize.
Info: Action ended 14:28:35: CostInitialize. Return value 1.
ActionStart: Action 14:28:35: FileCost. Computing space requirements
Info: Action start 14:28:35: FileCost.
Info: Action ended 14:28:35: FileCost. Return value 1.
ActionStart: Action 14:28:35: CostFinalize. Computing space requirements
Info: Action start 14:28:35: CostFinalize.
Info: Action ended 14:28:35: CostFinalize. Return value 1.
ActionStart: Action 14:28:35: Set_ARPNOMODIFY.
Info: Action start 14:28:35: Set_ARPNOMODIFY.
Info: Action ended 14:28:35: Set_ARPNOMODIFY. Return value 1.
ActionStart: Action 14:28:35: MigrateFeatureStates. Migrating feature states from related applications
Info: Action start 14:28:35: MigrateFeatureStates.
Info: Action ended 14:28:35: MigrateFeatureStates. Return value 0.
ActionStart: Action 14:28:35: InstallValidate. Validating install
Info: Action start 14:28:35: InstallValidate.
Info: Action ended 14:29:36: InstallValidate. Return value 1.
ActionStart: Action 14:29:36: InstallInitialize.
Info: Action start 14:29:36: InstallInitialize.
Info: Action ended 14:29:37: InstallInitialize. Return value 1.
ActionStart: Action 14:29:37: GenerateSecrets.
Info: Action start 14:29:37: GenerateSecrets.
Info: SFXCA: Extracting custom action to temporary directory: C:\Windows\Installer\MSI45AC.tmp-\
Info: Calling custom action BluePrism.Cloud.Base.CustomActions!BluePrism.Cloud.Base.CustomActions.CustomActions.GenerateSecrets
Info: Action ended 14:29:40: GenerateSecrets. Return value 1.
ActionStart: Action 14:29:40: RemoveExistingProducts. Removing applications
Info: Action start 14:29:40: RemoveExistingProducts.
Info: Action ended 14:29:40: RemoveExistingProducts. Return value 1.
ActionStart: Action 14:29:40: Set_InstallWindowsFeatures_Props.
Info: Action start 14:29:40: Set_InstallWindowsFeatures_Props.
Info: Action ended 14:29:40: Set_InstallWindowsFeatures_Props. Return value 1.
ActionStart: Action 14:29:40: InstallWindowsFeatures.
Info: Action start 14:29:40: InstallWindowsFeatures.
ActionStart: Action 14:29:42: GenerateScript. Generating script operations for action:
ActionData: InstallWindowsFeatures
Info: Action ended 14:29:42: InstallWindowsFeatures. Return value 1.
ActionStart: Action 14:29:42: ProcessComponents. Updating component registration
Info: Action start 14:29:42: ProcessComponents.
ActionData: 1: Updating component registration
Info: Action ended 14:30:44: ProcessComponents. Return value 1.
ActionStart: Action 14:30:44: UnpublishFeatures. Unpublishing Product Features
Info: Action start 14:30:44: UnpublishFeatures.
Info: Action ended 14:30:44: UnpublishFeatures. Return value 1.
ActionStart: Action 14:30:44: SchedSecureObjectsRollback.
Info: Action start 14:30:44: SchedSecureObjectsRollback.
Info: SchedSecureObjectsRollback: Entering SchedSecureObjectsRollback in C:\Windows\Installer\MSI4ABA.tmp, version 3.11.4516.0
Info: SchedSecureObjectsRollback: Failed to store ACL rollback information with error 0x80070002 - continuing
Info: Action ended 14:30:44: SchedSecureObjectsRollback. Return value 1.
ActionStart: Action 14:30:44: StopServices. Stopping services
Info: Action start 14:30:44: StopServices.
ActionData: Service: Stopping services
Info: Action ended 14:30:44: StopServices. Return value 1.
ActionStart: Action 14:30:44: DeleteServices. Deleting services
Info: Action start 14:30:44: DeleteServices.
Info: Action ended 14:30:44: DeleteServices. Return value 1.
ActionStart: Action 14:30:44: RemoveRegistryValues. Removing system registry values
Info: Action start 14:30:44: RemoveRegistryValues.
Info: Action ended 14:30:44: RemoveRegistryValues. Return value 1.
ActionStart: Action 14:30:44: Set_UnInstallWebsites_Props.
Info: Action start 14:30:44: Set_UnInstallWebsites_Props.
Info: Action ended 14:30:44: Set_UnInstallWebsites_Props. Return value 1.
ActionStart: Action 14:30:44: RemoveFiles. Removing files
Info: Action start 14:30:44: RemoveFiles.
Info: Action ended 14:30:44: RemoveFiles. Return value 1.
ActionStart: Action 14:30:45: Set_CleanFolders_Props.
Info: Action start 14:30:45: Set_CleanFolders_Props.
Info: Action ended 14:30:45: Set_CleanFolders_Props. Return value 1.
ActionStart: Action 14:30:45: RemoveFolders. Removing folders
Info: Action start 14:30:45: RemoveFolders.
Info: Action ended 14:30:45: RemoveFolders. Return value 1.
ActionStart: Action 14:30:45: CreateFolders. Creating folders
Info: Action start 14:30:46: CreateFolders.
ActionData: Folder: Creating folders
Info: Action ended 14:30:46: CreateFolders. Return value 1.
ActionStart: Action 14:30:46: InstallFiles. Copying new files
Info: Action start 14:30:46: InstallFiles.
ActionData: File: Copying new files, Directory: , Size:
Info: Action ended 14:33:25: InstallFiles. Return value 1.
ActionStart: Action 14:33:25: Set_ApplyDatabaseMigrations_Props.
Info: Action start 14:33:25: Set_ApplyDatabaseMigrations_Props.
Info: Action ended 14:33:25: Set_ApplyDatabaseMigrations_Props. Return value 1.
ActionStart: Action 14:33:25: ApplyDatabaseMigrations.
Info: Action start 14:33:25: ApplyDatabaseMigrations.
ActionData:
Info: Action ended 14:33:25: ApplyDatabaseMigrations. Return value 1.
ActionStart: Action 14:33:25: Set_EncryptDatabaseColumns_Props.
Info: Action start 14:33:25: Set_EncryptDatabaseColumns_Props.
Info: Action ended 14:33:25: Set_EncryptDatabaseColumns_Props. Return value 1.
ActionStart: Action 14:33:25: EncryptDatabaseColumns.
Info: Action start 14:33:25: EncryptDatabaseColumns.
ActionData:
Info: Action ended 14:33:25: EncryptDatabaseColumns. Return value 1.
ActionStart: Action 14:33:25: Set_InstallWebsites_Props.
Info: Action start 14:33:25: Set_InstallWebsites_Props.
Info: Action ended 14:33:25: Set_InstallWebsites_Props. Return value 1.
ActionStart: Action 14:33:25: SetInstallWebsites_Rollback.
Info: Action start 14:33:25: SetInstallWebsites_Rollback.
Info: Action ended 14:33:25: SetInstallWebsites_Rollback. Return value 1.
ActionStart: Action 14:33:25: InstallWebsites_Rollback.
Info: Action start 14:33:25: InstallWebsites_Rollback.
ActionData:
Info: Action ended 14:33:25: InstallWebsites_Rollback. Return value 1.
ActionStart: Action 14:33:25: InstallWebsites.
Info: Action start 14:33:25: InstallWebsites.
ActionData:
Info: Action ended 14:33:25: InstallWebsites. Return value 1.
ActionStart: Action 14:33:25: WriteRegistryValues. Writing system registry values
Info: Action start 14:33:25: WriteRegistryValues.
ActionData: Key: Writing system registry values, Name: , Value:
Info: Action ended 14:33:25: WriteRegistryValues. Return value 1.
ActionStart: Action 14:33:25: Set_UpdateAppSettingsJsonFiles_Props.
Info: Action start 14:33:25: Set_UpdateAppSettingsJsonFiles_Props.
Info: Action ended 14:33:25: Set_UpdateAppSettingsJsonFiles_Props. Return value 1.
ActionStart: Action 14:33:25: UpdateAppSettingsJsonFiles.
Info: Action start 14:33:25: UpdateAppSettingsJsonFiles.
ActionData:
Info: Action ended 14:33:25: UpdateAppSettingsJsonFiles. Return value 1.
ActionStart: Action 14:33:25: Set_SetEncryption_Props.
Info: Action start 14:33:25: Set_SetEncryption_Props.
Info: Action ended 14:33:25: Set_SetEncryption_Props. Return value 1.
ActionStart: Action 14:33:25: SetEncryption.
Info: Action start 14:33:25: SetEncryption.
ActionData:
Info: Action ended 14:33:25: SetEncryption. Return value 1.
ActionStart: Action 14:33:25: InstallServices. Installing new services
Info: Action start 14:33:25: InstallServices.
Info: Action ended 14:33:25: InstallServices. Return value 1.
ActionStart: Action 14:33:25: SchedSecureObjects.
Info: Action start 14:33:25: SchedSecureObjects.
Info: SchedSecureObjects: Entering SchedSecureObjects in C:\Windows\Installer\MSIC1F5.tmp, version 3.11.4516.0
ActionStart: Action 14:33:25: ExecSecureObjects.
Info: Action start 14:33:25: ExecSecureObjects.
ActionData:
Info: Action ended 14:33:25: ExecSecureObjects. Return value 1.
Info: Action ended 14:33:25: SchedSecureObjects. Return value 1.
ActionStart: Action 14:33:25: SchedServiceConfig.
Info: Action start 14:33:25: SchedServiceConfig.
Info: SchedServiceConfig: Entering SchedServiceConfig in C:\Windows\Installer\MSIC283.tmp, version 3.11.4516.0
ActionStart: Action 14:33:26: RollbackServiceConfig.
Info: Action start 14:33:26: RollbackServiceConfig.
ActionData:
Info: Action ended 14:33:26: RollbackServiceConfig. Return value 1.
ActionStart: Action 14:33:26: ExecServiceConfig.
Info: Action start 14:33:26: ExecServiceConfig.
ActionData:
Info: Action ended 14:33:26: ExecServiceConfig. Return value 1.
Info: Action ended 14:33:26: SchedServiceConfig. Return value 1.
ActionStart: Action 14:33:26: Set_SetLogServiceLogFolders_Props.
Info: Action start 14:33:26: Set_SetLogServiceLogFolders_Props.
Info: Action ended 14:33:26: Set_SetLogServiceLogFolders_Props. Return value 1.
ActionStart: Action 14:33:26: SetLogServiceLogFolders.
Info: Action start 14:33:26: SetLogServiceLogFolders.
ActionData:
Info: Action ended 14:33:26: SetLogServiceLogFolders. Return value 1.
ActionStart: Action 14:33:26: MsiConfigureServices.
Info: Action start 14:33:26: MsiConfigureServices.
ActionData:
Info: Action ended 14:33:27: MsiConfigureServices. Return value 1.
ActionStart: Action 14:33:27: StartServices. Starting services
Info: Action start 14:33:27: StartServices.
ActionData: Service: Starting services
Info: Action ended 14:33:28: StartServices. Return value 1.
ActionStart: Action 14:33:28: RegisterUser. Registering user
Info: Action start 14:33:28: RegisterUser.
Info: Action ended 14:33:28: RegisterUser. Return value 1.
ActionStart: Action 14:33:28: RegisterProduct. Registering product
Info: Action start 14:33:28: RegisterProduct.
ActionData: Registering product
Info: Action ended 14:33:28: RegisterProduct. Return value 1.
ActionStart: Action 14:33:28: PublishFeatures. Publishing Product Features
Info: Action start 14:33:28: PublishFeatures.
ActionData: Feature: Publishing Product Features
Info: Action ended 14:33:28: PublishFeatures. Return value 1.
ActionStart: Action 14:33:28: PublishProduct. Publishing product information
Info: Action start 14:33:28: PublishProduct.
ActionData: 1: Publishing product information
Info: Action ended 14:33:28: PublishProduct. Return value 1.
ActionStart: Action 14:33:28: Set_CancelRequestHandler_Props.
Info: Action start 14:33:28: Set_CancelRequestHandler_Props.
Info: Action ended 14:33:28: Set_CancelRequestHandler_Props. Return value 1.
ActionStart: Action 14:33:28: CancelRequestHandler.
Info: Action start 14:33:28: CancelRequestHandler.
ActionData:
Info: Action ended 14:33:28: CancelRequestHandler. Return value 1.
ActionStart: Action 14:33:28: Set_RestartAppPools_Props.
Info: Action start 14:33:28: Set_RestartAppPools_Props.
Info: Action ended 14:33:28: Set_RestartAppPools_Props. Return value 1.
ActionStart: Action 14:33:28: RestartAppPools.
Info: Action start 14:33:28: RestartAppPools.
ActionData:
Info: Action ended 14:33:28: RestartAppPools. Return value 1.
ActionStart: Action 14:33:28: InstallFinalize.
Info: Action start 14:33:28: InstallFinalize.
ActionStart: Action 14:33:29: InstallWindowsFeatures.
Info: SFXCA: Extracting custom action to temporary directory: C:\Windows\Installer\MSICE8A.tmp-\
Info: Calling custom action BluePrism.Cloud.Base.CustomActions!BluePrism.Cloud.Base.CustomActions.CustomActions.InstallWindowsFeatures
Info: Attempting to install windows features
Info: C:\Windows\sysnative\dism.exe /Online /Enable-Feature /Quiet /All /FeatureName:IIS-WebServer /FeatureName:FSRM-Infrastructure /FeatureName:FSRM-Management /FeatureName:ServerManager-Core-RSAT-Role-Tools /FeatureName:Server-Manager-RSAT-File-Services /FeatureName:WCF-HTTP-Activation45 /FeatureName:IIS-ApplicationInit
Info:
Exited with code: 0
OutputText:
ErrorText:
ActionStart: Action 14:33:44: ProcessComponents. Updating component registration
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB295C3D6D} 3: C:\Program Files (x86)\Blue Prism\
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB08DA97F6} 3: C:\Program Files (x86)\Blue Prism\Audit Service\appsettings.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3C52978E} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Automatonymous.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB601FCE58} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Azure.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9EF959BE} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Azure.Monitor.OpenTelemetry.Exporter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB80206104} 3: C:\Program Files (x86)\Blue Prism\Audit Service\BPC.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDC794D89} 3: C:\Program Files (x86)\Blue Prism\Audit Service\BPC.Extensions.Middleware.ExceptionHandler.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD58442E2} 3: C:\Program Files (x86)\Blue Prism\Audit Service\BPC.Extensions.Telemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE624C8DA} 3: C:\Program Files (x86)\Blue Prism\Audit Service\BPC.Logger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB652DCD47} 3: C:\Program Files (x86)\Blue Prism\Audit Service\BPC.SettingsProtection.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8FB2036F} 3: C:\Program Files (x86)\Blue Prism\Audit Service\BPC.SettingsProtection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB057B51E3} 3: C:\Program Files (x86)\Blue Prism\Audit Service\BPC.SettingsProtection.Services.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB9E21C9C} 3: C:\Program Files (x86)\Blue Prism\Audit Service\BPC.WindowsAudit.DataAccess.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBC947BD7} 3: C:\Program Files (x86)\Blue Prism\Audit Service\BPC.WindowsAudit.Web.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3C073241} 3: C:\Program Files (x86)\Blue Prism\Audit Service\BPC.WindowsAudit.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC0C3AE4D} 3: C:\Program Files (x86)\Blue Prism\Audit Service\BPC.WindowsAudit.Web.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB25250254} 3: C:\Program Files (x86)\Blue Prism\Audit Service\BPC.WindowsAudit.Web.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB35CFC573} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Elasticsearch.Net.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB82E862B1} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Google.Protobuf.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB87EF563B} 3: C:\Program Files (x86)\Blue Prism\Audit Service\GreenPipes.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB302D7130} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Grpc.Core.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB506E3767} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Grpc.Net.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBEDE7D48} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Grpc.Net.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBAFF8ECA} 3: C:\Program Files (x86)\Blue Prism\Audit Service\HealthChecks.IdSvr.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB83540874} 3: C:\Program Files (x86)\Blue Prism\Audit Service\HealthChecks.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB843A9EF8} 3: C:\Program Files (x86)\Blue Prism\Audit Service\MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB514D8095} 3: C:\Program Files (x86)\Blue Prism\Audit Service\MassTransit.ExtensionsDependencyInjectionIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5A9A8203} 3: C:\Program Files (x86)\Blue Prism\Audit Service\MassTransit.Platform.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBE7BE0DD} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.AI.DependencyCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2B003D3B} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.AI.EventCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB632E249B} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.AI.PerfCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4891D456} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.AI.ServerTelemetryChannel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC660057A} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.AI.WindowsServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA61C0627} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.ApplicationInsights.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAE637BBC} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4C404AAA} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.ApplicationInsights.NLogTarget.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5C879BBA} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.ApplicationInsights.WorkerService.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7EA9CA2B} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.AspNetCore.Authentication.JwtBearer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD0C0E5B4} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.AspNetCore.Authentication.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBDBF760E} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.AspNetCore.OData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC0F2934D} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Azure.KeyVault.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6BF0E574} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Azure.KeyVault.WebKey.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB2BF77AB} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA754311F} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Bcl.AsyncInterfaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3B5D03BB} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Bcl.HashCode.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDC0ADF2C} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB57D28207} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.EntityFrameworkCore.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF05888E3} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8C3F0FB0} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.EntityFrameworkCore.Relational.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7C75D72E} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.EntityFrameworkCore.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD633D8DC} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.Caching.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5C524C9A} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.Caching.Memory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB09818742} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3C7FD16F} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8701F5BA} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7E74FC4F} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB144874B7} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDB2E9A64} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB334A0A0E} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.Diagnostics.HealthChecks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFA79FF35} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.FileProviders.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2A83446B} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.Hosting.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFD06716F} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4FA01D3D} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDBAB38BB} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.Logging.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA50CEFF3} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD9EBE1DA} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAD3A0C40} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB04D61041} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEC679347} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Identity.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB43766000} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6D88109D} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB259E1AEC} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.IdentityModel.JsonWebTokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2E2E785D} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.IdentityModel.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC1914BA8} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.IdentityModel.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC7835A85} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.IdentityModel.Protocols.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB05DCF7C1} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.IdentityModel.Tokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2F018C52} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.OData.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAFC5AEAF} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.OData.Edm.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB07C6CB8D} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Rest.ClientRuntime.Azure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB12643DC2} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Rest.ClientRuntime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB67D8AFD2} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Microsoft.Spatial.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0DF5DDF3} 3: C:\Program Files (x86)\Blue Prism\Audit Service\NewId.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEEAA1EB5} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Newtonsoft.Json.Bson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCD931EC8} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Newtonsoft.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6A04A471} 3: C:\Program Files (x86)\Blue Prism\Audit Service\NLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB239EBF42} 3: C:\Program Files (x86)\Blue Prism\Audit Service\NLog.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9E9331F4} 3: C:\Program Files (x86)\Blue Prism\Audit Service\NLog.Targets.ElasticSearch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAA80DB18} 3: C:\Program Files (x86)\Blue Prism\Audit Service\NLog.Web.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB381222A5} 3: C:\Program Files (x86)\Blue Prism\Audit Service\NWebsec.AspNetCore.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEBCFAB22} 3: C:\Program Files (x86)\Blue Prism\Audit Service\NWebsec.AspNetCore.Middleware.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5EC645D6} 3: C:\Program Files (x86)\Blue Prism\Audit Service\OpenTelemetry.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDFCA0236} 3: C:\Program Files (x86)\Blue Prism\Audit Service\OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7DDE7D8B} 3: C:\Program Files (x86)\Blue Prism\Audit Service\OpenTelemetry.Contrib.Instrumentation.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF370F3A9} 3: C:\Program Files (x86)\Blue Prism\Audit Service\OpenTelemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEBD21EBF} 3: C:\Program Files (x86)\Blue Prism\Audit Service\OpenTelemetry.Exporter.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFFFD7725} 3: C:\Program Files (x86)\Blue Prism\Audit Service\OpenTelemetry.Exporter.Jaeger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCFA0E7B1} 3: C:\Program Files (x86)\Blue Prism\Audit Service\OpenTelemetry.Exporter.OpenTelemetryProtocol.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5363F0F7} 3: C:\Program Files (x86)\Blue Prism\Audit Service\OpenTelemetry.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB5DC610F} 3: C:\Program Files (x86)\Blue Prism\Audit Service\OpenTelemetry.Instrumentation.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEFD67E8B} 3: C:\Program Files (x86)\Blue Prism\Audit Service\OpenTelemetry.Instrumentation.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB11D1A6D1} 3: C:\Program Files (x86)\Blue Prism\Audit Service\OpenTelemetry.Instrumentation.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB31BB211E} 3: C:\Program Files (x86)\Blue Prism\Audit Service\System.Configuration.ConfigurationManager.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCA765FC8} 3: C:\Program Files (x86)\Blue Prism\Audit Service\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6E655715} 3: C:\Program Files (x86)\Blue Prism\Audit Service\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB053B912E} 3: C:\Program Files (x86)\Blue Prism\Audit Service\System.IdentityModel.Tokens.Jwt.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB19AD6722} 3: C:\Program Files (x86)\Blue Prism\Audit Service\System.Memory.Data.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAF5409FD} 3: C:\Program Files (x86)\Blue Prism\Audit Service\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7AB48589} 3: C:\Program Files (x86)\Blue Prism\Audit Service\System.Runtime.CompilerServices.Unsafe.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA44EFDC4} 3: C:\Program Files (x86)\Blue Prism\Audit Service\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA84835D2} 3: C:\Program Files (x86)\Blue Prism\Audit Service\System.Text.Encodings.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB83836DA4} 3: C:\Program Files (x86)\Blue Prism\Audit Service\System.Text.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD33BA7BA} 3: C:\Program Files (x86)\Blue Prism\Audit Service\System.Threading.Channels.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB924C9099} 3: C:\Program Files (x86)\Blue Prism\Audit Service\web.config
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFC7B4123} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\BPC.WindowsAudit.Migrator.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9D61AE05} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\BPC.WindowsAudit.Migrator.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBAC85FFF} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\BPC.WindowsAudit.Migrator.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB20730F4C} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\BPC.WindowsAudit.Migrator.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBC619614} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\CommandLine.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEE5BCDCF} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\dbup-core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF1030028} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\dbup-sqlserver.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC0049CC2} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\MediatR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB000B40CB} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\MediatR.Extensions.Microsoft.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD1E66BFB} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE757890A} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0222FD87} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6B779DFB} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5619C000} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF3F3FA6F} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB262674E1} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6DF3C22A} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\Microsoft.Extensions.Logging.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4B82A409} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\Microsoft.Extensions.Logging.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4F527A56} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2C5C1C7D} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2EBFC2A0} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4E1806D0} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCBA65D0A} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1BF91E27} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3BA90CBB} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB63465412} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\System.Text.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFA138B79} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\runtimes\unix\lib\netcoreapp2.1\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA2A52F47} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\runtimes\win\lib\netcoreapp2.1\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9BAD4F2E} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\runtimes\win-arm64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB28D6B43A} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\runtimes\win-x64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6FD06C8C} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\runtimes\win-x86\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0F2327BB} 3: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\unix\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF6D7F9FE} 3: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\unix\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB0371177} 3: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\win\lib\netcoreapp2.0\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7C510154} 3: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\win\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB196EC07B} 3: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\win\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6163B054} 3: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\win\lib\netstandard2.0\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF8239492} 3: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\win-arm64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2D16465B} 3: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\win-x64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0B3DA421} 3: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\win-x86\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4F629DA5} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Scripts\AuditDB.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB00BB5C4F} 3: C:\Program Files (x86)\Blue Prism\Audit Service\Scripts\CreateAuditDB.ps1
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA87B4508} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\appsettings.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBACE5CA33} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Automatonymous.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB54D74077} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Azure.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF3703A89} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Azure.Monitor.OpenTelemetry.Exporter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB82D2124} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\BPC.Audit.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCEF2ABBD} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\BPC.AuditService.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB23401544} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\BPC.AuditService.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC2FC8E8E} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\BPC.AuditService.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB85A326DD} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\BPC.AuditService.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7DA9C31D} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\BPC.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFAC832DC} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\BPC.Extensions.Telemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB04021EE2} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\BPC.Logger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2355E485} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\BPC.Messaging.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA914DDF8} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\BPC.SettingsProtection.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8B7D5FA5} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\BPC.SettingsProtection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDFC476BE} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\BPC.SettingsProtection.Services.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6BCB1B6B} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Elasticsearch.Net.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB93D4F589} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Google.Protobuf.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB69CCCCF2} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\GreenPipes.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3DB3A77F} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Grpc.Core.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB621422CD} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Grpc.Net.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF2B8CD40} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Grpc.Net.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF2997578} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\MassTransit.AspNetCoreIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5D280BDB} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\MassTransit.Azure.ServiceBus.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9B72F077} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB095B6DBA} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\MassTransit.ExtensionsDependencyInjectionIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0A36F2AC} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\MassTransit.Platform.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1F6FE24E} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\MassTransit.RabbitMqTransport.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE6E3316A} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\MassTransit.SignalR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF26A0D95} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.AI.DependencyCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB58BAC73F} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.AI.EventCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB90265589} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.AI.PerfCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1C9E0251} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.AI.ServerTelemetryChannel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB89B36047} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.AI.WindowsServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB85CAB010} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.ApplicationInsights.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6586E454} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9055A5BE} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.ApplicationInsights.NLogTarget.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3A07522B} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.ApplicationInsights.WorkerService.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3313FAF9} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Azure.Amqp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7BFA73EF} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Azure.KeyVault.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB66E33424} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Azure.KeyVault.WebKey.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCC56DF41} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Azure.ServiceBus.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAD233A37} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEA1C82D0} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Bcl.AsyncInterfaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB97B9DCF0} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.DotNet.PlatformAbstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDBE04268} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3C924853} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB2902227} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Configuration.CommandLine.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7C5C2C5E} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB627815E0} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Configuration.EnvironmentVariables.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7178299E} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Configuration.FileExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1F20C10C} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Configuration.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8CD1D92D} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Configuration.UserSecrets.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB459A5542} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3F57097C} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFC34E272} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.DependencyModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCF90A53A} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB00987FA3} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Diagnostics.HealthChecks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD90D9ED9} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.FileProviders.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1875CFAD} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.FileProviders.Physical.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF08FDEFD} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.FileSystemGlobbing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC7942D28} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Hosting.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB41C7D29A} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB61E7C370} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Hosting.WindowsServices.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB878E1611} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF0252D60} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Logging.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6EB1D3A3} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Logging.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6A1BE6EB} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Logging.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB412F4CC6} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Logging.Debug.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB146E5FF4} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0EA128AF} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Logging.EventLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD6DEDA3A} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Logging.EventSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB58D4F78C} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1D4BB66D} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDB067EF0} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2DA1439A} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB931FBADD} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1946CC50} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.IdentityModel.JsonWebTokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB959A6D14} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.IdentityModel.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB45D4BB0A} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.IdentityModel.Tokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3C2F6D05} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Rest.ClientRuntime.Azure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB71DF4EBB} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Microsoft.Rest.ClientRuntime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB415C168} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\NewId.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA8AC72FA} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Newtonsoft.Json.Bson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB45C91482} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Newtonsoft.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4EB91243} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\NLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB40B416D5} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\NLog.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDC173BDE} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\NLog.Targets.ElasticSearch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6739B493} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\NLog.Web.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB09C105B3} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\OpenTelemetry.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4561DCEF} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4B1402ED} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\OpenTelemetry.Contrib.Instrumentation.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB94DD3E6B} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\OpenTelemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9993DE31} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\OpenTelemetry.Exporter.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDBBC4819} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\OpenTelemetry.Exporter.Jaeger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBB853FB0} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\OpenTelemetry.Exporter.OpenTelemetryProtocol.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2243476C} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\OpenTelemetry.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6EB78410} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\OpenTelemetry.Instrumentation.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5FD036A2} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\OpenTelemetry.Instrumentation.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1F282B75} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\OpenTelemetry.Instrumentation.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB8C37768} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\RabbitMQ.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3C446666} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\Scrutor.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2205F977} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\System.ComponentModel.Annotations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB54013BB2} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\System.Configuration.ConfigurationManager.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB61C71BDB} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB994AD8AA} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0DFC0355} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB84911B2} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\System.IdentityModel.Tokens.Jwt.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB77ED4B99} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\System.Memory.Data.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB08C20251} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\System.Runtime.CompilerServices.Unsafe.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF75A2C98} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB080222DF} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\System.ServiceProcess.ServiceController.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7F03039E} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\System.Text.Encodings.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB96DDF518} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\System.Text.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF20059B6} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\System.Threading.Channels.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB68DA1F10} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\runtimes\unix\lib\netcoreapp2.1\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB493B24C8} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\runtimes\win\lib\netcoreapp2.0\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE57D2442} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\runtimes\win\lib\netcoreapp2.1\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC2D92FB9} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\runtimes\win\lib\netstandard2.0\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4C02DB12} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\runtimes\win\lib\netstandard2.0\System.ServiceProcess.ServiceController.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9650803F} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\runtimes\win-arm64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB21F18ED9} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\runtimes\win-x64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB47F28DB2} 3: C:\Program Files (x86)\Blue Prism\Audit Service Listener\runtimes\win-x86\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB754CA542} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\appsettings.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA2C06375} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\AutoMapper.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB434A69E7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Automatonymous.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF8FD58C3} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Azure.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD87891F3} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Azure.Monitor.OpenTelemetry.Exporter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF633B622} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BluePrism.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB46611A4A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Audit.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6F9718B1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Audit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE003376B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4BAB627A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.EmailService.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB00944C2D} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.EmailService.Messages.Commands.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB97B79FAC} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Extensions.ActionResults.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF6113C39} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Extensions.ActionResults.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8981BDB8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA9B53253} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Extensions.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1A0A4E51} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Extensions.Linq.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB006EB157} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Extensions.Middleware.ExceptionHandler.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB25C01A41} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Extensions.String.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF9F7526B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Extensions.Tasks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB441ADF50} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Extensions.Telemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6F2C5C88} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.FileStorage.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3ABF685F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Hub.Messages.Commands.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA16B3730} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Ims.Messages.Commands.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5EE9BC78} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.IMS.Messages.Events.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8E7B4F83} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Interact.Messages.Commands.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6E9872F7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.LicenseManager.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCCBA4391} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.LicenseManager.Messages.Events.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB558D8717} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Logger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8B6BD624} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Messaging.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB52E892AE} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Repository.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDD26B7F6} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Search.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB55641128} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Search.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB62749C75} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.Search.Services.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF7F1DCC1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.SettingsProtection.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1B6F0FDA} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.SettingsProtection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA7DD8AB0} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\BPC.SettingsProtection.Services.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB75A1C3FD} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\dotnet-aspnet-codegenerator-design.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9784C189} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\EFCore.BulkExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB753069EB} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Elasticsearch.Net.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB26CAF4F5} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\FastMember.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB35D08FCB} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Google.Protobuf.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEEAB0A65} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\GreenPipes.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5A1B78A6} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Grpc.Core.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFF5B5754} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Grpc.Net.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1CB40642} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Grpc.Net.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9927C214} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\HealthChecks.RabbitMQ.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE777123F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\HealthChecks.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7B496D06} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\IdentityModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7E8D803E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\IdentityServer4.AspNetIdentity.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7BADE9BC} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\IdentityServer4.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB116CD2F9} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\IdentityServer4.EntityFramework.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB83A80A6C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\IdentityServer4.EntityFramework.Storage.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA6266D55} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\IdentityServer4.Storage.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6D14D285} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ImsServer.BusinessLogic.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB615FA953} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ImsServer.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4B79B722} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ImsServer.DataAccess.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB47F7B345} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ImsServer.IntegrationServices.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1893EFDD} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ImsServer.Web.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB77CACD5C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ImsServer.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB433848F8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ImsServer.Web.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3CA57A4A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ImsServer.Web.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4C80B344} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ImsServer.Web.Views.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFE272DCA} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\MassTransit.AspNetCoreIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB83C9DA1B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\MassTransit.Azure.ServiceBus.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB258E36F1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0B4FC492} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\MassTransit.ExtensionsDependencyInjectionIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB0C76A38} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\MassTransit.Platform.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2012D4C0} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\MassTransit.RabbitMqTransport.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFABA6041} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\MassTransit.SignalR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB83B4246A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AI.DependencyCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB388AA4AA} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AI.EventCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0E1D16B5} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AI.PerfCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8AD15DFE} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AI.ServerTelemetryChannel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA6402DAE} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AI.WindowsServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB870EE42E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.ApplicationInsights.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4D45798D} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3D780638} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.ApplicationInsights.NLogTarget.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD1CA68AD} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AspNetCore.Authentication.JwtBearer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2EE2684E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AspNetCore.Authentication.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6B730F02} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AspNetCore.Cryptography.Internal.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB71F62E99} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AspNetCore.Cryptography.KeyDerivation.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB11071758} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AspNetCore.DataProtection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB429B73DD} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AspNetCore.DataProtection.AzureStorage.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEBB5212E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AspNetCore.DataProtection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB12FBDA4C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AspNetCore.Identity.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9587928D} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AspNetCore.JsonPatch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBDE1087A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AspNetCore.Mvc.NewtonsoftJson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB30789DB} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AspNetCore.Mvc.Razor.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBDFDB62F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AspNetCore.NodeServices.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3A38FEE5} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AspNetCore.Razor.Language.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6AE37802} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AspNetCore.SpaServices.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5DB03A81} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.AspNetCore.SpaServices.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1DA5AA09} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Azure.Amqp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB26E870E2} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Azure.KeyVault.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5AA8E3D7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Azure.KeyVault.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB399958FB} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Azure.KeyVault.WebKey.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB004E58F2} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Azure.ServiceBus.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2E6424D5} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB351A4882} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Azure.Storage.Blob.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE7765074} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Azure.Storage.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB63706493} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Bcl.AsyncInterfaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB15553A7E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Bcl.HashCode.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB83330430} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.CodeAnalysis.CSharp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB13A4B623} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.CodeAnalysis.CSharp.Workspaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0CF81414} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.CodeAnalysis.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBDC6D57F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.CodeAnalysis.Razor.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3467F6BD} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.CodeAnalysis.Workspaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6D597DF5} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Data.Edm.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB93FD966C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Data.OData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4AFE3C4C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB205B1D22} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Data.Sqlite.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9A4966F7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.DotNet.PlatformAbstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB31088C86} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.EntityFrameworkCore.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA62AC7D7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.EntityFrameworkCore.Design.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB211DD803} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCAD520FC} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.EntityFrameworkCore.Relational.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB4A455AE} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.EntityFrameworkCore.Sqlite.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB903D240F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.EntityFrameworkCore.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB9695767} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Caching.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB302CDFDA} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Caching.Memory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE4CF5F77} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Caching.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB586BFBD6} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBECE73ED9} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD19E9891} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Configuration.CommandLine.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEA864438} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5FA6202C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Configuration.EnvironmentVariables.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8022D98F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Configuration.FileExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCDB65189} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Configuration.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6CD585C8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Configuration.UserSecrets.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5D96697E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB04F7983B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAD63A4EF} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.DependencyModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB54ED022C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4A810583} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Diagnostics.HealthChecks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB91AE12D0} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.FileProviders.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB01134F70} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.FileProviders.Physical.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA939F1FB} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.FileSystemGlobbing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB79E1B4AC} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Hosting.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB87C5B962} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB651CE293} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3D387C73} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Identity.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4E7DCE97} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Identity.Stores.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2438A9E4} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9BAD6392} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Logging.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2CDBCC70} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Logging.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5D0E680E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Logging.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB21399D0C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Logging.Debug.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB30AF663E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB46081F6A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Logging.EventLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB93BE5D87} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Logging.EventSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB49AF3EA0} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1B1A550D} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9CA95384} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB18412973} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.FeatureManagement.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB03B8F77F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.FeatureManagement.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD9D8BFCE} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Identity.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF16C20FC} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB17B46B5B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB961A09AA} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.IdentityModel.JsonWebTokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA36D35C7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.IdentityModel.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7DCC4B70} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.IdentityModel.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB43ED9D0A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.IdentityModel.Protocols.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB198577F1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.IdentityModel.Tokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2ADF353B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.OpenApi.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB3AA1822} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Rest.ClientRuntime.Azure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8D217835} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Rest.ClientRuntime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3E72FB93} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.VisualStudio.Web.CodeGeneration.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC933477D} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.VisualStudio.Web.CodeGeneration.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB1A8FEB3} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.VisualStudio.Web.CodeGeneration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB18F71539} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.VisualStudio.Web.CodeGeneration.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB97DE48AD} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.VisualStudio.Web.CodeGeneration.Templating.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8E12E2C7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.VisualStudio.Web.CodeGeneration.Utils.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3BCE00E0} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.VisualStudio.Web.CodeGenerators.Mvc.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFFD8AC62} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Microsoft.Win32.SystemEvents.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB704466FF} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\NewId.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC704B082} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Newtonsoft.Json.Bson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD3381765} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Newtonsoft.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB02B7522D} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\NLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0A483132} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\NLog.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFBA8F4A6} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\NLog.Targets.ElasticSearch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB76D8195C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\NLog.Web.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEEDE8242} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Novell.Directory.Ldap.NETStandard.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBFD14444} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\NuGet.Frameworks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB29576E88} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\NWebsec.AspNetCore.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA60B3549} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\NWebsec.AspNetCore.Middleware.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2E205539} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\OpenTelemetry.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5457F358} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF03C00CF} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\OpenTelemetry.Contrib.Instrumentation.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6DEBDCF0} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\OpenTelemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB5495F8F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\OpenTelemetry.Exporter.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5F0A1821} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\OpenTelemetry.Exporter.Jaeger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFCD76052} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\OpenTelemetry.Exporter.OpenTelemetryProtocol.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9BCFB8B9} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\OpenTelemetry.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD9572092} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\OpenTelemetry.Instrumentation.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3C1163BE} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\OpenTelemetry.Instrumentation.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEC60F5D0} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\OpenTelemetry.Instrumentation.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB4DB0439} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\RabbitMQ.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4EB73AA3} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Scrutor.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1F7F525A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\SixLabors.Fonts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFD1859AD} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\SixLabors.ImageSharp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF5A56C28} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\SixLabors.ImageSharp.Drawing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB21D306A5} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\SkiDiveCode.Ldap.Rfc2253.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCC72BB98} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\SQLitePCLRaw.batteries_v2.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA73CC461} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\SQLitePCLRaw.core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC5C854E6} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\SQLitePCLRaw.nativelibrary.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9840EA68} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\SQLitePCLRaw.provider.dynamic_cdecl.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5A1AB304} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Swashbuckle.AspNetCore.Annotations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE0F73E2F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Swashbuckle.AspNetCore.Swagger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB44C24219} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Swashbuckle.AspNetCore.SwaggerGen.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB134240E1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Swashbuckle.AspNetCore.SwaggerUI.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB34887241} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.ComponentModel.Annotations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB136D0E6C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Composition.AttributedModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA78F237B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Composition.Convention.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBDB28DEF} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Composition.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB800B4185} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Composition.Runtime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFC56E11A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Composition.TypedParts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB866074E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Configuration.ConfigurationManager.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE5270E08} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB33540E33} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE736099C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.DirectoryServices.AccountManagement.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF499FB41} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.DirectoryServices.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAD4960E9} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.DirectoryServices.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCB05DCEF} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Drawing.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB388DA66C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.IdentityModel.Tokens.Jwt.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF89E7889} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.IO.FileSystem.AccessControl.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCF8D08DD} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Memory.Data.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB05DDB02} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Resources.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA66629AF} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA3B0140C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Runtime.CompilerServices.Unsafe.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4CE7D491} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Security.AccessControl.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC9DA4EA8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1D148234} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Security.Permissions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB42F0496E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Security.Principal.Windows.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB88F95288} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Spatial.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3650BD53} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Text.Encodings.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA6204B1E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Text.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB02A99435} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Threading.Channels.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB808458E8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\System.Windows.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2BDA5FD1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\web.config
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB22571413} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\cs\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD218B3D6} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\cs\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB530F411A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\cs\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE2601190} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\cs\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF864DF12} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\de\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB89F7EE4C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\de\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA5F44070} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\de\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB42A1ADA1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\de\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB416D5A26} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\de\Microsoft.Data.Edm.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD175083D} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\de\Microsoft.Data.OData.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB62C89484} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\de\System.Spatial.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAF189166} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\es\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6768D5E4} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\es\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB510E0A13} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\es\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB1EC70AD} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\es\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3912CD32} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\es\Microsoft.Data.Edm.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB07848378} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\es\Microsoft.Data.OData.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBB91829B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\es\System.Spatial.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4315E5E4} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\fr\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA018E941} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\fr\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC16EA7F8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\fr\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB964ECC78} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\fr\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB20502BC} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\fr\Microsoft.Data.Edm.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB74581752} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\fr\Microsoft.Data.OData.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB48FE1713} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\fr\System.Spatial.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB494AC1B1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\it\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB0D6789C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\it\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8724C450} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\it\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB36CB001D} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\it\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCE7C7B0B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\it\Microsoft.Data.Edm.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3A9C2E60} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\it\Microsoft.Data.OData.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2D1363BF} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\it\System.Spatial.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF909BEC9} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ja\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4A41E5A7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ja\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE8B8DDF2} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ja\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEFB27948} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ja\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB699E7B1E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ja\Microsoft.Data.Edm.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4B3A85BB} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ja\Microsoft.Data.OData.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1D1B1E2B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ja\System.Spatial.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1D9802D7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ko\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB78608BBC} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ko\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE6573630} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ko\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB778017E7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ko\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB54E418F2} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ko\Microsoft.Data.Edm.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCA0722D4} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ko\Microsoft.Data.OData.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB67917123} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ko\System.Spatial.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC54CCEA6} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrations\SqlScripts\RefreshTokenMigration.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC3A4243D} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrations\SqlScripts\RenameAuthenticationSettingsTable.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB09BBFAD3} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrations\SqlScripts\UpdateHubAndInteractClients.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6644646F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrations\SqlScripts\UpdateHubAndInteractClientsDown.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE0FAA32F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\AutoMapper.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB77EE4441} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Automatonymous.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB08173EEA} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\BluePrism.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCA8928B6} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\BPC.Audit.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB220E3F88} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\BPC.Audit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB41E4FAAB} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\BPC.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB29D56942} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\BPC.Extensions.ActionResults.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDE8DD959} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\BPC.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB54FAABEE} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\BPC.FileStorage.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2A1DBCF5} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\BPC.Logger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAE0ABDD2} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\BPC.Messaging.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB8C74D89} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\BPC.Repository.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6453C5C8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\BPC.SettingsProtection.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA4555773} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\BPC.SettingsProtection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4A35C2C2} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\BPC.SettingsProtection.Services.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB09AECE12} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\CommandLine.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF351461C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\dbup-core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5676A75D} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\dbup-sqlserver.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1145CAA6} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\EFCore.BulkExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB894219A0} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Elasticsearch.Net.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB93748D72} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\FastMember.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5274DD10} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\GreenPipes.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF9794D45} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\IdentityModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA8F95CEE} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\IdentityServer4.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7E32FF76} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\IdentityServer4.EntityFramework.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA22FA717} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\IdentityServer4.EntityFramework.Storage.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6C2F5E28} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\IdentityServer4.Storage.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB01135CFA} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\ImsMigrations.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9AD85394} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\ImsMigrations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAA9E2E11} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\ImsMigrations.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8F7F6EFB} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\ImsMigrations.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAF70EE9A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\ImsServer.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD6515DEB} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\ImsServer.DataAccess.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1D9DE80C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\MassTransit.AspNetCoreIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5703F651} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\MassTransit.Azure.ServiceBus.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB45D164A0} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB214D0A70} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\MassTransit.ExtensionsDependencyInjectionIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE501F72A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\MassTransit.RabbitMqTransport.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB53A46EA} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\MassTransit.SignalR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8AB29030} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\MediatR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA4708E3F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\MediatR.Extensions.Microsoft.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB060FF4D4} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.AI.DependencyCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB964E916E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.AI.EventCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6B67EAA0} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.AI.PerfCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3368C327} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.AI.ServerTelemetryChannel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB71985F53} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.AI.WindowsServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB17F8D2C6} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.ApplicationInsights.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBAFE792D} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB46837821} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.ApplicationInsights.NLogTarget.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC59A2914} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.AspNetCore.Authentication.JwtBearer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF656F1CC} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.AspNetCore.Authentication.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8700FD6E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.AspNetCore.Cryptography.Internal.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBE9FDB0C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.AspNetCore.Cryptography.KeyDerivation.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB25305C8B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.AspNetCore.Identity.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9E363C0B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.AspNetCore.JsonPatch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4F190A6D} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.AspNetCore.Mvc.Razor.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDE8148DF} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.AspNetCore.Razor.Language.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC0463F51} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Azure.Amqp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA3816CF6} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Azure.KeyVault.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEA366F9C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Azure.KeyVault.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB40B5080F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Azure.KeyVault.WebKey.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE9DC2432} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Azure.ServiceBus.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8707D25E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB39BF4236} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Azure.Storage.Blob.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3F53A820} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Azure.Storage.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDFB1EA08} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Bcl.AsyncInterfaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEC2962B3} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Bcl.HashCode.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8EE94B55} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.CodeAnalysis.CSharp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB42C1807C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.CodeAnalysis.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE478239D} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.CodeAnalysis.Razor.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6BC23929} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE1748CE5} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Data.Sqlite.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB38632018} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.DotNet.PlatformAbstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB08AF83B1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.EntityFrameworkCore.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4B2569B1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.EntityFrameworkCore.Design.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEE0017B3} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD094D04F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.EntityFrameworkCore.Relational.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5A813A0A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.EntityFrameworkCore.Sqlite.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA1E295C5} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.EntityFrameworkCore.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7D7FC753} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Caching.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB85E2F6C1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Caching.Memory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6E1EC459} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB24AE33D7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBABE74477} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Configuration.CommandLine.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD1D411C8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB0011B6C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Configuration.EnvironmentVariables.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB587B57BE} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Configuration.FileExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB26269FFA} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Configuration.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB183E93E7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Configuration.UserSecrets.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1227AF40} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7383B346} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4A5BB62A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.DependencyModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDB9C6834} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.DiagnosticAdapter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD898214B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB09661D35} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Diagnostics.HealthChecks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4D13E31B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.FileProviders.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAB02535C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.FileProviders.Physical.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0542988B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.FileSystemGlobbing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE715ED0E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Hosting.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB58DD2C2C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3FFF4B65} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF95336AD} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Identity.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAAE76DD5} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Identity.Stores.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4C1E0109} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB343D781D} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Logging.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD803A9AD} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Logging.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB58FD99F8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Logging.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB31D11CC2} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Logging.Debug.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB621C825E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3D1F2DD4} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Logging.EventLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB92D2348A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Logging.EventSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFB0EDA12} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9C1FC2D8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB764EE460} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.PlatformAbstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE4752E4A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB399FA00E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Identity.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFC02C575} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB046B25DA} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.IdentityModel.JsonWebTokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2771A01C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.IdentityModel.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9AF27936} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.IdentityModel.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3FF5EE81} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.IdentityModel.Protocols.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA6D6FD8F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.IdentityModel.Tokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2B2170F1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Rest.ClientRuntime.Azure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB63DE7E7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Rest.ClientRuntime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA5D4D281} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Microsoft.Win32.SystemEvents.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB07A526D9} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\NewId.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7BCE2101} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Newtonsoft.Json.Bson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB93E54F41} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Newtonsoft.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2E51E908} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\NLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD1F82D64} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\NLog.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4479CEDA} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\NLog.Targets.ElasticSearch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8A4CDB33} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\NLog.Web.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3FC9B724} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\RabbitMQ.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB328F2433} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\SixLabors.Fonts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFA9EA167} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\SixLabors.ImageSharp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9D2CEAA8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\SixLabors.ImageSharp.Drawing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB021D8294} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\SkiDiveCode.Ldap.Rfc2253.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7E0BEFBF} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\SQLitePCLRaw.batteries_v2.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF28410BB} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\SQLitePCLRaw.core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB132274EF} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\SQLitePCLRaw.nativelibrary.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB067A8EF0} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\SQLitePCLRaw.provider.dynamic_cdecl.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB220CAE3F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.ComponentModel.Annotations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB28E24AE3} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.Configuration.ConfigurationManager.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA50269F3} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB774C4D1C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF783BFD1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3FA89B6E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.DirectoryServices.AccountManagement.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB98AD0D04} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.DirectoryServices.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF1E6DB49} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.DirectoryServices.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFF8E7ADB} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.Drawing.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6BD860FC} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.IdentityModel.Tokens.Jwt.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6F486E29} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.IO.FileSystem.AccessControl.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB31150EC9} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF47C8EDF} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.Runtime.CompilerServices.Unsafe.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF1CEC637} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.Security.AccessControl.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3FD699A1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBADD39A79} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.Security.Permissions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB60219EB3} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.Security.Principal.Windows.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB76F2BA87} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.Text.Encodings.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB55EE7472} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.Text.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4CEBE23E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.Threading.Channels.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6381A604} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\System.Windows.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB62D6D056} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Migrations\SqlScripts\RefreshTokenMigration.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCB323191} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Migrations\SqlScripts\RenameAuthenticationSettingsTable.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDFA4B2FC} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Migrations\SqlScripts\UpdateHubAndInteractClients.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9A1E0FD8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Migrations\SqlScripts\UpdateHubAndInteractClientsDown.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB13CBD6E1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\alpine-x64\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7FCD5F76} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\linux\lib\netcoreapp2.0\System.DirectoryServices.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA46C3095} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\linux-arm\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF9A9E68C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\linux-arm64\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA6779818} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\linux-armel\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB75D81A30} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\linux-musl-x64\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4F2B19CE} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\linux-x64\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8C51B670} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\linux-x86\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEBB5B04C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\osx\lib\netcoreapp2.0\System.DirectoryServices.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB76F1D811} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\osx-x64\native\libe_sqlite3.dylib
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB28E037E7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\unix\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9069EBA3} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\unix\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1B586A7E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\unix\lib\netcoreapp2.1\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB46767B85} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\unix\lib\netcoreapp2.1\System.Security.Principal.Windows.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB43F80A8A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\unix\lib\netcoreapp3.0\System.Drawing.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0F5AA1BC} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.0\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB076D364F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.0\System.DirectoryServices.AccountManagement.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD3A2C0B0} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.0\System.DirectoryServices.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB13000B66} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.0\System.DirectoryServices.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9D17CF33} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF95BCC67} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.0\System.Security.AccessControl.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC9623022} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB33406A67} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.1\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8E97CE92} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.1\System.Security.Principal.Windows.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB59FFBAA} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp3.0\Microsoft.Win32.SystemEvents.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB587C2DFD} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp3.0\System.Drawing.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9DF3A8CF} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp3.0\System.Windows.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0FB43EEE} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netstandard2.0\System.IO.FileSystem.AccessControl.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5F3AA26E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netstandard2.0\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBECA4F2D2} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win-arm\native\e_sqlite3.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1E8295C5} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win-arm64\native\e_sqlite3.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB100808E9} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win-arm64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5887B8FA} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win-x64\native\e_sqlite3.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB344F70F6} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win-x64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA5B10753} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win-x86\native\e_sqlite3.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB47FDBC82} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win-x86\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBAF182A1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Scripts\Cache\[Cache]-001-Table-Cache-Create.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0B32BF8F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\pl\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAEF3F504} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\pl\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB84687577} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\pl\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3D54920F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\pl\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEF438E8A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\pt-BR\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB641C54DE} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\pt-BR\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8DEF94AF} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\pt-BR\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBE2C105A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\pt-BR\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB26D10A70} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ru\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB16C5E34E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ru\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB63D28961} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ru\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA786F2BA} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ru\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB096517B4} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ru\Microsoft.Data.Edm.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB78DF9648} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ru\Microsoft.Data.OData.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF9D3ADB8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\ru\System.Spatial.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB25346078} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\alpine-x64\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD5F0C29A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\linux\lib\netcoreapp2.0\System.DirectoryServices.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD174D596} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\linux-arm\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE997BCB8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\linux-arm64\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6DC01968} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\linux-armel\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB707AA444} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\linux-musl-x64\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB66B5DB9B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\linux-x64\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB612ACE8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\linux-x86\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB87211B49} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\osx\lib\netcoreapp2.0\System.DirectoryServices.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3AC017ED} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\osx-x64\native\libe_sqlite3.dylib
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCA3C53A7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\unix\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB58C9D4E5} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\unix\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8670D4B1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\unix\lib\netcoreapp2.1\System.Security.Principal.Windows.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEFB15EB7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\unix\lib\netcoreapp3.0\System.Drawing.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA821283F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp2.0\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5FFE2ECE} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp2.0\System.DirectoryServices.AccountManagement.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7140300D} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp2.0\System.DirectoryServices.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD9054116} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp2.0\System.DirectoryServices.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB978EE8E4} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC7BCECA0} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp2.0\System.Security.AccessControl.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8A4CDEBE} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE40BFF3E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp2.1\System.Security.Principal.Windows.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8D565FE9} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp3.0\Microsoft.Win32.SystemEvents.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7EF87CF0} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp3.0\System.Drawing.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0516804B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp3.0\System.Windows.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCA30896D} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netstandard2.0\System.IO.FileSystem.AccessControl.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA1038B51} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netstandard2.0\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB40324532} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win-arm\native\e_sqlite3.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB54454A94} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win-arm64\native\e_sqlite3.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0D09286B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win-arm64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE86A87F1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win-x64\native\e_sqlite3.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB791B31D6} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win-x64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7DB2898A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win-x86\native\e_sqlite3.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5B2C5EC4} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win-x86\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF43F1E9F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\tr\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9E7BA304} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\tr\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3C062CDB} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\tr\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC77EF2DE} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\tr\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA80EFBFB} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\asset-manifest.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB15D6AD92} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\favicon.ico
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBACD96A43} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\ims.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6FFDE0AF} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\index.html
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB76F97ED3} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\precache-manifest.5d0155ae2e2b0a02a86b7a45531a4c20.js
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3E339263} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\service-worker.js
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9FF36B7E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\css\swagger_custom_style.css
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE4A75C17} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\auth-server\de\auth-server-de.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE5C5102F} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\auth-server\en\auth-server-en.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFB878D75} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\auth-server\es\auth-server-es.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA53FB649} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\auth-server\fr\auth-server-fr.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB64DAD0B5} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\auth-server\ja\auth-server-ja.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1669DBD8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\auth-server\pt\auth-server-pt.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB628ED075} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\auth-server\ru\auth-server-ru.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4F700735} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\auth-server\zh\auth-server-zh.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB962AC285} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\common\de\common-de.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF3CA84EC} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\common\en\common-en.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB57E0C561} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\common\es\common-es.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC7FC8E55} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\common\fr\common-fr.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB03AC4833} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\common\ja\common-ja.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1D8E0AF8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\common\pt\common-pt.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB903789A2} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\common\ru\common-ru.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0DF06A4B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\common\zh\common-zh.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB93F033C7} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\css\2.a1570274.chunk.css
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB560521D8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\css\2.a1570274.chunk.css.map
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA92E4C5C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\css\main.fab92ab7.chunk.css
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB54552A65} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\css\main.fab92ab7.chunk.css.map
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0E0BDFD9} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\js\2.a9e6f5ab.chunk.js
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCA541B5A} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\js\2.a9e6f5ab.chunk.js.LICENSE.txt
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB412EDB50} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\js\2.a9e6f5ab.chunk.js.map
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB06C8C532} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\js\main.db03a044.chunk.js
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1E435E86} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\js\main.db03a044.chunk.js.map
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8C7FEF5E} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\js\runtime-main.88d2a8d5.js
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFC2A0CC3} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\js\runtime-main.88d2a8d5.js.map
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6C4F6918} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\media\KintoSans-Bold.31112dfb.woff2
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFA13C598} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\media\KintoSans-Regular.377fc131.woff2
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB53C887D0} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\media\login.422d7535.svg
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB22323CAB} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\media\logo_sq.fb35e635.png
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB81E5723B} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\media\Roboto-Bold.f712717c.woff2
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5DE10A23} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\media\Roboto-Regular.51095fe9.woff2
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA431EF18} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\media\upload.bb2875a3.svg
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB87BD52F6} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hans\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3A83BBD1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hans\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFDD5F5A2} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hans\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB53B082A1} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hans\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6EDB63AC} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hans\Microsoft.Data.Edm.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1D03D2AB} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hans\Microsoft.Data.OData.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8C14522C} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hans\System.Spatial.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCCF044E8} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hant\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD40FBF91} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hant\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAB25CDAE} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hant\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2F143F29} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hant\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB73423538} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hant\Microsoft.Data.Edm.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAE4D2151} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hant\Microsoft.Data.OData.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8ECBD3EC} 3: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hant\System.Spatial.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAD217C34} 3: C:\Program Files (x86)\Blue Prism\Email Service\appsettings.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB748C2D02} 3: C:\Program Files (x86)\Blue Prism\Email Service\Automatonymous.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB308FD2C3} 3: C:\Program Files (x86)\Blue Prism\Email Service\Azure.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD4F19669} 3: C:\Program Files (x86)\Blue Prism\Email Service\Azure.Monitor.OpenTelemetry.Exporter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5AEE8074} 3: C:\Program Files (x86)\Blue Prism\Email Service\BouncyCastle.Crypto.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB054B7E1E} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.EmailService.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB641B7365} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.EmailService.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB015390EF} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.EmailService.Data.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB71455552} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.EmailService.Logic.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE520C6A0} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.EmailService.Messages.Commands.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA04EFED0} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.EmailService.Web.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8088F4EF} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.EmailService.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB53D092C3} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.EmailService.Web.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB52A2D5D2} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.EmailService.Web.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB38CC5712} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB99032067} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.Extensions.Middleware.ExceptionHandler.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6393A39B} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.Extensions.Tasks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB96488F37} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.Extensions.Telemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB97C42AA8} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.Logger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB0B6D890} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.Messaging.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2F61439E} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.SettingsProtection.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBADCD119} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.SettingsProtection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB64ED042B} 3: C:\Program Files (x86)\Blue Prism\Email Service\BPC.SettingsProtection.Services.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0E4EB713} 3: C:\Program Files (x86)\Blue Prism\Email Service\Dapper.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB799FE6B7} 3: C:\Program Files (x86)\Blue Prism\Email Service\Elasticsearch.Net.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6B7E5604} 3: C:\Program Files (x86)\Blue Prism\Email Service\FluentValidation.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB798E020C} 3: C:\Program Files (x86)\Blue Prism\Email Service\FluentValidation.DependencyInjectionExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB046153C8} 3: C:\Program Files (x86)\Blue Prism\Email Service\FluentValidation.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2D10754E} 3: C:\Program Files (x86)\Blue Prism\Email Service\Google.Protobuf.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFD086612} 3: C:\Program Files (x86)\Blue Prism\Email Service\GreenPipes.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8FF03ABF} 3: C:\Program Files (x86)\Blue Prism\Email Service\Grpc.Core.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBB7C50A5} 3: C:\Program Files (x86)\Blue Prism\Email Service\Grpc.Net.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF04257F2} 3: C:\Program Files (x86)\Blue Prism\Email Service\Grpc.Net.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB74F0BC07} 3: C:\Program Files (x86)\Blue Prism\Email Service\HealthChecks.IdSvr.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1DD88EB5} 3: C:\Program Files (x86)\Blue Prism\Email Service\HealthChecks.RabbitMQ.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFF2DCD8E} 3: C:\Program Files (x86)\Blue Prism\Email Service\HealthChecks.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE8939336} 3: C:\Program Files (x86)\Blue Prism\Email Service\MailKit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3F9B7D70} 3: C:\Program Files (x86)\Blue Prism\Email Service\MassTransit.AspNetCoreIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB33C60B14} 3: C:\Program Files (x86)\Blue Prism\Email Service\MassTransit.Azure.ServiceBus.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC826474B} 3: C:\Program Files (x86)\Blue Prism\Email Service\MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC88E52EB} 3: C:\Program Files (x86)\Blue Prism\Email Service\MassTransit.ExtensionsDependencyInjectionIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA1715AE3} 3: C:\Program Files (x86)\Blue Prism\Email Service\MassTransit.Platform.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0E2D8B4C} 3: C:\Program Files (x86)\Blue Prism\Email Service\MassTransit.RabbitMqTransport.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC993B983} 3: C:\Program Files (x86)\Blue Prism\Email Service\MassTransit.SignalR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC5AC3D3D} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.AI.DependencyCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB247EE704} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.AI.EventCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4FA4788F} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.AI.PerfCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9CBEA7F0} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.AI.ServerTelemetryChannel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6E7C7D7E} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.AI.WindowsServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB583347B7} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.ApplicationInsights.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1C9B5468} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB10CB8F59} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.ApplicationInsights.NLogTarget.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB639E5CA4} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.AspNetCore.Authentication.JwtBearer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE0EE9E49} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.AspNetCore.Authentication.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE36B614C} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.AspNetCore.JsonPatch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE44E0B7B} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.AspNetCore.Mvc.NewtonsoftJson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6B028027} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Azure.Amqp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2B2AEB8A} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Azure.KeyVault.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB63868698} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Azure.KeyVault.WebKey.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB241BFF00} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Azure.ServiceBus.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE2C3C59F} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB017F8EDE} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Bcl.AsyncInterfaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFCF4A995} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB363B8CB3} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB15BDD51A} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE5607413} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7EDCB049} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB67949C0E} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7F425C10} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1B55E7D8} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Extensions.Diagnostics.HealthChecks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6DAB95CD} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Extensions.FileProviders.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5D661657} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Extensions.Hosting.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB802ECB90} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Extensions.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5C9A7266} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6E378DB2} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Extensions.Logging.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4C4E8402} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF8A35368} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDF9AA334} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDDFA5B9B} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFEAB9F4B} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Graph.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3AD38886} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Graph.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF449E536} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Identity.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC276829C} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0F8CA582} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF38BD885} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.IdentityModel.JsonWebTokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB18C496B5} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.IdentityModel.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6DA58F4E} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.IdentityModel.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB33276F7F} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.IdentityModel.Protocols.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4DF12FFD} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.IdentityModel.Tokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB90730D87} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Rest.ClientRuntime.Azure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB309CAE82} 3: C:\Program Files (x86)\Blue Prism\Email Service\Microsoft.Rest.ClientRuntime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB23B6EEDC} 3: C:\Program Files (x86)\Blue Prism\Email Service\MimeKit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB232FD892} 3: C:\Program Files (x86)\Blue Prism\Email Service\NewId.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB08A60289} 3: C:\Program Files (x86)\Blue Prism\Email Service\Newtonsoft.Json.Bson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB516CA6F} 3: C:\Program Files (x86)\Blue Prism\Email Service\Newtonsoft.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1688ABEF} 3: C:\Program Files (x86)\Blue Prism\Email Service\Nito.AsyncEx.Coordination.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4C8FF540} 3: C:\Program Files (x86)\Blue Prism\Email Service\Nito.AsyncEx.Tasks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB04DEECAB} 3: C:\Program Files (x86)\Blue Prism\Email Service\Nito.Collections.Deque.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7B2E86DB} 3: C:\Program Files (x86)\Blue Prism\Email Service\Nito.Disposables.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB932DA32E} 3: C:\Program Files (x86)\Blue Prism\Email Service\NLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB22034965} 3: C:\Program Files (x86)\Blue Prism\Email Service\NLog.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCADC591B} 3: C:\Program Files (x86)\Blue Prism\Email Service\NLog.Targets.ElasticSearch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9A7FE3B8} 3: C:\Program Files (x86)\Blue Prism\Email Service\NLog.Web.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC0B16B7F} 3: C:\Program Files (x86)\Blue Prism\Email Service\NWebsec.AspNetCore.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB390FB5AE} 3: C:\Program Files (x86)\Blue Prism\Email Service\NWebsec.AspNetCore.Middleware.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1C4663D8} 3: C:\Program Files (x86)\Blue Prism\Email Service\OpenTelemetry.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB582E9EBF} 3: C:\Program Files (x86)\Blue Prism\Email Service\OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1EA50BAD} 3: C:\Program Files (x86)\Blue Prism\Email Service\OpenTelemetry.Contrib.Instrumentation.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFF65D611} 3: C:\Program Files (x86)\Blue Prism\Email Service\OpenTelemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBAC48EAB} 3: C:\Program Files (x86)\Blue Prism\Email Service\OpenTelemetry.Exporter.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB56E4B5D0} 3: C:\Program Files (x86)\Blue Prism\Email Service\OpenTelemetry.Exporter.Jaeger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2FFC32E2} 3: C:\Program Files (x86)\Blue Prism\Email Service\OpenTelemetry.Exporter.OpenTelemetryProtocol.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB294FA9C4} 3: C:\Program Files (x86)\Blue Prism\Email Service\OpenTelemetry.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6F47329A} 3: C:\Program Files (x86)\Blue Prism\Email Service\OpenTelemetry.Instrumentation.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAA23042A} 3: C:\Program Files (x86)\Blue Prism\Email Service\OpenTelemetry.Instrumentation.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE3E784E6} 3: C:\Program Files (x86)\Blue Prism\Email Service\OpenTelemetry.Instrumentation.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD8AB4726} 3: C:\Program Files (x86)\Blue Prism\Email Service\RabbitMQ.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA8B9105E} 3: C:\Program Files (x86)\Blue Prism\Email Service\System.Configuration.ConfigurationManager.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1E0E1FF9} 3: C:\Program Files (x86)\Blue Prism\Email Service\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE125D1A7} 3: C:\Program Files (x86)\Blue Prism\Email Service\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD3C3BE9E} 3: C:\Program Files (x86)\Blue Prism\Email Service\System.IdentityModel.Tokens.Jwt.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF21DE276} 3: C:\Program Files (x86)\Blue Prism\Email Service\System.Memory.Data.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB99874C1} 3: C:\Program Files (x86)\Blue Prism\Email Service\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEC3B33CD} 3: C:\Program Files (x86)\Blue Prism\Email Service\System.Runtime.CompilerServices.Unsafe.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2D851C6A} 3: C:\Program Files (x86)\Blue Prism\Email Service\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0C578C02} 3: C:\Program Files (x86)\Blue Prism\Email Service\System.Text.Encodings.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF5CB18D7} 3: C:\Program Files (x86)\Blue Prism\Email Service\System.Text.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3F84B9C3} 3: C:\Program Files (x86)\Blue Prism\Email Service\System.Threading.Channels.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8B16C389} 3: C:\Program Files (x86)\Blue Prism\Email Service\web.config
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC3F8F34E} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\BPC.EmailService.Migrator.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB77DBD4CC} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\BPC.EmailService.Migrator.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB649BA4A1} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\BPC.EmailService.Migrator.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFB9F5E86} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\BPC.EmailService.Migrator.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBED19836F} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\CommandLine.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB58077D0} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\dbup-core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB591B7A98} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\dbup-sqlserver.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE94769AF} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\MediatR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB844B89A6} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\MediatR.Extensions.Microsoft.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB06B83481} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3CA215F2} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB44861860} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB54238526} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB01F02AAC} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDF05D563} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB67E2B718} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB96CD61DA} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\Microsoft.Extensions.Logging.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4925F551} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\Microsoft.Extensions.Logging.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD8F5C68D} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2A57F934} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE77805ED} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4383287D} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB27740C38} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB632723D5} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4C479A1A} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1A35EF86} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\System.Text.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF62FAED0} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\runtimes\unix\lib\netcoreapp2.1\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCF1240D9} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\runtimes\win\lib\netcoreapp2.1\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5180F3A9} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\runtimes\win-arm64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE86A1EFA} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\runtimes\win-x64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2FE14124} 3: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\runtimes\win-x86\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB048F8639} 3: C:\Program Files (x86)\Blue Prism\Email Service\Resources\Emails\TestEmailBody.html
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5BEB42C5} 3: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\unix\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB35416D16} 3: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\unix\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB63BF5B11} 3: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\win\lib\netcoreapp2.0\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB46D3C132} 3: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\win\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB11634430} 3: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\win\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB07A077F2} 3: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\win\lib\netstandard2.0\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB554B5E4B} 3: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\win-arm64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE7FDDCB3} 3: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\win-x64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB74037653} 3: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\win-x86\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF130E1BC} 3: C:\Program Files (x86)\Blue Prism\Email Service\Scripts\Senders\AddEmailSender.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB09C2BC91} 3: C:\Program Files (x86)\Blue Prism\Email Service\Scripts\Senders\GetEmailSender.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB70B780E8} 3: C:\Program Files (x86)\Blue Prism\Email Service\Scripts\Senders\RemoveAllEmailSenders.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB39E5DC0F} 3: C:\Program Files (x86)\Blue Prism\File Service\appsettings.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7921A7BA} 3: C:\Program Files (x86)\Blue Prism\File Service\Automatonymous.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB617E307C} 3: C:\Program Files (x86)\Blue Prism\File Service\Azure.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC1DC47ED} 3: C:\Program Files (x86)\Blue Prism\File Service\Azure.Monitor.OpenTelemetry.Exporter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9E53AE67} 3: C:\Program Files (x86)\Blue Prism\File Service\BPC.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB50A1259A} 3: C:\Program Files (x86)\Blue Prism\File Service\BPC.Extensions.Middleware.ExceptionHandler.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1509E0C8} 3: C:\Program Files (x86)\Blue Prism\File Service\BPC.Extensions.Telemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB606D1B11} 3: C:\Program Files (x86)\Blue Prism\File Service\BPC.FileStorage.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1DCF42FA} 3: C:\Program Files (x86)\Blue Prism\File Service\BPC.FileStorageApi.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB26C2F219} 3: C:\Program Files (x86)\Blue Prism\File Service\BPC.FileStorageApi.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB99B5D25E} 3: C:\Program Files (x86)\Blue Prism\File Service\BPC.FileStorageApi.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB39D2AD15} 3: C:\Program Files (x86)\Blue Prism\File Service\BPC.FileStorageApi.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB50F3EA01} 3: C:\Program Files (x86)\Blue Prism\File Service\BPC.Logger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB57D03914} 3: C:\Program Files (x86)\Blue Prism\File Service\BPC.SettingsProtection.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFF69BC84} 3: C:\Program Files (x86)\Blue Prism\File Service\BPC.SettingsProtection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1297BC0E} 3: C:\Program Files (x86)\Blue Prism\File Service\BPC.SettingsProtection.Services.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF957983D} 3: C:\Program Files (x86)\Blue Prism\File Service\dotnet-aspnet-codegenerator-design.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB49811B49} 3: C:\Program Files (x86)\Blue Prism\File Service\Elasticsearch.Net.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2AF6DE27} 3: C:\Program Files (x86)\Blue Prism\File Service\Google.Protobuf.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB88F00101} 3: C:\Program Files (x86)\Blue Prism\File Service\GreenPipes.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB806B674C} 3: C:\Program Files (x86)\Blue Prism\File Service\Grpc.Core.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDE1FD122} 3: C:\Program Files (x86)\Blue Prism\File Service\Grpc.Net.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB6652F4B} 3: C:\Program Files (x86)\Blue Prism\File Service\Grpc.Net.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB30E71B2D} 3: C:\Program Files (x86)\Blue Prism\File Service\HealthChecks.IdSvr.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5720D2FB} 3: C:\Program Files (x86)\Blue Prism\File Service\IdentityModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB78879C5C} 3: C:\Program Files (x86)\Blue Prism\File Service\MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB61352842} 3: C:\Program Files (x86)\Blue Prism\File Service\MassTransit.ExtensionsDependencyInjectionIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFF3043B4} 3: C:\Program Files (x86)\Blue Prism\File Service\MassTransit.Platform.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3DFF293C} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.AI.DependencyCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE31B7043} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.AI.EventCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB718942C3} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.AI.PerfCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3D28F3A7} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.AI.ServerTelemetryChannel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9A48770A} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.AI.WindowsServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB23A8060F} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.ApplicationInsights.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8D452A71} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC64B2E89} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.ApplicationInsights.NLogTarget.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD6EFA0E3} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.AspNetCore.Authentication.JwtBearer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB070C2509} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.AspNetCore.Authentication.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB37C56F13} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.AspNetCore.JsonPatch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBC89E138} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.AspNetCore.Mvc.Razor.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB303B8D36} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.AspNetCore.Razor.Language.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6EE76CFD} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Azure.KeyVault.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCAFD2455} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Azure.KeyVault.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB47C79AB3} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Azure.KeyVault.WebKey.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB826671F8} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE2AD6509} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Azure.Storage.Blob.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB223B1BC1} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Azure.Storage.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDE869B9F} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Bcl.AsyncInterfaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB58122029} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Bcl.HashCode.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2DB90A68} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.CodeAnalysis.CSharp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDB407174} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.CodeAnalysis.CSharp.Workspaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE19E0F80} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.CodeAnalysis.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAE702A31} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.CodeAnalysis.Razor.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8C58B60E} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.CodeAnalysis.Workspaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB77994B1D} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEFA7A503} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.EntityFrameworkCore.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9BDA953C} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB14016F61} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.EntityFrameworkCore.Relational.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8AC0F2AE} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.EntityFrameworkCore.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB859655DC} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Caching.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC4E542AE} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Caching.Memory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC780521E} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9D20EE18} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA4B5C82E} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Configuration.CommandLine.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB0EA8F4F} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD8AB7111} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Configuration.EnvironmentVariables.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB60D96FF7} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Configuration.FileExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9401C96F} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Configuration.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB15EB5473} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Configuration.UserSecrets.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2260F107} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBDC50410} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFE90E856} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.DependencyModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB959AFACE} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAFD835E1} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Diagnostics.HealthChecks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAA6E9DDF} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.FileProviders.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6DE6A381} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.FileProviders.Physical.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0651173E} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.FileSystemGlobbing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB58FFAC45} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Hosting.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC344166B} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC1F2434D} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD7015A85} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBD45F259} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Logging.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6C2D3D45} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Logging.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB79278780} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Logging.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB794B9FB3} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Logging.Debug.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8D5872B4} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0E02B7BC} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Logging.EventLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB952F9F2D} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Logging.EventSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8B5D5100} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFFBD37D8} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA655A37C} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7471DA15} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Identity.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8758167F} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0C890C72} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB01F203DA} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.IdentityModel.JsonWebTokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9964ED40} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.IdentityModel.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC41F5197} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.IdentityModel.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE1ECEA60} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.IdentityModel.Protocols.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDC433932} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.IdentityModel.Tokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE652D959} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Rest.ClientRuntime.Azure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFB13B348} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.Rest.ClientRuntime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF3711FE3} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.VisualStudio.Web.CodeGeneration.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2322ADA1} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.VisualStudio.Web.CodeGeneration.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB585EDA45} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.VisualStudio.Web.CodeGeneration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE1155D3F} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.VisualStudio.Web.CodeGeneration.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB7C7815C} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.VisualStudio.Web.CodeGeneration.Templating.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB51C2A8F1} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.VisualStudio.Web.CodeGeneration.Utils.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4BC31E3B} 3: C:\Program Files (x86)\Blue Prism\File Service\Microsoft.VisualStudio.Web.CodeGenerators.Mvc.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB68576B08} 3: C:\Program Files (x86)\Blue Prism\File Service\NewId.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFE9C5C71} 3: C:\Program Files (x86)\Blue Prism\File Service\Newtonsoft.Json.Bson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB333361A1} 3: C:\Program Files (x86)\Blue Prism\File Service\Newtonsoft.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA2EED482} 3: C:\Program Files (x86)\Blue Prism\File Service\NLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE90F0EC1} 3: C:\Program Files (x86)\Blue Prism\File Service\NLog.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB02345BD4} 3: C:\Program Files (x86)\Blue Prism\File Service\NLog.Targets.ElasticSearch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9C2E7790} 3: C:\Program Files (x86)\Blue Prism\File Service\NLog.Web.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5FA85F5F} 3: C:\Program Files (x86)\Blue Prism\File Service\NuGet.Frameworks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB46F10B0E} 3: C:\Program Files (x86)\Blue Prism\File Service\NWebsec.AspNetCore.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB73E22DB4} 3: C:\Program Files (x86)\Blue Prism\File Service\NWebsec.AspNetCore.Middleware.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC6BAD6F2} 3: C:\Program Files (x86)\Blue Prism\File Service\OpenTelemetry.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB025EAC44} 3: C:\Program Files (x86)\Blue Prism\File Service\OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE117E75C} 3: C:\Program Files (x86)\Blue Prism\File Service\OpenTelemetry.Contrib.Instrumentation.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB31B61ACA} 3: C:\Program Files (x86)\Blue Prism\File Service\OpenTelemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB06AF48B2} 3: C:\Program Files (x86)\Blue Prism\File Service\OpenTelemetry.Exporter.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3529E6CA} 3: C:\Program Files (x86)\Blue Prism\File Service\OpenTelemetry.Exporter.Jaeger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB37080DB8} 3: C:\Program Files (x86)\Blue Prism\File Service\OpenTelemetry.Exporter.OpenTelemetryProtocol.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB27995F8C} 3: C:\Program Files (x86)\Blue Prism\File Service\OpenTelemetry.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB979D0A9D} 3: C:\Program Files (x86)\Blue Prism\File Service\OpenTelemetry.Instrumentation.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA16DFC4C} 3: C:\Program Files (x86)\Blue Prism\File Service\OpenTelemetry.Instrumentation.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAB373C20} 3: C:\Program Files (x86)\Blue Prism\File Service\OpenTelemetry.Instrumentation.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA69442FF} 3: C:\Program Files (x86)\Blue Prism\File Service\Scrutor.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB73DC0C21} 3: C:\Program Files (x86)\Blue Prism\File Service\SixLabors.Fonts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAC850847} 3: C:\Program Files (x86)\Blue Prism\File Service\SixLabors.ImageSharp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFB56C506} 3: C:\Program Files (x86)\Blue Prism\File Service\SixLabors.ImageSharp.Drawing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB215A1F62} 3: C:\Program Files (x86)\Blue Prism\File Service\System.Composition.AttributedModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4D542941} 3: C:\Program Files (x86)\Blue Prism\File Service\System.Composition.Convention.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB592D9F9} 3: C:\Program Files (x86)\Blue Prism\File Service\System.Composition.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4BA47D01} 3: C:\Program Files (x86)\Blue Prism\File Service\System.Composition.Runtime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB85E81116} 3: C:\Program Files (x86)\Blue Prism\File Service\System.Composition.TypedParts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDDEBFCAD} 3: C:\Program Files (x86)\Blue Prism\File Service\System.Configuration.ConfigurationManager.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4DF84960} 3: C:\Program Files (x86)\Blue Prism\File Service\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC7E86828} 3: C:\Program Files (x86)\Blue Prism\File Service\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB35480BCC} 3: C:\Program Files (x86)\Blue Prism\File Service\System.IdentityModel.Tokens.Jwt.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB113C888C} 3: C:\Program Files (x86)\Blue Prism\File Service\System.Memory.Data.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA5237EF2} 3: C:\Program Files (x86)\Blue Prism\File Service\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9479A35E} 3: C:\Program Files (x86)\Blue Prism\File Service\System.Runtime.CompilerServices.Unsafe.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE0DA7132} 3: C:\Program Files (x86)\Blue Prism\File Service\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB12BAD948} 3: C:\Program Files (x86)\Blue Prism\File Service\System.Text.Encodings.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF62EC445} 3: C:\Program Files (x86)\Blue Prism\File Service\System.Text.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB151C9530} 3: C:\Program Files (x86)\Blue Prism\File Service\System.Threading.Channels.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB286F9D98} 3: C:\Program Files (x86)\Blue Prism\File Service\Web.config
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB526052F3} 3: C:\Program Files (x86)\Blue Prism\File Service\cs\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBC70D0EE} 3: C:\Program Files (x86)\Blue Prism\File Service\cs\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB292E6115} 3: C:\Program Files (x86)\Blue Prism\File Service\cs\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB86D51ECE} 3: C:\Program Files (x86)\Blue Prism\File Service\cs\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9409E8FA} 3: C:\Program Files (x86)\Blue Prism\File Service\de\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB13A013C8} 3: C:\Program Files (x86)\Blue Prism\File Service\de\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB231F01F4} 3: C:\Program Files (x86)\Blue Prism\File Service\de\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB988662F3} 3: C:\Program Files (x86)\Blue Prism\File Service\de\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8570F4CE} 3: C:\Program Files (x86)\Blue Prism\File Service\es\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3E7C3B72} 3: C:\Program Files (x86)\Blue Prism\File Service\es\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB8EA6C25} 3: C:\Program Files (x86)\Blue Prism\File Service\es\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9DCF4DEA} 3: C:\Program Files (x86)\Blue Prism\File Service\es\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB026D83D} 3: C:\Program Files (x86)\Blue Prism\File Service\fr\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB97C6D77A} 3: C:\Program Files (x86)\Blue Prism\File Service\fr\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBDF913FA} 3: C:\Program Files (x86)\Blue Prism\File Service\fr\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFFC66299} 3: C:\Program Files (x86)\Blue Prism\File Service\fr\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6DAF0D1F} 3: C:\Program Files (x86)\Blue Prism\File Service\it\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB09809E66} 3: C:\Program Files (x86)\Blue Prism\File Service\it\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2056A81E} 3: C:\Program Files (x86)\Blue Prism\File Service\it\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCC448516} 3: C:\Program Files (x86)\Blue Prism\File Service\it\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4713782F} 3: C:\Program Files (x86)\Blue Prism\File Service\ja\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD4E50506} 3: C:\Program Files (x86)\Blue Prism\File Service\ja\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEB7208DA} 3: C:\Program Files (x86)\Blue Prism\File Service\ja\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB599D7803} 3: C:\Program Files (x86)\Blue Prism\File Service\ja\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB51F9BE51} 3: C:\Program Files (x86)\Blue Prism\File Service\ko\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF104A6FA} 3: C:\Program Files (x86)\Blue Prism\File Service\ko\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7EC5E544} 3: C:\Program Files (x86)\Blue Prism\File Service\ko\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9943A6E7} 3: C:\Program Files (x86)\Blue Prism\File Service\ko\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB739CA316} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Azure.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8A148817} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Azure.Identity.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB26723D27} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\BPC.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9A55D5AC} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\BPC.FileStorage.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB53D097E8} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\BPC.FileStorageApi.Migrator.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4BE8243D} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\BPC.FileStorageApi.Migrator.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEE1CAC53} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\BPC.FileStorageApi.Migrator.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB51E11656} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\BPC.FileStorageApi.Migrator.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2F3C2F42} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\CommandLine.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF3273193} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Dapper.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6807406C} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\dbup-core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB80E79B0} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\dbup-sqlserver.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5D89CE5B} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\IdentityModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB181C8FD2} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\MediatR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB63661DC7} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\MediatR.Extensions.Microsoft.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB956E1FF8} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Antiforgery.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB8A813AB} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Authentication.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBEFAF4A7} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Authentication.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3114A4E5} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Authorization.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB54C3320B} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Authorization.Policy.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB085C6427} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Cors.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC89F000A} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Cryptography.Internal.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1EDEF1F8} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.DataProtection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA2BB11BE} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.DataProtection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC7B0126E} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Diagnostics.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB31C0EA72} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Hosting.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1538D3DE} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Hosting.Server.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB5435A1F} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Html.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB40F3766C} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Http.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA5E7BE35} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB642582A8} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Http.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8D143D9E} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Http.Features.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB20DED625} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.JsonPatch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7B2A16D7} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Localization.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE2E3CCC9} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Mvc.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCFEDB952} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Mvc.ApiExplorer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0DC19329} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Mvc.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB596619B} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Mvc.Cors.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB32179F93} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Mvc.DataAnnotations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0DE4A3FC} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Mvc.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB01EFEE3D} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Mvc.Formatters.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB965FCB7E} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Mvc.Localization.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB74681775} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Mvc.Razor.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA6108A54} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Mvc.Razor.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3AEFEF09} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Mvc.RazorPages.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB76A4C9C0} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Mvc.TagHelpers.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB585F37FE} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Mvc.ViewFeatures.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE2362A51} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Razor.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB852D8ECE} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Razor.Language.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4F970CF6} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Razor.Runtime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD630116A} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.ResponseCaching.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8A01973A} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Routing.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4CA4CFE7} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.Routing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF38D80F4} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.AspNetCore.WebUtilities.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB652B2DEC} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Azure.KeyVault.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6624C377} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1960522E} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Azure.Storage.Blob.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEC0480FD} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Azure.Storage.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB01DC3253} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Bcl.AsyncInterfaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5DC5EC9D} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Bcl.HashCode.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB30D1125C} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.CodeAnalysis.CSharp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEA27250E} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.CodeAnalysis.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB154BAD24} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.CodeAnalysis.Razor.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7AF7A4DE} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6723BA26} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.DotNet.PlatformAbstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD71D5E74} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.EntityFrameworkCore.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB41075A22} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB04BC3694} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.EntityFrameworkCore.Relational.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1DB3FF93} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.EntityFrameworkCore.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEE5A831E} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Caching.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB11C192D8} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Caching.Memory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEB5D81D6} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB85AEFD03} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE504FF22} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Configuration.CommandLine.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC463ACFF} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB43E29BFE} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Configuration.EnvironmentVariables.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6BD9DE16} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Configuration.FileExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB555EFBDD} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Configuration.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB1C81EE3} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Configuration.UserSecrets.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCEFBAB87} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7ED40A65} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF62267B7} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.DependencyModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD07D4947} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.FileProviders.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE71C98BD} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.FileProviders.Composite.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB447306A0} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.FileProviders.Physical.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB94220072} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.FileSystemGlobbing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9194E997} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Hosting.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB377812BA} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1B83C6EF} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB711FA2CF} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Localization.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC2A3A290} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Localization.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD45E8AB0} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1EAA0D38} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Logging.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBF254F5D} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Logging.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBA37060B} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Logging.Debug.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1688FF08} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEF7C4C80} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Logging.EventLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1B2074CC} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Logging.EventSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBECBE696} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.ObjectPool.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB79E4163} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB1E6BC63} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB61401DD0} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAE369A2C} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Extensions.WebEncoders.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB68840FE2} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Identity.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEC2A5794} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Identity.Client.Extensions.Msal.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCE9107B5} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8DD840FE} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.IdentityModel.JsonWebTokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0E4D2F3D} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.IdentityModel.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB78B84A7} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.IdentityModel.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA5F8961D} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.IdentityModel.Protocols.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7DEB99AE} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.IdentityModel.Tokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1E683794} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Net.Http.Headers.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBADAC6364} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Microsoft.Win32.SystemEvents.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB87A45C87} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Newtonsoft.Json.Bson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA43B103B} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Newtonsoft.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBD27E99F} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\SixLabors.Fonts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF8458B9F} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\SixLabors.ImageSharp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB53C08B8A} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\SixLabors.ImageSharp.Drawing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB480EC20} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\System.Configuration.ConfigurationManager.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB57FB492D} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD64AF486} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB759F2843} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\System.Diagnostics.EventLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB65F254C5} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\System.Drawing.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB37788AD9} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\System.IdentityModel.Tokens.Jwt.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBADB7895D} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\System.Resources.NetStandard.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB09142DE3} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1F3995A1} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\System.Security.Cryptography.Pkcs.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB641AC8A7} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6A110782} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\System.Security.Cryptography.Xml.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC00BF5AC} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\System.Security.Permissions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4F61AED0} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\System.Text.Encodings.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC151AF12} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\System.Text.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB85AA12FE} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\System.Windows.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD51BD77F} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\unix\lib\netcoreapp2.1\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5C497D50} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\unix\lib\netcoreapp3.0\System.Drawing.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB37B9A785} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\unix\lib\netcoreapp3.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7A60DE3E} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netcoreapp2.0\System.Diagnostics.EventLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB805570D3} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netcoreapp2.1\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2D99305E} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netcoreapp2.1\System.Security.Cryptography.Pkcs.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFF538EDC} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netcoreapp3.0\Microsoft.Win32.SystemEvents.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCF519D33} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netcoreapp3.0\System.Drawing.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE5E0DF26} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netcoreapp3.0\System.Windows.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC2D89891} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netcoreapp3.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB8BD8A27} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netstandard2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA7F41D4C} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netstandard2.0\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF50DD26F} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win-arm\native\Microsoft.Data.SqlClient.SNI.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB566B5AEC} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win-arm64\native\Microsoft.Data.SqlClient.SNI.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5BCED3FC} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win-arm64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCDFE6228} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win-x64\native\Microsoft.Data.SqlClient.SNI.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7C3E0A27} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win-x64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9E3349AC} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win-x86\native\Microsoft.Data.SqlClient.SNI.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6A0F9B4D} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win-x86\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB960BAA37} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Scripts\[Cache]-001-Table-Cache-Create.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC4D1071B} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Scripts\[Files]-001-Table-Files-Create.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC4FEFC51} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Scripts\[Files]-002-Set-Unique-To-Column-Ident-Of-Table-Files.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6B048BF7} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Scripts\Single\AddFile.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB72A4BDE8} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Scripts\Single\IsFileByPurposeExisted.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBBEA548C} 3: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Scripts\Single\SelectExistedIdents.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA7EF91B2} 3: C:\Program Files (x86)\Blue Prism\File Service\pl\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB42F15AB2} 3: C:\Program Files (x86)\Blue Prism\File Service\pl\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB99569F8C} 3: C:\Program Files (x86)\Blue Prism\File Service\pl\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB33BF068C} 3: C:\Program Files (x86)\Blue Prism\File Service\pl\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBADE9B728} 3: C:\Program Files (x86)\Blue Prism\File Service\pt-BR\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3AB67756} 3: C:\Program Files (x86)\Blue Prism\File Service\pt-BR\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA08E66B9} 3: C:\Program Files (x86)\Blue Prism\File Service\pt-BR\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB81D94499} 3: C:\Program Files (x86)\Blue Prism\File Service\pt-BR\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9CD7CFA0} 3: C:\Program Files (x86)\Blue Prism\File Service\ru\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0D3B0FE2} 3: C:\Program Files (x86)\Blue Prism\File Service\ru\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB29190B1D} 3: C:\Program Files (x86)\Blue Prism\File Service\ru\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB33F3A3BA} 3: C:\Program Files (x86)\Blue Prism\File Service\ru\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD85BE7AF} 3: C:\Program Files (x86)\Blue Prism\File Service\runtimes\unix\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB944D1DEC} 3: C:\Program Files (x86)\Blue Prism\File Service\runtimes\unix\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC121DA04} 3: C:\Program Files (x86)\Blue Prism\File Service\runtimes\win\lib\netcoreapp2.0\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB60CE3367} 3: C:\Program Files (x86)\Blue Prism\File Service\runtimes\win\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA758B758} 3: C:\Program Files (x86)\Blue Prism\File Service\runtimes\win\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD9EC5B08} 3: C:\Program Files (x86)\Blue Prism\File Service\runtimes\win\lib\netstandard2.0\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFD365EF2} 3: C:\Program Files (x86)\Blue Prism\File Service\runtimes\win-arm64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCDFA8D38} 3: C:\Program Files (x86)\Blue Prism\File Service\runtimes\win-x64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2662CC0F} 3: C:\Program Files (x86)\Blue Prism\File Service\runtimes\win-x86\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB144213F7} 3: C:\Program Files (x86)\Blue Prism\File Service\tr\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF1F92433} 3: C:\Program Files (x86)\Blue Prism\File Service\tr\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9724B7A1} 3: C:\Program Files (x86)\Blue Prism\File Service\tr\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB435EC12} 3: C:\Program Files (x86)\Blue Prism\File Service\tr\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6453AD8E} 3: C:\Program Files (x86)\Blue Prism\File Service\zh-Hans\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3F0D88FE} 3: C:\Program Files (x86)\Blue Prism\File Service\zh-Hans\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA40CB8AB} 3: C:\Program Files (x86)\Blue Prism\File Service\zh-Hans\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA2A37946} 3: C:\Program Files (x86)\Blue Prism\File Service\zh-Hans\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC9C49050} 3: C:\Program Files (x86)\Blue Prism\File Service\zh-Hant\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1A3BAA5A} 3: C:\Program Files (x86)\Blue Prism\File Service\zh-Hant\Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5ADB40D0} 3: C:\Program Files (x86)\Blue Prism\File Service\zh-Hant\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD8FD1406} 3: C:\Program Files (x86)\Blue Prism\File Service\zh-Hant\Microsoft.CodeAnalysis.Workspaces.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF77A1761} 3: C:\Program Files (x86)\Blue Prism\Hub\appsettings.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7A134B32} 3: C:\Program Files (x86)\Blue Prism\Hub\Automatonymous.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB04874B58} 3: C:\Program Files (x86)\Blue Prism\Hub\Azure.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA2DD5BE0} 3: C:\Program Files (x86)\Blue Prism\Hub\Azure.Monitor.OpenTelemetry.Exporter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB57E237F6} 3: C:\Program Files (x86)\Blue Prism\Hub\BPC.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB07536412} 3: C:\Program Files (x86)\Blue Prism\Hub\BPC.Extensions.Middleware.ExceptionHandler.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9A36778D} 3: C:\Program Files (x86)\Blue Prism\Hub\BPC.Extensions.Telemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCAFD6AA7} 3: C:\Program Files (x86)\Blue Prism\Hub\BPC.Logger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9CD7271F} 3: C:\Program Files (x86)\Blue Prism\Hub\BPC.SettingsProtection.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE1B131DB} 3: C:\Program Files (x86)\Blue Prism\Hub\BPC.SettingsProtection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDE66DD4F} 3: C:\Program Files (x86)\Blue Prism\Hub\BPC.SettingsProtection.Services.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB449FF36F} 3: C:\Program Files (x86)\Blue Prism\Hub\Connect.Web.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDC617114} 3: C:\Program Files (x86)\Blue Prism\Hub\Connect.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE94F8354} 3: C:\Program Files (x86)\Blue Prism\Hub\Connect.Web.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB109F0E83} 3: C:\Program Files (x86)\Blue Prism\Hub\Connect.Web.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9E66079E} 3: C:\Program Files (x86)\Blue Prism\Hub\Elasticsearch.Net.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB704FEF09} 3: C:\Program Files (x86)\Blue Prism\Hub\ExtCore.Infrastructure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6AC41D5C} 3: C:\Program Files (x86)\Blue Prism\Hub\ExtCore.WebApplication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB54645D18} 3: C:\Program Files (x86)\Blue Prism\Hub\FluentValidation.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC01D8DEF} 3: C:\Program Files (x86)\Blue Prism\Hub\FluentValidation.DependencyInjectionExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1CC96636} 3: C:\Program Files (x86)\Blue Prism\Hub\FluentValidation.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9DDB1C36} 3: C:\Program Files (x86)\Blue Prism\Hub\Google.Protobuf.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA481DDF8} 3: C:\Program Files (x86)\Blue Prism\Hub\GreenPipes.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0764390F} 3: C:\Program Files (x86)\Blue Prism\Hub\Grpc.Core.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6375944E} 3: C:\Program Files (x86)\Blue Prism\Hub\Grpc.Net.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0AC3DEB6} 3: C:\Program Files (x86)\Blue Prism\Hub\Grpc.Net.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEA06861E} 3: C:\Program Files (x86)\Blue Prism\Hub\MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB90F01F43} 3: C:\Program Files (x86)\Blue Prism\Hub\MassTransit.ExtensionsDependencyInjectionIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB28C4A080} 3: C:\Program Files (x86)\Blue Prism\Hub\MassTransit.Platform.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB236554E7} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.AI.DependencyCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB58A91B43} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.AI.EventCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCAC9ADBA} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.AI.PerfCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAC5FAA39} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.AI.ServerTelemetryChannel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB79ACFE0} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.AI.WindowsServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB02ACC8C} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.ApplicationInsights.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7647410C} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB74076A1F} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.ApplicationInsights.NLogTarget.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3D1A806A} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.AspNetCore.JsonPatch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB38BA77BC} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.AspNetCore.Mvc.NewtonsoftJson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB00DA7E30} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.AspNetCore.Mvc.Razor.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3745ADF1} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.AspNetCore.Mvc.Razor.RuntimeCompilation.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB15A4D576} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.AspNetCore.Razor.Language.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEB0797E7} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Azure.KeyVault.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB44316104} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Azure.KeyVault.WebKey.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4685498E} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB13DE8750} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Bcl.AsyncInterfaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB83A23AE1} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.CodeAnalysis.CSharp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBAFA6534} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.CodeAnalysis.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB0FFC06A} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.CodeAnalysis.Razor.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB617778A7} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4553DC62} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.Caching.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB70611E57} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.Caching.Memory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC0BBCBCA} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7C571E31} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9BD9E64C} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC62F5AD9} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.Configuration.FileExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB68B4D0DC} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.Configuration.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5E8CB7BF} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC1D431E5} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB308EF4DE} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.DependencyModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5A3851DB} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.FileProviders.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6E0D3F30} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.FileProviders.Physical.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFF8BAF11} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.FileSystemGlobbing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB67A93F3B} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.Hosting.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9A9D455F} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCAD68E3B} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.Logging.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBADC73C51} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3130EEE4} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC733B2EF} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB56B5C027} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB10D8422B} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Identity.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB26DCC545} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB52F40724} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7EB3F7B2} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.IdentityModel.JsonWebTokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6BBC43CD} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.IdentityModel.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE257FE6C} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.IdentityModel.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB039B1F6E} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.IdentityModel.Protocols.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB92884F1C} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.IdentityModel.Tokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0A465857} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Rest.ClientRuntime.Azure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD8C9F48F} 3: C:\Program Files (x86)\Blue Prism\Hub\Microsoft.Rest.ClientRuntime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8A03EBD6} 3: C:\Program Files (x86)\Blue Prism\Hub\NewId.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD917F9B5} 3: C:\Program Files (x86)\Blue Prism\Hub\Newtonsoft.Json.Bson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8A05D644} 3: C:\Program Files (x86)\Blue Prism\Hub\Newtonsoft.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC8F5F683} 3: C:\Program Files (x86)\Blue Prism\Hub\NLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4A00A019} 3: C:\Program Files (x86)\Blue Prism\Hub\NLog.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB69051BE7} 3: C:\Program Files (x86)\Blue Prism\Hub\NLog.Targets.ElasticSearch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB314A5B1B} 3: C:\Program Files (x86)\Blue Prism\Hub\NLog.Web.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB36A25639} 3: C:\Program Files (x86)\Blue Prism\Hub\NWebsec.AspNetCore.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB13ABB0D0} 3: C:\Program Files (x86)\Blue Prism\Hub\NWebsec.AspNetCore.Middleware.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7280CD50} 3: C:\Program Files (x86)\Blue Prism\Hub\OpenTelemetry.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB33222E13} 3: C:\Program Files (x86)\Blue Prism\Hub\OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCE75C791} 3: C:\Program Files (x86)\Blue Prism\Hub\OpenTelemetry.Contrib.Instrumentation.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1BEA7982} 3: C:\Program Files (x86)\Blue Prism\Hub\OpenTelemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB99E2F1D4} 3: C:\Program Files (x86)\Blue Prism\Hub\OpenTelemetry.Exporter.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5DC71AF7} 3: C:\Program Files (x86)\Blue Prism\Hub\OpenTelemetry.Exporter.Jaeger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB54A909A1} 3: C:\Program Files (x86)\Blue Prism\Hub\OpenTelemetry.Exporter.OpenTelemetryProtocol.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB81F4DF98} 3: C:\Program Files (x86)\Blue Prism\Hub\OpenTelemetry.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4E84D1C8} 3: C:\Program Files (x86)\Blue Prism\Hub\OpenTelemetry.Instrumentation.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF30FB6A5} 3: C:\Program Files (x86)\Blue Prism\Hub\OpenTelemetry.Instrumentation.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB15AE7579} 3: C:\Program Files (x86)\Blue Prism\Hub\OpenTelemetry.Instrumentation.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA2226E8B} 3: C:\Program Files (x86)\Blue Prism\Hub\System.ComponentModel.Annotations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8EDF8B4B} 3: C:\Program Files (x86)\Blue Prism\Hub\System.Configuration.ConfigurationManager.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBED61C106} 3: C:\Program Files (x86)\Blue Prism\Hub\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB60EFBA0D} 3: C:\Program Files (x86)\Blue Prism\Hub\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB93DAB319} 3: C:\Program Files (x86)\Blue Prism\Hub\System.IdentityModel.Tokens.Jwt.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB613BBEA3} 3: C:\Program Files (x86)\Blue Prism\Hub\System.Memory.Data.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4016A962} 3: C:\Program Files (x86)\Blue Prism\Hub\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8F450E0A} 3: C:\Program Files (x86)\Blue Prism\Hub\System.Runtime.CompilerServices.Unsafe.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB035E173F} 3: C:\Program Files (x86)\Blue Prism\Hub\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE449BC16} 3: C:\Program Files (x86)\Blue Prism\Hub\System.Text.Encodings.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC067EE07} 3: C:\Program Files (x86)\Blue Prism\Hub\System.Text.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFB7F99C0} 3: C:\Program Files (x86)\Blue Prism\Hub\System.Threading.Channels.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE606711B} 3: C:\Program Files (x86)\Blue Prism\Hub\Web.config
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1CADA93B} 3: C:\Program Files (x86)\Blue Prism\Hub\cs\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9A2C3AF1} 3: C:\Program Files (x86)\Blue Prism\Hub\cs\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCC3C7983} 3: C:\Program Files (x86)\Blue Prism\Hub\de\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDBC4DBBA} 3: C:\Program Files (x86)\Blue Prism\Hub\de\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB39A6610A} 3: C:\Program Files (x86)\Blue Prism\Hub\es\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1E8AE4EC} 3: C:\Program Files (x86)\Blue Prism\Hub\es\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB982CB289} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\packages.config
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB788FBD3F} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\AspNetCore.Proxy.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB22B7A41F} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Automatonymous.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEBCD8DBD} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Azure.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBAB731DB} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Azure.Storage.Blobs.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB833FEB47} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Azure.Storage.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2C76A689} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Azure.Storage.Queues.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8FCA3632} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BluePrismCloud.ExtCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB9C68058} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Audit.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB68BF2314} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Audit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7B57A7C7} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB96483B75} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Contracts.InteractForms.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6729A647} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Data.Sql.Encryption.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2B02447C} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.EmailService.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB02A548AC} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.EmailService.Messages.Commands.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB66A43529} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Extensions.ActionResults.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCAC5C707} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Extensions.ActionResults.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFB394D34} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE4CBC8BC} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Extensions.Linq.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7EDEA579} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Extensions.String.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB93C495B2} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Extensions.Tasks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB746E6CFF} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.FileStorage.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB345D9963} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Hub.Messages.Commands.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD8016417} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Iada.Messages.Commands.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB33FDED47} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Ims.Messages.Commands.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1D49EF4F} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Interact.Messages.Commands.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE016ACCF} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.LicenseManager.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD2EC2C9F} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.LicenseManager.Messages.Events.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE46877D7} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Logger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB366861C9} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Messaging.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1DC7D59A} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.NotificationCenter.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6555CDB0} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.NotificationCenter.Messages.Commands.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB451C20C2} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Repository.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC67F1621} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Search.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4F4B6C55} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Search.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB71E8FDD6} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.Search.Services.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC204C057} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.SettingsProtection.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE8142124} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.SettingsProtection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6CD0580D} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\BPC.SettingsProtection.Services.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB17498CA1} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Authentication.Forms.BusinessLogic.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF59960C8} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Authentication.Forms.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBE966D4B} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Authentication.Forms.Frontend.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDE5E7A20} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Core.Data.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB756FAFF4} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Core.Data.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC604586E} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Core.Data.Entities.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB23F1174A} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Core.Data.EntityFramework.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB146EFC69} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2487BC5D} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Core.Environment.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB1DA6A2C} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Core.Frontend.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB44EA552B} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Core.Services.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB665E1FC3} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Core.Thoughtonomy.Data.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB309D14C0} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Core.Thoughtonomy.Data.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB984B8CDC} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Core.Thoughtonomy.Data.Entities.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8C810096} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Core.Thoughtonomy.Data.EntityFramework.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD84BE500} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Dashboard.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC490F355} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Dashboard.Frontend.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC1658335} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Installer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB413C2C1B} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Connect.Installer.Frontend.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB88E05D74} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\CsvHelper.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1824F120} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Dapper.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6AF35B59} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\EFCore.BulkExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE486ACBD} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Elasticsearch.Net.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB11F8CC59} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\ElmahCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5B42D4E0} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\ElmahCore.Mvc.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEE135EE5} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\ExtCore.Data.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA685AAFF} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\ExtCore.Data.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB337264DC} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\ExtCore.Data.Entities.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB86C1A6E9} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\ExtCore.Infrastructure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB3658E1E} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\ExtCore.Mvc.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF072063D} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\ExtCore.Mvc.Infrastructure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB300CC20A} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\ExtCore.WebApplication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFD9EC07A} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\FastMember.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFF84513F} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\FSharp.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7FF088B6} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\GreenPipes.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB9C225D4} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\HealthChecks.AzureStorage.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2E129C1D} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\HealthChecks.IdSvr.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7DED7E91} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\HealthChecks.Network.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB02E046A6} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\HealthChecks.RabbitMQ.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE9CEFA4D} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\HealthChecks.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8488BA0F} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\HealthChecks.System.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB053DC595} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\HealthChecks.Uris.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB14F03AE} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Hub.Core.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4A72EB92} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Hub.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB198E9CA8} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\IdentityModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA3BBFA16} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Linq.Expression.Optimizer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6CCD37B7} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\MassTransit.AspNetCoreIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB81D723C7} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\MassTransit.Azure.ServiceBus.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB58EC0A7F} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4424FF54} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\MassTransit.ExtensionsDependencyInjectionIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF5624999} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\MassTransit.RabbitMqTransport.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2A05DDCB} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\MassTransit.SignalR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA3745C32} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AI.DependencyCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5BBA912E} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AI.EventCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF7B699A0} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AI.PerfCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5BEFF3DD} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AI.ServerTelemetryChannel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB700B2C1E} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AI.WindowsServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB89816E11} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.ApplicationInsights.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEDF62E83} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1B25A3AB} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.ApplicationInsights.NLogTarget.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0682614C} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AspNetCore.Authentication.JwtBearer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFBEFFB13} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AspNetCore.Authentication.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA903B385} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AspNetCore.Cryptography.Internal.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB37A4D086} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AspNetCore.Cryptography.KeyDerivation.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB90F54601} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AspNetCore.Identity.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4A35D8B7} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AspNetCore.JsonPatch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1817D974} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AspNetCore.Mvc.NewtonsoftJson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB46C2057F} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AspNetCore.Mvc.Razor.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3A3E953A} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AspNetCore.NodeServices.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB49DEBE59} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AspNetCore.Razor.Language.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0AF6F69D} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AspNetCore.SpaServices.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD7FD82AC} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.AspNetCore.SpaServices.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6F623FE8} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Azure.Amqp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB45A921C6} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Azure.Cosmos.Table.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB05F75F6F} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Azure.DocumentDB.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB522E100B} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Azure.KeyVault.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD5A0099B} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Azure.KeyVault.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6873BE6B} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Azure.KeyVault.WebKey.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB10B0ECD2} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Azure.ServiceBus.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA6CCF884} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE3553928} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Azure.Storage.Blob.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6EA6A2E1} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Azure.Storage.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFFDE1881} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Bcl.AsyncInterfaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA0AFAAC3} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Bcl.HashCode.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD5A8AC59} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.CodeAnalysis.CSharp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAFD10B30} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.CodeAnalysis.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF8A693A2} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.CodeAnalysis.Razor.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7E2BFAF7} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Data.SqlClient.AlwaysEncrypted.AzureKeyVaultProvider.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB23DFA02E} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA91327F6} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Data.Sqlite.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB722ADEF8} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.DotNet.PlatformAbstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB64F2019A} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.EntityFrameworkCore.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8F73A4C0} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2C7E5A71} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.EntityFrameworkCore.Relational.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB86EE9C8E} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.EntityFrameworkCore.Sqlite.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB17873D81} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.EntityFrameworkCore.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD30E79D9} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Caching.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB72D0B833} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Caching.Memory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB24D5771C} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Caching.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB46EB77F4} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9C9C5C0C} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB92A7806A} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Configuration.CommandLine.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4BB86D31} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE5D8629B} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Configuration.EnvironmentVariables.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5BEAFDF9} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Configuration.FileExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE468BF46} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Configuration.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB07CC2872} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Configuration.UserSecrets.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4DC7ED51} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB36FE6585} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7605F588} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.DependencyModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB94C1DED5} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.DiagnosticAdapter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEE8A92FB} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB97DC536C} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Diagnostics.HealthChecks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBABA40552} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.FileProviders.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8B3BDEC0} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.FileProviders.Physical.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB0D7FE4C} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.FileSystemGlobbing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB83300FCD} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Hosting.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8EB67B63} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB231AED52} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4F3ED364} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Identity.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB660C2B77} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Identity.Stores.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB519AAD41} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDC04A9A9} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Logging.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB82D53444} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Logging.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAE4F5692} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Logging.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4DB34A47} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Logging.Debug.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB23036268} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC5D5B31A} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Logging.EventLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8AA32329} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Logging.EventSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB07C43A9C} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBABC4C88B} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1D597C3D} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.PlatformAbstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB61D1CB4A} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB40C866CE} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Identity.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB920CF97C} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB83FCE0E} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD3C5FBAA} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.IdentityModel.JsonWebTokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB643652D2} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.IdentityModel.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFF1715D5} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.IdentityModel.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB7B998EA} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.IdentityModel.Protocols.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB89FF79B5} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.IdentityModel.Tokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCF530710} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.OData.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD7678B6B} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.OData.Edm.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB60B4DF4F} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.OpenApi.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB37F769C} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Rest.ClientRuntime.Azure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1A6FBCD1} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Rest.ClientRuntime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB64E875CB} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Microsoft.Spatial.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3346C624} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NewId.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEBDE865C} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Newtonsoft.Json.Bson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA4000576} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Newtonsoft.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9F811F6B} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD7C295EE} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NLog.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB36401CAE} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NLog.Targets.ElasticSearch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3E9843EA} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NLog.Web.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBCC700E0} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NuGet.Commands.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8ACB9F6E} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NuGet.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB95BE56F4} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NuGet.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0A3F7653} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NuGet.ContentModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB56AD2BFB} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NuGet.DependencyResolver.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD8AC805A} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NuGet.Frameworks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB5A14729} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NuGet.LibraryModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB05A871CF} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NuGet.PackageManagement.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB116B0C07} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NuGet.Packaging.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB95EFE3D7} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NuGet.Packaging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC4CCFB9D} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NuGet.ProjectModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA5A8328D} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NuGet.Protocol.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9127147E} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NuGet.Resolver.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB40E6B02A} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\NuGet.Versioning.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC08CA8C8} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\RabbitMQ.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB16723CF1} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Renci.SshNet.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9924551A} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Scrutor.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC94A1A17} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\SixLabors.Fonts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB671C4303} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\SixLabors.ImageSharp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB97C4A3DE} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\SixLabors.ImageSharp.Drawing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB91DCC215} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\SQLitePCLRaw.batteries_v2.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8EC8732A} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\SQLitePCLRaw.core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB794FDA5F} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\SQLitePCLRaw.nativelibrary.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB55FFDB3F} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\SQLitePCLRaw.provider.dynamic_cdecl.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1B6B3301} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\SshNet.Security.Cryptography.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB89DE4E47} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Swashbuckle.AspNetCore.Annotations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4F0512F5} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Swashbuckle.AspNetCore.Swagger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF559C268} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Swashbuckle.AspNetCore.SwaggerGen.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB79BF3723} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\Swashbuckle.AspNetCore.SwaggerUI.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB689EEA83} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\System.ComponentModel.Annotations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDD710E13} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\System.Configuration.ConfigurationManager.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB52B9224B} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB208A938F} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB570CF771} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB02FE76CD} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\System.IdentityModel.Tokens.Jwt.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8A3472F4} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\System.Resources.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB97ACBBDB} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCAFED11C} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9612A084} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\System.ServiceProcess.ServiceController.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB80F0070E} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\System.Text.Encodings.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB53609605} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\System.Threading.Channels.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1D8BA205} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\System.Xml.XPath.XmlDocument.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAC610DA1} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\de\Connect.Core.Services.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD29E81B4} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\es\Connect.Core.Services.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1DA62B7B} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\fr\Connect.Core.Services.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0CB31589} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\ja\Connect.Core.Services.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB808B4C8B} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\pt\Connect.Core.Services.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB25F8FDAA} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\ru\Connect.Core.Services.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8C648A58} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\zh\Connect.Core.Services.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFE4106CD} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\Connect.Authentication.Forms.4.6.0.99.nupkg
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDC1DB04D} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\Connect.Core.4.6.0.99.nupkg
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC2553CD2} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\Connect.Core.Data.4.6.0.99.nupkg
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCAC5B608} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\Connect.Core.Thoughtonomy.Data.4.6.0.99.nupkg
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB440A7968} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\Connect.Dashboard.4.6.0.99.nupkg
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9D4B0A5E} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\Connect.Installer.4.6.0.99.nupkg
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9B07D07B} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\Connect.ProjectManagement.4.6.0.99.nupkg
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0EAC2337} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\Connect.SelfServe.Forms.4.6.0.99.nupkg
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB138F434A} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\Hub.AutomationLifecycle.BusinessProcesses.4.6.0.99.nupkg
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE09B7BD8} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\Hub.BluePrismDecision.4.6.0.99.nupkg
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8FA9F3A1} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\Hub.WebBasedControlRoom.4.6.0.99.nupkg
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE61A4318} 3: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Packages\sqlserver.21.1.18235.nupkg
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3CB92469} 3: C:\Program Files (x86)\Blue Prism\Hub\fr\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC4552F65} 3: C:\Program Files (x86)\Blue Prism\Hub\fr\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB99E96978} 3: C:\Program Files (x86)\Blue Prism\Hub\it\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF33FAEAC} 3: C:\Program Files (x86)\Blue Prism\Hub\it\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB35FCECB1} 3: C:\Program Files (x86)\Blue Prism\Hub\ja\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAC1CD6F9} 3: C:\Program Files (x86)\Blue Prism\Hub\ja\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF63D489C} 3: C:\Program Files (x86)\Blue Prism\Hub\ko\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDFAE292A} 3: C:\Program Files (x86)\Blue Prism\Hub\ko\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB059C0DDE} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Automatonymous.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB29327483} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\BluePrismCloud.ExtCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB98816982} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\BPC.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD14936E4} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\BPC.Contracts.InteractForms.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB05CE37F8} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\BPC.Data.Sql.Encryption.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE2244FDB} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\BPC.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB335B8C16} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\BPC.Extensions.Tasks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2EA4EC3C} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\BPC.Messaging.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB59E93385} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\BPC.Repository.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6D3DB7D3} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\BPC.SettingsProtection.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6E659A24} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\BPC.SettingsProtection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB947F67EA} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\BPC.SettingsProtection.Services.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA8ACB6AB} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\CommandLine.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4E7E337A} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Connect.Core.Data.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6481DAEE} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Connect.Core.Data.Entities.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB651291B4} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Connect.Core.Data.EntityFramework.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDF892E61} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Connect.Core.Environment.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB13C375E4} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Connect.Core.Thoughtonomy.Data.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC7529E13} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Connect.Core.Thoughtonomy.Data.Entities.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB60147EBB} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Connect.Core.Thoughtonomy.Data.EntityFramework.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB01A8FAEA} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Dapper.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5A0D95D1} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\dbup-core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDCC368C5} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\dbup-sqlserver.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB66295236} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\EFCore.BulkExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2BB5D509} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\ExtCore.Data.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB78EBDEA8} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\ExtCore.Data.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB4E67B4A} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\ExtCore.Data.Entities.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB20972A3} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\ExtCore.Infrastructure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4D79CD57} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\ExtCore.Mvc.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB709C6DBA} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\ExtCore.Mvc.Infrastructure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1808A9CF} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\ExtCore.WebApplication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3650E1EC} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\FastMember.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB83F497BC} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\FSharp.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFE062DE9} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\GreenPipes.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC583365E} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Hub.Core.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEFE78E85} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Hub.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF3499366} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\HubMigrations.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB272300A9} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\HubMigrations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB519458DC} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\HubMigrations.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB70BD8F6B} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\HubMigrations.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB94206BA5} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Linq.Expression.Optimizer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB91E858B5} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\MassTransit.AspNetCoreIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC3EAFEEA} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\MassTransit.Azure.ServiceBus.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC7A3AD8E} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB09B6A968} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\MassTransit.ExtensionsDependencyInjectionIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF1541A2F} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\MassTransit.RabbitMqTransport.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD1B4C2E9} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\MassTransit.SignalR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC6CF2E74} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\MediatR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB93F3FF8B} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\MediatR.Extensions.Microsoft.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1A5C4417} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.AspNetCore.Cryptography.Internal.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5387A93D} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.AspNetCore.Cryptography.KeyDerivation.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1DD9CA3D} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Azure.Amqp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4CFBAFDA} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Azure.KeyVault.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB320553A8} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Azure.KeyVault.WebKey.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8DB51037} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Azure.ServiceBus.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB774B6FF7} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBABA5DA2} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Bcl.AsyncInterfaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA54BA055} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Bcl.HashCode.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB29B319A0} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Data.SqlClient.AlwaysEncrypted.AzureKeyVaultProvider.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB635766AD} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB84F6CB2E} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Data.Sqlite.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB62B95FCD} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.DotNet.PlatformAbstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7C7E4910} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.EntityFrameworkCore.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFE066D3B} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9BD33642} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.EntityFrameworkCore.Relational.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC48C4E27} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.EntityFrameworkCore.Sqlite.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFF953B44} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.EntityFrameworkCore.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFD1517B7} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Caching.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4A5C79E0} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Caching.Memory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFB891142} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB062657A8} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8A7AD575} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2EE9F96A} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB11A26D47} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD1CD0124} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.DependencyModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3BAE081C} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7F5A0175} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Diagnostics.HealthChecks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC2ED9EA2} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.FileProviders.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDBC463B6} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Hosting.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB72A84387} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Identity.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB98EE13C0} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Identity.Stores.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2FB689B8} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB17224EC1} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Logging.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB40CF32D7} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Logging.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1137384E} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD79C407F} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4EE58177} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC1BA6D3D} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC423D3CD} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Identity.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6564184B} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB530D9EDE} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.IdentityModel.JsonWebTokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD994AA4F} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.IdentityModel.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB98D1317D} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.IdentityModel.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB07F36805} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.IdentityModel.Protocols.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8D7AF431} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.IdentityModel.Tokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDE3B9281} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Rest.ClientRuntime.Azure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0D52440E} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Microsoft.Rest.ClientRuntime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA8912CAE} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\NewId.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBE3DA895} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Newtonsoft.Json.Bson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB11EC0F59} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Newtonsoft.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3893AA89} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\NLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5554980D} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\NLog.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA4C1CC8D} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\NLog.Web.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1E9AB891} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\RabbitMQ.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7D5062A4} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\SQLitePCLRaw.batteries_v2.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6B22A000} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\SQLitePCLRaw.core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6BF0A286} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\SQLitePCLRaw.nativelibrary.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2F006378} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\SQLitePCLRaw.provider.dynamic_cdecl.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8BC032E1} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\System.Configuration.ConfigurationManager.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2CE62145} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA62732FE} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB72BC894C} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\System.IdentityModel.Tokens.Jwt.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE72AC18B} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5FEE54F8} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0BB18433} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\System.Text.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9E4323AD} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\System.Threading.Channels.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB95E54638} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\alpine-x64\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB97D419E0} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\any\native\FSharp.Core.optdata
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF24BAE0D} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\any\native\FSharp.Core.sigdata
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9E854BB4} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\linux-arm\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6F1032C6} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\linux-arm64\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6259972D} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\linux-armel\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB951EB4A4} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\linux-musl-x64\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7FEFA21F} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\linux-x64\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEEAE39BD} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\linux-x86\native\libe_sqlite3.so
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0215A974} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\osx-x64\native\libe_sqlite3.dylib
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBACAC8662} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\unix\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDA84A766} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\unix\lib\netcoreapp2.1\Microsoft.Data.SqlClient.AlwaysEncrypted.AzureKeyVaultProvider.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8817F9D7} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\unix\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCD4D5373} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\unix\lib\netcoreapp2.1\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7AEE2AFD} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA146431C} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win\lib\netcoreapp2.1\Microsoft.Data.SqlClient.AlwaysEncrypted.AzureKeyVaultProvider.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB252E81CC} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB127070B4} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win\lib\netcoreapp2.1\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBADD2BA9E} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win\lib\netstandard2.0\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE4C68C78} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win-arm\native\e_sqlite3.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB982AAF1B} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win-arm64\native\e_sqlite3.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA290E0EB} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win-arm64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE836DC91} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win-x64\native\e_sqlite3.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC72D8C6C} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win-x64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB542D60D6} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win-x86\native\e_sqlite3.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0E93B572} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win-x86\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4AA7B92B} 3: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Scripts\Cache\[Cache]-001-Table-Cache-Create.sql
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB693DE22} 3: C:\Program Files (x86)\Blue Prism\Hub\pl\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB87D52C2A} 3: C:\Program Files (x86)\Blue Prism\Hub\pl\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB42938686} 3: C:\Program Files (x86)\Blue Prism\Hub\pt-BR\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC4D89077} 3: C:\Program Files (x86)\Blue Prism\Hub\pt-BR\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB618253A5} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Antiforgery.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1E19FC53} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Authentication.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFF9D5931} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Authentication.Cookies.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB50D324D8} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Authentication.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9F20644F} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Authentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB207D9686} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Authentication.OAuth.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB11125AFF} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Authorization.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE08674DA} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Authorization.Policy.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCEDA8F84} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Components.Authorization.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB23562F4B} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Components.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB834AE983} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Components.Forms.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0BD004A9} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Components.Server.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB489B0C60} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Components.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7FB49485} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Connections.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4D1AC380} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.CookiePolicy.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBC02BE92} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Cors.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6D05D592} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Cryptography.Internal.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB36A9CEA} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Cryptography.KeyDerivation.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB52FAE740} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.DataProtection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB62A47E50} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.DataProtection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4AA13182} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.DataProtection.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7089646F} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Diagnostics.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB30C40A7F} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Diagnostics.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEAF8C8C3} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Diagnostics.HealthChecks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB565A920D} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB57BCB700} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.HostFiltering.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFA617D1D} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Hosting.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4EEB0F44} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7EBBAE05} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Hosting.Server.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB80BAD3CD} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Html.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7C8CFBDE} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Http.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF013B6E4} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Http.Connections.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE81046BD} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Http.Connections.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE10D9F28} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6C0C9609} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Http.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0D67B1BD} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Http.Features.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1C0FCC0A} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.HttpOverrides.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB65935A3F} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.HttpsPolicy.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1F630A83} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Identity.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2576D455} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Localization.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCB5A8AE3} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Localization.Routing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB53C40FB0} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Metadata.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1CDBEBBF} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Mvc.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB44518D6A} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Mvc.ApiExplorer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC925AC57} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Mvc.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE0B43511} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Mvc.Cors.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF4E8D974} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Mvc.DataAnnotations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB24D886CF} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Mvc.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB593A6E05} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Mvc.Formatters.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB25AC157A} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Mvc.Formatters.Xml.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB985B36F} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Mvc.Localization.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB45BBC1DB} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Mvc.Razor.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD5A25C28} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Mvc.RazorPages.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0D86A25B} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Mvc.TagHelpers.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5D9CD57F} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Mvc.ViewFeatures.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB86697319} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Razor.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAFE0FE18} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Razor.Runtime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBD5DE257} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.ResponseCaching.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB1606C9B} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.ResponseCaching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFD03AA12} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.ResponseCompression.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB823A7806} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Rewrite.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE63111A3} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Routing.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6FD1FE46} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Routing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4839FE34} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Server.HttpSys.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8B36DEE1} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Server.IIS.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC1048C94} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Server.IISIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2AF86327} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Server.Kestrel.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC4784F5D} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Server.Kestrel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB95F5BDA6} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDC57B6BE} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.Session.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE5F6E5E0} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.SignalR.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6789EC35} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.SignalR.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD65D4F43} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.SignalR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB45A81799} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.SignalR.Protocols.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB323B521C} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.StaticFiles.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3349842C} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.WebSockets.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE4F52E32} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.AspNetCore.WebUtilities.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA58A6E50} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.CSharp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB03C948BB} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCD8EAF76} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Configuration.CommandLine.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4F43A78A} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Configuration.EnvironmentVariables.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB711E4564} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Configuration.Ini.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF01A207F} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Configuration.KeyPerFile.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCF4FA04F} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Configuration.UserSecrets.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB60F2817A} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Configuration.Xml.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0C644DC7} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF01F8D41} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Diagnostics.HealthChecks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB334A172C} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.FileProviders.Composite.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB80FD88EC} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.FileProviders.Embedded.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2E72B005} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB55B89A07} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEFC5A59D} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Identity.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8D973367} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Identity.Stores.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4619615D} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Localization.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB429DC13E} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Localization.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1E2FD58C} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Logging.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD30AD82F} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Logging.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB22AC38B0} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Logging.Debug.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB7ABA555} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Logging.EventLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0D3BB151} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Logging.EventSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0BCD0FB3} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Logging.TraceSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB895928E} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.ObjectPool.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1FA62F45} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.Options.DataAnnotations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB38486966} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Extensions.WebEncoders.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB92AD9A0E} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.JSInterop.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7E8AA50E} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Net.Http.Headers.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEC27F611} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.VisualBasic.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA101BFAC} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.VisualBasic.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4590B35E} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Win32.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB427B741B} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\Microsoft.Win32.Registry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6B7A7887} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\mscorlib.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB252CD838} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\netstandard.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB440F35D7} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.AppContext.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4C8CB2DD} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Buffers.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA61FFC00} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Collections.Concurrent.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9931A2C6} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Collections.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7263A15D} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Collections.Immutable.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB44CEF7B8} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Collections.NonGeneric.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCE717E96} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Collections.Specialized.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4FD627A2} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.ComponentModel.Annotations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB32BBAD8} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.ComponentModel.DataAnnotations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE9885B96} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.ComponentModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB29EAA286} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.ComponentModel.EventBasedAsync.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8019BC48} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.ComponentModel.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBCDAA45C} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.ComponentModel.TypeConverter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0CAFA53E} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDACE3AB9} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5F9D9B55} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5F1A6FCD} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Data.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB01631F07} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Data.DataSetExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB43C6E9CD} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Data.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5DFD2F30} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Diagnostics.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAF3DF7FD} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Diagnostics.Debug.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2350B4F9} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Diagnostics.EventLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB450E1945} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Diagnostics.FileVersionInfo.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB92D440F7} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB6851980} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Diagnostics.Process.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8FA9C059} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Diagnostics.StackTrace.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAB234642} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Diagnostics.TextWriterTraceListener.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF86FD9E8} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Diagnostics.Tools.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1108A090} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Diagnostics.TraceSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0165AC26} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Diagnostics.Tracing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7871CEB5} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF488AB8C} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Drawing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB60926CB7} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Drawing.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC9F87965} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Dynamic.Runtime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB82668D3A} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Globalization.Calendars.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB69BEA28B} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Globalization.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB800CE7D} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Globalization.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA037023C} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.IO.Compression.Brotli.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCEA3876F} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.IO.Compression.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9BB0C815} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.IO.Compression.FileSystem.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAA06A8A9} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.IO.Compression.ZipFile.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBD185109} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.IO.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB657E857} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.IO.FileSystem.AccessControl.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB58A100BB} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.IO.FileSystem.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0952BCAE} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.IO.FileSystem.DriveInfo.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF5632315} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.IO.FileSystem.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBFA113AC} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.IO.FileSystem.Watcher.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6C448ED7} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.IO.IsolatedStorage.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF833F455} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.IO.MemoryMappedFiles.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAD7A0178} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.IO.Pipelines.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB55384079} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.IO.Pipes.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC5F10085} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.IO.UnmanagedMemoryStream.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCFDCA501} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Linq.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB58549623} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Linq.Expressions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB075F348A} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Linq.Parallel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEBE00F8F} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Linq.Queryable.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB901DCAE1} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Memory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB48BEAFFC} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB29AD9877} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB71353CD5} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.HttpListener.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB06B1DEFC} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.Mail.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0757CCC0} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.NameResolution.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA577E48A} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.NetworkInformation.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2663BE8F} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.Ping.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB31ABD9A} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3D35412B} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.Requests.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB05DC2C27} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.Security.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB37A851C5} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.ServicePoint.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB20C989BE} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.Sockets.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1F4E5C53} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.WebClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB852911B6} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.WebHeaderCollection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4D148279} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.WebProxy.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB78E9A0F0} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.WebSockets.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB7489F1A} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Net.WebSockets.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE588C59E} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Numerics.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBCB2AAE2} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Numerics.Vectors.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB03FAB5AE} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.ObjectModel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB12ECE50D} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Reflection.DispatchProxy.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD019C316} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Reflection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5A00DB77} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Reflection.Emit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBADF7A73F} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Reflection.Emit.ILGeneration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA746536A} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Reflection.Emit.Lightweight.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6A35D303} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Reflection.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFAF2369E} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Reflection.Metadata.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA04A684A} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Reflection.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB992D83C3} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Reflection.TypeExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFDBFE9EB} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Resources.Reader.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBED363E5A} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Resources.ResourceManager.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7C35765E} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Resources.Writer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE254BEBD} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Runtime.CompilerServices.VisualC.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDA0D65EA} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Runtime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB716713BF} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Runtime.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBFA6E473} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Runtime.Handles.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB11DB69A4} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Runtime.InteropServices.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB20B86C68} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Runtime.InteropServices.RuntimeInformation.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD30CC044} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Runtime.InteropServices.WindowsRuntime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB69BBAFDE} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Runtime.Intrinsics.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB94F507B1} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Runtime.Loader.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC64982C9} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Runtime.Numerics.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA8F54877} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Runtime.Serialization.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB776AA08A} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Runtime.Serialization.Formatters.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB50030F0D} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Runtime.Serialization.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB24BAC5E7} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Runtime.Serialization.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1F20B3D5} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Runtime.Serialization.Xml.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB523BCAD2} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Security.AccessControl.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB56ADA245} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Security.Claims.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2CBA3C46} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Security.Cryptography.Algorithms.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4636C6E1} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Security.Cryptography.Cng.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB609A7262} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Security.Cryptography.Csp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB76FD1A16} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Security.Cryptography.Encoding.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB04A0AD37} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Security.Cryptography.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8BDF407D} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Security.Cryptography.X509Certificates.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBF0EBE3B} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Security.Cryptography.Xml.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB34D3D391} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Security.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB3D915A8} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Security.Permissions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB50BCA443} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Security.Principal.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEB17B4F5} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Security.Principal.Windows.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF68A14F3} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Security.SecureString.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE2FB4ABB} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.ServiceModel.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8BB87559} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.ServiceProcess.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA6746D06} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Text.Encoding.CodePages.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC66FEEB4} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Text.Encoding.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB39F918E4} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Text.Encoding.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB236EDE65} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Text.RegularExpressions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB1096386} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Threading.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB23D7ACA4} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Threading.Overlapped.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB04C9654} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Threading.Tasks.Dataflow.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB39A11132} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Threading.Tasks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCB4112F8} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Threading.Tasks.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5BA71D35} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Threading.Tasks.Parallel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCDDAF253} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Threading.Thread.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE1AEA903} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Threading.ThreadPool.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB88C47E92} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Threading.Timer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB78E9E443} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Transactions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB719E7998} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Transactions.Local.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9C0EFBCF} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.ValueTuple.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3DA83CCD} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8C29685F} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Web.HttpUtility.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3EF39406} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Windows.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1F3B524D} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Windows.Extensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAB29BB63} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Xml.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8C34128C} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Xml.Linq.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE559E3E0} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Xml.ReaderWriter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1463E405} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Xml.Serialization.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFD51FED0} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Xml.XDocument.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4CDDE895} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Xml.XmlDocument.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDDA046F3} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Xml.XmlSerializer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE82455B9} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Xml.XPath.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB395F74D9} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\System.Xml.XPath.XDocument.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6705BB31} 3: C:\Program Files (x86)\Blue Prism\Hub\refs\WindowsBase.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5AD296BB} 3: C:\Program Files (x86)\Blue Prism\Hub\ru\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB37D8794F} 3: C:\Program Files (x86)\Blue Prism\Hub\ru\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6299EDB9} 3: C:\Program Files (x86)\Blue Prism\Hub\runtimes\unix\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF245022F} 3: C:\Program Files (x86)\Blue Prism\Hub\runtimes\unix\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB03A12DD8} 3: C:\Program Files (x86)\Blue Prism\Hub\runtimes\win\lib\netcoreapp2.0\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2A7F1E62} 3: C:\Program Files (x86)\Blue Prism\Hub\runtimes\win\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB15696EB3} 3: C:\Program Files (x86)\Blue Prism\Hub\runtimes\win\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB57127C67} 3: C:\Program Files (x86)\Blue Prism\Hub\runtimes\win\lib\netstandard2.0\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD5912239} 3: C:\Program Files (x86)\Blue Prism\Hub\runtimes\win-arm64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCF70DC4C} 3: C:\Program Files (x86)\Blue Prism\Hub\runtimes\win-x64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8AF44060} 3: C:\Program Files (x86)\Blue Prism\Hub\runtimes\win-x86\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC2B70FC4} 3: C:\Program Files (x86)\Blue Prism\Hub\tr\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5C811685} 3: C:\Program Files (x86)\Blue Prism\Hub\tr\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB19F5231B} 3: C:\Program Files (x86)\Blue Prism\Hub\zh-Hans\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB920223DA} 3: C:\Program Files (x86)\Blue Prism\Hub\zh-Hans\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2237F1C9} 3: C:\Program Files (x86)\Blue Prism\Hub\zh-Hant\Microsoft.CodeAnalysis.CSharp.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB01B3D55A} 3: C:\Program Files (x86)\Blue Prism\Hub\zh-Hant\Microsoft.CodeAnalysis.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB602B1064} 3: C:\Program Files (x86)\Blue Prism\License Manager\appsettings.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB110A7953} 3: C:\Program Files (x86)\Blue Prism\License Manager\Automatonymous.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6B8C6B9F} 3: C:\Program Files (x86)\Blue Prism\License Manager\Azure.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB76BFF66F} 3: C:\Program Files (x86)\Blue Prism\License Manager\Azure.Monitor.OpenTelemetry.Exporter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB16966777} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB56D1E15F} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.Extensions.Middleware.ExceptionHandler.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3728D94B} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.Extensions.Tasks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB3788A05} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.Extensions.Telemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7F4CF0EA} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.LicenseManager.BusinessLogic.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDC766773} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.LicenseManager.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC95C3636} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.LicenseManager.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB98658DCA} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.LicenseManager.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6E32D52A} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.LicenseManager.DataAccess.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEE092CE3} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.LicenseManager.Logic.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB810B3E57} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.LicenseManager.Messages.Events.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8F51A749} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.LicenseManager.Web.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB27A16826} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.LicenseManager.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB56837933} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.LicenseManager.Web.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF0AE7332} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.LicenseManager.Web.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA2BE239C} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.Logger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC5EFE078} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.Messaging.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB29398A8C} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.SettingsProtection.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEEC3F0DB} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.SettingsProtection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5442C308} 3: C:\Program Files (x86)\Blue Prism\License Manager\BPC.SettingsProtection.Services.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7A7F850E} 3: C:\Program Files (x86)\Blue Prism\License Manager\Dapper.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD21EE5FB} 3: C:\Program Files (x86)\Blue Prism\License Manager\Elasticsearch.Net.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB045BDF3C} 3: C:\Program Files (x86)\Blue Prism\License Manager\FluentValidation.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB29727300} 3: C:\Program Files (x86)\Blue Prism\License Manager\FluentValidation.DependencyInjectionExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB480D3667} 3: C:\Program Files (x86)\Blue Prism\License Manager\FluentValidation.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBECA48AD6} 3: C:\Program Files (x86)\Blue Prism\License Manager\Google.Protobuf.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0BDB0B39} 3: C:\Program Files (x86)\Blue Prism\License Manager\GreenPipes.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC3030D57} 3: C:\Program Files (x86)\Blue Prism\License Manager\Grpc.Core.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4B8CDED4} 3: C:\Program Files (x86)\Blue Prism\License Manager\Grpc.Net.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB12CECE94} 3: C:\Program Files (x86)\Blue Prism\License Manager\Grpc.Net.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2D7AFF71} 3: C:\Program Files (x86)\Blue Prism\License Manager\HealthChecks.IdSvr.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB51C015C5} 3: C:\Program Files (x86)\Blue Prism\License Manager\HealthChecks.RabbitMQ.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB45715419} 3: C:\Program Files (x86)\Blue Prism\License Manager\HealthChecks.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB580E6845} 3: C:\Program Files (x86)\Blue Prism\License Manager\MassTransit.AspNetCoreIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB50FBFEBC} 3: C:\Program Files (x86)\Blue Prism\License Manager\MassTransit.Azure.ServiceBus.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC4052929} 3: C:\Program Files (x86)\Blue Prism\License Manager\MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBED0CF61E} 3: C:\Program Files (x86)\Blue Prism\License Manager\MassTransit.ExtensionsDependencyInjectionIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6426687E} 3: C:\Program Files (x86)\Blue Prism\License Manager\MassTransit.Platform.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB668023BD} 3: C:\Program Files (x86)\Blue Prism\License Manager\MassTransit.RabbitMqTransport.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7EA38855} 3: C:\Program Files (x86)\Blue Prism\License Manager\MassTransit.SignalR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8681E117} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.AI.DependencyCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB23E6A9A7} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.AI.EventCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB62597843} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.AI.PerfCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC76EECE3} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.AI.ServerTelemetryChannel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6BBF2CB9} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.AI.WindowsServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB003C809C} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.ApplicationInsights.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB3D6DBB7} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB70637CB0} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.ApplicationInsights.NLogTarget.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD99C11D1} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.AspNetCore.Authentication.JwtBearer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2C52C3CD} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.AspNetCore.JsonPatch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEF25B198} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.AspNetCore.Mvc.NewtonsoftJson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4902823F} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.AspNetCore.Mvc.Versioning.ApiExplorer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0460D578} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.AspNetCore.Mvc.Versioning.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAED97E39} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Azure.Amqp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEECB3708} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Azure.KeyVault.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB55C20C5F} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Azure.KeyVault.WebKey.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA753C1B3} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Azure.ServiceBus.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB044D43CE} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB359D2131} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Bcl.AsyncInterfaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8C131B29} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCFCE686B} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCFBB4AFE} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB203061F8} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB82874999} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4DF33385} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB917FA105} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBB850D56} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.Diagnostics.HealthChecks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF4939796} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.FileProviders.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB224F66DC} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.FileProviders.Embedded.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0C1A7E13} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.Hosting.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA3FC887A} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF8C79AA1} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0C259211} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.Logging.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDCB4ECCF} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9015FD60} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC57DACF4} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1C5EF7D6} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBE586902} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Identity.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB52EB4ECE} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7728AF5A} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF44A0C40} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.IdentityModel.JsonWebTokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4F3EDE2F} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.IdentityModel.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB99416066} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.IdentityModel.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAE94E43C} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.IdentityModel.Protocols.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC720EABD} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.IdentityModel.Tokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF77C3C98} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.OpenApi.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE26FD4B0} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Rest.ClientRuntime.Azure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB69D9DCC2} 3: C:\Program Files (x86)\Blue Prism\License Manager\Microsoft.Rest.ClientRuntime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1B8C5667} 3: C:\Program Files (x86)\Blue Prism\License Manager\NewId.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB16E7D76C} 3: C:\Program Files (x86)\Blue Prism\License Manager\Newtonsoft.Json.Bson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB6FF73DF} 3: C:\Program Files (x86)\Blue Prism\License Manager\Newtonsoft.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEF2117CF} 3: C:\Program Files (x86)\Blue Prism\License Manager\NLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB4CDBEEE} 3: C:\Program Files (x86)\Blue Prism\License Manager\NLog.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB980FC672} 3: C:\Program Files (x86)\Blue Prism\License Manager\NLog.Targets.ElasticSearch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCADA20C0} 3: C:\Program Files (x86)\Blue Prism\License Manager\NLog.Web.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCC60EE28} 3: C:\Program Files (x86)\Blue Prism\License Manager\NWebsec.AspNetCore.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5609D984} 3: C:\Program Files (x86)\Blue Prism\License Manager\NWebsec.AspNetCore.Middleware.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8D93756D} 3: C:\Program Files (x86)\Blue Prism\License Manager\OpenTelemetry.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA84EA89C} 3: C:\Program Files (x86)\Blue Prism\License Manager\OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB10B68842} 3: C:\Program Files (x86)\Blue Prism\License Manager\OpenTelemetry.Contrib.Instrumentation.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF94C546B} 3: C:\Program Files (x86)\Blue Prism\License Manager\OpenTelemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7A9B408F} 3: C:\Program Files (x86)\Blue Prism\License Manager\OpenTelemetry.Exporter.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2DC37EEC} 3: C:\Program Files (x86)\Blue Prism\License Manager\OpenTelemetry.Exporter.Jaeger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2F39E705} 3: C:\Program Files (x86)\Blue Prism\License Manager\OpenTelemetry.Exporter.OpenTelemetryProtocol.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB41BCABD7} 3: C:\Program Files (x86)\Blue Prism\License Manager\OpenTelemetry.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9ECA1121} 3: C:\Program Files (x86)\Blue Prism\License Manager\OpenTelemetry.Instrumentation.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2564D999} 3: C:\Program Files (x86)\Blue Prism\License Manager\OpenTelemetry.Instrumentation.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB553A426A} 3: C:\Program Files (x86)\Blue Prism\License Manager\OpenTelemetry.Instrumentation.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB64E05224} 3: C:\Program Files (x86)\Blue Prism\License Manager\RabbitMQ.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB29F1CB80} 3: C:\Program Files (x86)\Blue Prism\License Manager\Swashbuckle.AspNetCore.Annotations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB86AE0524} 3: C:\Program Files (x86)\Blue Prism\License Manager\Swashbuckle.AspNetCore.Swagger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB30797903} 3: C:\Program Files (x86)\Blue Prism\License Manager\Swashbuckle.AspNetCore.SwaggerGen.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6C2FDE6F} 3: C:\Program Files (x86)\Blue Prism\License Manager\Swashbuckle.AspNetCore.SwaggerUI.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB92AA7E73} 3: C:\Program Files (x86)\Blue Prism\License Manager\System.Configuration.ConfigurationManager.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC14621BF} 3: C:\Program Files (x86)\Blue Prism\License Manager\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB11196C35} 3: C:\Program Files (x86)\Blue Prism\License Manager\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB16A9AE56} 3: C:\Program Files (x86)\Blue Prism\License Manager\System.IdentityModel.Tokens.Jwt.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB08B68465} 3: C:\Program Files (x86)\Blue Prism\License Manager\System.Memory.Data.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB03031E1B} 3: C:\Program Files (x86)\Blue Prism\License Manager\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC7C2F333} 3: C:\Program Files (x86)\Blue Prism\License Manager\System.Runtime.CompilerServices.Unsafe.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB00D2392E} 3: C:\Program Files (x86)\Blue Prism\License Manager\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB825E8633} 3: C:\Program Files (x86)\Blue Prism\License Manager\System.Text.Encodings.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB114EA1E0} 3: C:\Program Files (x86)\Blue Prism\License Manager\System.Text.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD44780A3} 3: C:\Program Files (x86)\Blue Prism\License Manager\System.Threading.Channels.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB9A94C54} 3: C:\Program Files (x86)\Blue Prism\License Manager\Web.config
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5AA64113} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\BPC.LicenseManager.Migrator.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6A632373} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\BPC.LicenseManager.Migrator.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB21314090} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\BPC.LicenseManager.Migrator.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC09EE04A} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\BPC.LicenseManager.Migrator.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB266AC5F4} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\CommandLine.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB46A7C059} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\dbup-core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD0375E79} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\dbup-sqlserver.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5BEEAE40} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\MediatR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2DD53612} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\MediatR.Extensions.Microsoft.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE078DD41} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC16BAFD1} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCF38FF77} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4E24ED00} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4B64D3A5} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF2FE13E3} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB80247A48} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB75E79371} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\Microsoft.Extensions.Logging.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4643B0E8} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\Microsoft.Extensions.Logging.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBCF0CE55} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE567911B} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB99338C38} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB82E6AA24} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF109943C} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAEBB5D19} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE0649BF2} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB36E5F5DD} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\System.Text.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB369ADA9A} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\runtimes\unix\lib\netcoreapp2.1\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBB2666E0} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\runtimes\win\lib\netcoreapp2.1\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFA16B5FF} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\runtimes\win-arm64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB399EC4A9} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\runtimes\win-x64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3FF37591} 3: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\runtimes\win-x86\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB92F59ACF} 3: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\unix\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3C16A76F} 3: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\unix\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCD1E370C} 3: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\win\lib\netcoreapp2.0\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB90C8459} 3: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\win\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAE99310B} 3: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\win\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB967DE63} 3: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\win\lib\netstandard2.0\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9D6A4750} 3: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\win-arm64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB074299F0} 3: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\win-x64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB23322706} 3: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\win-x86\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4AF10505} 3: C:\Program Files (x86)\Blue Prism\Log Service\appsettings.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB01E434D4} 3: C:\Program Files (x86)\Blue Prism\Log Service\BPC.Logger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB61527AB0} 3: C:\Program Files (x86)\Blue Prism\Log Service\BPC.WindowsLogsGathererWorkerService.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF95A1915} 3: C:\Program Files (x86)\Blue Prism\Log Service\BPC.WindowsLogsGathererWorkerService.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1D9F8603} 3: C:\Program Files (x86)\Blue Prism\Log Service\BPC.WindowsLogsGathererWorkerService.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB033AB60D} 3: C:\Program Files (x86)\Blue Prism\Log Service\BPC.WindowsLogsGathererWorkerService.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC286BE1B} 3: C:\Program Files (x86)\Blue Prism\Log Service\Elasticsearch.Net.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB4996EBD} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8793AF38} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.ApplicationInsights.NLogTarget.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC96CF312} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE544687F} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFD92223A} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Configuration.CommandLine.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE339D3A4} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB67E3666F} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Configuration.EnvironmentVariables.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB74290667} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Configuration.FileExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD2E74F19} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Configuration.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFA0EC4E1} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Configuration.UserSecrets.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB54F0B75B} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC5050170} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA6605439} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.FileProviders.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCAEA6327} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.FileProviders.Physical.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD9A363B2} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.FileSystemGlobbing.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0C9EE486} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Hosting.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0EDBB77D} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1F58C138} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Hosting.WindowsServices.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCBD0EE61} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5E9C79DD} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Logging.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBFBE1D6C} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Logging.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB15E0D1BE} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Logging.Debug.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDC41464C} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6E9E1DCD} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Logging.EventLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2F03CEC8} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Logging.EventSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB431ABFD} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA241880B} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBBA9762C} 3: C:\Program Files (x86)\Blue Prism\Log Service\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1A26B0FF} 3: C:\Program Files (x86)\Blue Prism\Log Service\Newtonsoft.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB219F8200} 3: C:\Program Files (x86)\Blue Prism\Log Service\NLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1A757289} 3: C:\Program Files (x86)\Blue Prism\Log Service\NLog.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB77C2FEE7} 3: C:\Program Files (x86)\Blue Prism\Log Service\NLog.Targets.ElasticSearch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF20322FC} 3: C:\Program Files (x86)\Blue Prism\Log Service\NLog.Web.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA41C1B56} 3: C:\Program Files (x86)\Blue Prism\Log Service\System.ServiceProcess.ServiceController.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB4F6B204} 3: C:\Program Files (x86)\Blue Prism\Log Service\runtimes\win\lib\netstandard2.0\System.ServiceProcess.ServiceController.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB07EBEAA8} 3: C:\Program Files (x86)\Blue Prism\Notification Center\appsettings.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE743AD2B} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Automatonymous.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAFFE727B} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Azure.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7924DD53} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Azure.Monitor.OpenTelemetry.Exporter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB79063536} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.Contracts.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6865DACB} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB80E2BCB0} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.Extensions.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9D13DCF2} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.Extensions.Middleware.ExceptionHandler.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF5E68B51} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.Extensions.Tasks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB40F2DF0B} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.Extensions.Telemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2D01F288} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.Logger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB97CBFE62} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.Messaging.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9D01C654} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.NotificationCenter.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB885914ED} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.NotificationCenter.BusinessLogic.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB83BEF98C} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.NotificationCenter.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEF1D9490} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.NotificationCenter.DataAccess.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA5489206} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.NotificationCenter.Messages.Commands.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF1EB35A5} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.NotificationCenter.Web.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC2733813} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.NotificationCenter.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1A791BBB} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.NotificationCenter.Web.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB25366E2E} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.NotificationCenter.Web.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8F23A7AD} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.SettingsProtection.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5B830705} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.SettingsProtection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE1CC86A5} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.SettingsProtection.Services.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8AAFAF48} 3: C:\Program Files (x86)\Blue Prism\Notification Center\BPC.SignalR.Messages.Commands.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAD32DAB9} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Dapper.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC7300435} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Elasticsearch.Net.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9D6BA2F2} 3: C:\Program Files (x86)\Blue Prism\Notification Center\FluentValidation.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB69E164CA} 3: C:\Program Files (x86)\Blue Prism\Notification Center\FluentValidation.DependencyInjectionExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB219A8E77} 3: C:\Program Files (x86)\Blue Prism\Notification Center\FluentValidation.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3B20E600} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Google.Protobuf.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFBAD5393} 3: C:\Program Files (x86)\Blue Prism\Notification Center\GreenPipes.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA0E6A962} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Grpc.Core.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4FBA3DC0} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Grpc.Net.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB085262A9} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Grpc.Net.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0A226926} 3: C:\Program Files (x86)\Blue Prism\Notification Center\HealthChecks.IdSvr.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB535FC54A} 3: C:\Program Files (x86)\Blue Prism\Notification Center\HealthChecks.RabbitMQ.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0BAF37A8} 3: C:\Program Files (x86)\Blue Prism\Notification Center\HealthChecks.SqlServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1C5A1110} 3: C:\Program Files (x86)\Blue Prism\Notification Center\MassTransit.AspNetCoreIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAC8074B1} 3: C:\Program Files (x86)\Blue Prism\Notification Center\MassTransit.Azure.ServiceBus.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2E7135D6} 3: C:\Program Files (x86)\Blue Prism\Notification Center\MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB43D09798} 3: C:\Program Files (x86)\Blue Prism\Notification Center\MassTransit.ExtensionsDependencyInjectionIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD6CEC36E} 3: C:\Program Files (x86)\Blue Prism\Notification Center\MassTransit.Platform.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4D4B880C} 3: C:\Program Files (x86)\Blue Prism\Notification Center\MassTransit.RabbitMqTransport.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5541B39C} 3: C:\Program Files (x86)\Blue Prism\Notification Center\MassTransit.SignalR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA56777C4} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.AI.DependencyCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD4B194D7} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.AI.EventCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF567A13A} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.AI.PerfCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB46894EED} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.AI.ServerTelemetryChannel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2A98BF9C} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.AI.WindowsServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAB08C83B} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.ApplicationInsights.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB44FC929D} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD0FD309B} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.ApplicationInsights.NLogTarget.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9D50714C} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.AspNetCore.Authentication.JwtBearer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDD23BE58} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.AspNetCore.JsonPatch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5AB2F676} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.AspNetCore.Mvc.NewtonsoftJson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE22BD3B1} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Azure.Amqp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBCF9A4D0} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Azure.KeyVault.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB947176E6} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Azure.KeyVault.WebKey.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE9EBB4D6} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Azure.ServiceBus.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB26C358BA} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB144B1EDD} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Bcl.AsyncInterfaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB11E1E3DD} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Bcl.HashCode.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB78F4BE14} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB824DFA66} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB91A911D2} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3AA8F8AC} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB73F69287} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0DF24B3E} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB301F1C83} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA86CC690} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.Diagnostics.HealthChecks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE28BFC18} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.FileProviders.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB34F2E359} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.Hosting.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA0806632} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE9C7387B} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.Localization.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBCFDDEA5} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.Localization.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF43000F4} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB25EEAE0C} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.Logging.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA3DACD77} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA9225164} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA0F96D84} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4C6737A6} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB44424953} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Identity.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB09EA987C} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCA113908} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB53CB5A25} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.IdentityModel.JsonWebTokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5E741C2D} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.IdentityModel.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8DADB3F0} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.IdentityModel.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1802BEA8} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.IdentityModel.Protocols.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB8E6DCD5} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.IdentityModel.Tokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB4CD0995} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.OpenApi.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD3495FE6} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Rest.ClientRuntime.Azure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB848EDA5D} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Microsoft.Rest.ClientRuntime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB54B10136} 3: C:\Program Files (x86)\Blue Prism\Notification Center\NewId.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB43C27275} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Newtonsoft.Json.Bson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD2F5E87F} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Newtonsoft.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE3C78B6B} 3: C:\Program Files (x86)\Blue Prism\Notification Center\NLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB74DCD719} 3: C:\Program Files (x86)\Blue Prism\Notification Center\NLog.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB04FC1F3A} 3: C:\Program Files (x86)\Blue Prism\Notification Center\NLog.Targets.ElasticSearch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB33CF6A61} 3: C:\Program Files (x86)\Blue Prism\Notification Center\NLog.Web.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB29B63E7} 3: C:\Program Files (x86)\Blue Prism\Notification Center\NWebsec.AspNetCore.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB410286F8} 3: C:\Program Files (x86)\Blue Prism\Notification Center\NWebsec.AspNetCore.Middleware.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE08965DD} 3: C:\Program Files (x86)\Blue Prism\Notification Center\OpenTelemetry.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD4CCEC88} 3: C:\Program Files (x86)\Blue Prism\Notification Center\OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1C1C856E} 3: C:\Program Files (x86)\Blue Prism\Notification Center\OpenTelemetry.Contrib.Instrumentation.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDED7563D} 3: C:\Program Files (x86)\Blue Prism\Notification Center\OpenTelemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5FB28826} 3: C:\Program Files (x86)\Blue Prism\Notification Center\OpenTelemetry.Exporter.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB111A2DD6} 3: C:\Program Files (x86)\Blue Prism\Notification Center\OpenTelemetry.Exporter.Jaeger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDCAF345B} 3: C:\Program Files (x86)\Blue Prism\Notification Center\OpenTelemetry.Exporter.OpenTelemetryProtocol.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3AE9C274} 3: C:\Program Files (x86)\Blue Prism\Notification Center\OpenTelemetry.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA0406252} 3: C:\Program Files (x86)\Blue Prism\Notification Center\OpenTelemetry.Instrumentation.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDE48AF26} 3: C:\Program Files (x86)\Blue Prism\Notification Center\OpenTelemetry.Instrumentation.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB04B83E45} 3: C:\Program Files (x86)\Blue Prism\Notification Center\OpenTelemetry.Instrumentation.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB802244AB} 3: C:\Program Files (x86)\Blue Prism\Notification Center\RabbitMQ.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB2C1C1DE} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Swashbuckle.AspNetCore.Annotations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC2C88252} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Swashbuckle.AspNetCore.Swagger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE4108569} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Swashbuckle.AspNetCore.SwaggerGen.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3F1CC2CC} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Swashbuckle.AspNetCore.SwaggerUI.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB21EF577E} 3: C:\Program Files (x86)\Blue Prism\Notification Center\System.ComponentModel.Annotations.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB025594F3} 3: C:\Program Files (x86)\Blue Prism\Notification Center\System.Configuration.ConfigurationManager.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5731F594} 3: C:\Program Files (x86)\Blue Prism\Notification Center\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4880A664} 3: C:\Program Files (x86)\Blue Prism\Notification Center\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB210F1F50} 3: C:\Program Files (x86)\Blue Prism\Notification Center\System.IdentityModel.Tokens.Jwt.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCDCEBF8E} 3: C:\Program Files (x86)\Blue Prism\Notification Center\System.Memory.Data.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8D9F85F8} 3: C:\Program Files (x86)\Blue Prism\Notification Center\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBCDDCA65} 3: C:\Program Files (x86)\Blue Prism\Notification Center\System.Runtime.CompilerServices.Unsafe.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB70919324} 3: C:\Program Files (x86)\Blue Prism\Notification Center\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBE9CE939} 3: C:\Program Files (x86)\Blue Prism\Notification Center\System.Text.Encodings.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9E67E5C3} 3: C:\Program Files (x86)\Blue Prism\Notification Center\System.Text.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6801A53C} 3: C:\Program Files (x86)\Blue Prism\Notification Center\System.Threading.Channels.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDB510D81} 3: C:\Program Files (x86)\Blue Prism\Notification Center\web.config
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7D1E68D1} 3: C:\Program Files (x86)\Blue Prism\Notification Center\de\BPC.NotificationCenter.Core.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB65A903FE} 3: C:\Program Files (x86)\Blue Prism\Notification Center\es\BPC.NotificationCenter.Core.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9BA64B0B} 3: C:\Program Files (x86)\Blue Prism\Notification Center\fr\BPC.NotificationCenter.Core.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB54872661} 3: C:\Program Files (x86)\Blue Prism\Notification Center\ja\BPC.NotificationCenter.Core.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3A8B797A} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\BPC.NotificationCenter.Migrator.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB04BB925F} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\BPC.NotificationCenter.Migrator.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEAF56D94} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\BPC.NotificationCenter.Migrator.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB621AFFFB} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\BPC.NotificationCenter.Migrator.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB746214DD} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\CommandLine.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFC28F46D} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\dbup-core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB70968453} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\dbup-sqlserver.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4EF5B8D8} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\MediatR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB86AA9F9C} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\MediatR.Extensions.Microsoft.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE63D6C5D} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDFB40280} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAEA978EA} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB70FC69B6} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0E41FA70} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0C381F47} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB50B82DF4} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEA25A9F2} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\Microsoft.Extensions.Logging.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB411D5CDA} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\Microsoft.Extensions.Logging.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB590E48C5} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB094A801B} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB98643D01} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB43D64486} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB78E9F18C} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB51CD4550} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEA2D487B} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEC1F4F5E} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\System.Text.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA133F8F3} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\runtimes\unix\lib\netcoreapp2.1\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCFD7E1CB} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\runtimes\win\lib\netcoreapp2.1\System.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB935300CA} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\runtimes\win-arm64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9C26428A} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\runtimes\win-x64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB74FE8519} 3: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\runtimes\win-x86\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB550489D7} 3: C:\Program Files (x86)\Blue Prism\Notification Center\pt\BPC.NotificationCenter.Core.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE0C8D757} 3: C:\Program Files (x86)\Blue Prism\Notification Center\ru\BPC.NotificationCenter.Core.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC6B8363B} 3: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\unix\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB24DD5596} 3: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\unix\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB34790B85} 3: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\win\lib\netcoreapp2.0\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD5CB16E2} 3: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\win\lib\netcoreapp2.0\System.Runtime.Caching.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB77C3D0E} 3: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\win\lib\netcoreapp2.1\Microsoft.Data.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB187BB31D} 3: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\win\lib\netstandard2.0\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE283859D} 3: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\win-arm64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7ED85081} 3: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\win-x64\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB43E28DB8} 3: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\win-x86\native\sni.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA9AA6098} 3: C:\Program Files (x86)\Blue Prism\Notification Center\SqlScripts\SqlScripts.resx
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB547EAD88} 3: C:\Program Files (x86)\Blue Prism\Notification Center\zh\BPC.NotificationCenter.Core.resources.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB981D2EAA} 3: C:\Program Files (x86)\Blue Prism\SignalR\appsettings.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB17D153DE} 3: C:\Program Files (x86)\Blue Prism\SignalR\Automatonymous.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFE7240F4} 3: C:\Program Files (x86)\Blue Prism\SignalR\Azure.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB3691D19} 3: C:\Program Files (x86)\Blue Prism\SignalR\Azure.Monitor.OpenTelemetry.Exporter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBA23FAD2} 3: C:\Program Files (x86)\Blue Prism\SignalR\BPC.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC35B544D} 3: C:\Program Files (x86)\Blue Prism\SignalR\BPC.Extensions.Middleware.ExceptionHandler.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB038B0313} 3: C:\Program Files (x86)\Blue Prism\SignalR\BPC.Extensions.Telemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB2557B578} 3: C:\Program Files (x86)\Blue Prism\SignalR\BPC.Logger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8FF852D3} 3: C:\Program Files (x86)\Blue Prism\SignalR\BPC.Messaging.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD8227519} 3: C:\Program Files (x86)\Blue Prism\SignalR\BPC.SettingsProtection.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB00A7EB5F} 3: C:\Program Files (x86)\Blue Prism\SignalR\BPC.SettingsProtection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB545F221B} 3: C:\Program Files (x86)\Blue Prism\SignalR\BPC.SettingsProtection.Services.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEAE53A53} 3: C:\Program Files (x86)\Blue Prism\SignalR\BPC.SignalR.deps.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDD2984DC} 3: C:\Program Files (x86)\Blue Prism\SignalR\BPC.SignalR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB96C6396E} 3: C:\Program Files (x86)\Blue Prism\SignalR\BPC.SignalR.exe
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB92F29173} 3: C:\Program Files (x86)\Blue Prism\SignalR\BPC.SignalR.Messages.Commands.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBBB9C557} 3: C:\Program Files (x86)\Blue Prism\SignalR\BPC.SignalR.runtimeconfig.json
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB494537A} 3: C:\Program Files (x86)\Blue Prism\SignalR\Elasticsearch.Net.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB786E2C27} 3: C:\Program Files (x86)\Blue Prism\SignalR\Google.Protobuf.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB36184D24} 3: C:\Program Files (x86)\Blue Prism\SignalR\GreenPipes.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB360EA903} 3: C:\Program Files (x86)\Blue Prism\SignalR\Grpc.Core.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE1E4C110} 3: C:\Program Files (x86)\Blue Prism\SignalR\Grpc.Net.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBECCDD606} 3: C:\Program Files (x86)\Blue Prism\SignalR\Grpc.Net.Common.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6307AE0D} 3: C:\Program Files (x86)\Blue Prism\SignalR\HealthChecks.IdSvr.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB100D53BA} 3: C:\Program Files (x86)\Blue Prism\SignalR\HealthChecks.RabbitMQ.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCB740AF6} 3: C:\Program Files (x86)\Blue Prism\SignalR\MassTransit.AspNetCoreIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB440FB0AB} 3: C:\Program Files (x86)\Blue Prism\SignalR\MassTransit.Azure.ServiceBus.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1810A937} 3: C:\Program Files (x86)\Blue Prism\SignalR\MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB838A47FF} 3: C:\Program Files (x86)\Blue Prism\SignalR\MassTransit.ExtensionsDependencyInjectionIntegration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC54ECD0C} 3: C:\Program Files (x86)\Blue Prism\SignalR\MassTransit.Platform.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB29B5436C} 3: C:\Program Files (x86)\Blue Prism\SignalR\MassTransit.RabbitMqTransport.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0DA1CB64} 3: C:\Program Files (x86)\Blue Prism\SignalR\MassTransit.SignalR.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB22639A8E} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.AI.DependencyCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB54492B7B} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.AI.EventCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB538C5FB4} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.AI.PerfCounterCollector.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7F3301EF} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.AI.ServerTelemetryChannel.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD7736801} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.AI.WindowsServer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB38BC77D8} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.ApplicationInsights.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC907CA2F} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB20CFFAB7} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.ApplicationInsights.NLogTarget.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE2854D70} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.ApplicationInsights.WorkerService.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1844010B} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.AspNetCore.Authentication.JwtBearer.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD001296D} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.AspNetCore.Authentication.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8B10DD1F} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.AspNetCore.JsonPatch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB64C33CAC} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.AspNetCore.Mvc.NewtonsoftJson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB777303B3} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Azure.Amqp.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBEB3B4DC4} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Azure.KeyVault.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7F0BD7DC} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Azure.KeyVault.WebKey.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB6AA5E30E} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Azure.ServiceBus.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7F955836} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Azure.Services.AppAuthentication.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB4F201F9} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Bcl.AsyncInterfaces.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB26186F1D} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Extensions.Configuration.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9F066E88} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Extensions.Configuration.Binder.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7213DEEB} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Extensions.Configuration.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB69DDA5FC} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Extensions.DependencyInjection.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB70CC4FD5} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Extensions.DependencyInjection.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB807D4911} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5E81C714} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Extensions.Diagnostics.HealthChecks.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB421F617C} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Extensions.FileProviders.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF406C67D} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Extensions.Hosting.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8C4B1F58} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Extensions.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1B42358C} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Extensions.Logging.Abstractions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC1639646} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Extensions.Logging.ApplicationInsights.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB827BD117} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB53E4D4E4} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Extensions.Options.ConfigurationExtensions.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5C13CAA6} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Extensions.Options.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB131F08F8} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Extensions.Primitives.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB559067A0} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.IdentityModel.Clients.ActiveDirectory.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4DBA6746} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB19154418} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.IdentityModel.JsonWebTokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9A659FBB} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.IdentityModel.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB3654141B} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.IdentityModel.Protocols.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB7A00E78B} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.IdentityModel.Protocols.OpenIdConnect.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE70D68AE} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.IdentityModel.Tokens.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB81C0FF74} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Rest.ClientRuntime.Azure.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB06BB9882} 3: C:\Program Files (x86)\Blue Prism\SignalR\Microsoft.Rest.ClientRuntime.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCDA5BD9F} 3: C:\Program Files (x86)\Blue Prism\SignalR\NewId.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA3ECC542} 3: C:\Program Files (x86)\Blue Prism\SignalR\Newtonsoft.Json.Bson.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC6D0282A} 3: C:\Program Files (x86)\Blue Prism\SignalR\Newtonsoft.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBF44A7A94} 3: C:\Program Files (x86)\Blue Prism\SignalR\NLog.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5FC50489} 3: C:\Program Files (x86)\Blue Prism\SignalR\NLog.Extensions.Logging.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA273ED7B} 3: C:\Program Files (x86)\Blue Prism\SignalR\NLog.Targets.ElasticSearch.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0AE45B54} 3: C:\Program Files (x86)\Blue Prism\SignalR\NLog.Web.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD4139C25} 3: C:\Program Files (x86)\Blue Prism\SignalR\NWebsec.AspNetCore.Core.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC0E9E910} 3: C:\Program Files (x86)\Blue Prism\SignalR\NWebsec.AspNetCore.Middleware.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE4A2735D} 3: C:\Program Files (x86)\Blue Prism\SignalR\OpenTelemetry.Api.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBE097BFFD} 3: C:\Program Files (x86)\Blue Prism\SignalR\OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5A4AF795} 3: C:\Program Files (x86)\Blue Prism\SignalR\OpenTelemetry.Contrib.Instrumentation.MassTransit.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB550F33DA} 3: C:\Program Files (x86)\Blue Prism\SignalR\OpenTelemetry.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBAB5DD9A3} 3: C:\Program Files (x86)\Blue Prism\SignalR\OpenTelemetry.Exporter.Console.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBC10BE6CA} 3: C:\Program Files (x86)\Blue Prism\SignalR\OpenTelemetry.Exporter.Jaeger.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB1560DE7A} 3: C:\Program Files (x86)\Blue Prism\SignalR\OpenTelemetry.Exporter.OpenTelemetryProtocol.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB9CFA8265} 3: C:\Program Files (x86)\Blue Prism\SignalR\OpenTelemetry.Extensions.Hosting.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFAD83578} 3: C:\Program Files (x86)\Blue Prism\SignalR\OpenTelemetry.Instrumentation.AspNetCore.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4ADFAD90} 3: C:\Program Files (x86)\Blue Prism\SignalR\OpenTelemetry.Instrumentation.Http.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBFDAB546D} 3: C:\Program Files (x86)\Blue Prism\SignalR\OpenTelemetry.Instrumentation.SqlClient.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBBCD415E6} 3: C:\Program Files (x86)\Blue Prism\SignalR\RabbitMQ.Client.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBB69B2B10} 3: C:\Program Files (x86)\Blue Prism\SignalR\System.Configuration.ConfigurationManager.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCF3233B1} 3: C:\Program Files (x86)\Blue Prism\SignalR\System.Diagnostics.DiagnosticSource.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD31296A9} 3: C:\Program Files (x86)\Blue Prism\SignalR\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB8BE2D993} 3: C:\Program Files (x86)\Blue Prism\SignalR\System.IdentityModel.Tokens.Jwt.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBA7640DF6} 3: C:\Program Files (x86)\Blue Prism\SignalR\System.Memory.Data.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB141AD37A} 3: C:\Program Files (x86)\Blue Prism\SignalR\System.Net.WebSockets.WebSocketProtocol.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB0CCF6C6A} 3: C:\Program Files (x86)\Blue Prism\SignalR\System.Runtime.CompilerServices.Unsafe.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB304A185D} 3: C:\Program Files (x86)\Blue Prism\SignalR\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB59702CE8} 3: C:\Program Files (x86)\Blue Prism\SignalR\System.Text.Encodings.Web.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB4E9B0619} 3: C:\Program Files (x86)\Blue Prism\SignalR\System.Text.Json.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCE58DD1D} 3: C:\Program Files (x86)\Blue Prism\SignalR\System.Threading.Channels.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDD899FB3} 3: C:\Program Files (x86)\Blue Prism\SignalR\Web.config
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBCC44E8DE} 3: C:\Program Files (x86)\Blue Prism\SignalR\runtimes\win\lib\netcoreapp2.0\System.Diagnostics.PerformanceCounter.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBDE461FAF} 3: C:\Program Files (x86)\Blue Prism\SignalR\runtimes\win\lib\netstandard2.0\System.Security.Cryptography.ProtectedData.dll
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECB5DCF9B50} 3: C:\Program Files (x86)\
ActionData: 1: {1D0E3189-5DF1-4D4A-8D1B-DECBA012CD35} 2: {1D0E3189-5DF1-4D4A-8D1B-DECBD3823D44} 3: D:\
ActionStart: Action 14:35:42: StopServices. Stopping services
ActionStart: Action 14:35:42: CreateFolders. Creating folders
ActionData: Folder: C:\Program Files (x86)\Blue Prism\
ActionData: Folder: D:\
ActionStart: Action 14:35:42: InstallFiles. Copying new files
ActionData: File: 2.a1570274.chunk.css.map, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\css\, Size: 40093
ActionData: File: 2.a1570274.chunk.css, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\css\, Size: 22997
ActionData: File: 2.a9e6f5ab.chunk.js.LICENSE.txt, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\js\, Size: 4029
ActionData: File: 2.a9e6f5ab.chunk.js.map, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\js\, Size: 11827549
ActionData: File: 2.a9e6f5ab.chunk.js, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\js\, Size: 3300920
ActionData: File: [Cache]-001-Table-Cache-Create.sql, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Scripts\Cache\, Size: 512
ActionData: File: [Cache]-001-Table-Cache-Create.sql, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Scripts\, Size: 1040
ActionData: File: [Cache]-001-Table-Cache-Create.sql, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\Scripts\Cache\, Size: 512
ActionData: File: [Files]-001-Table-Files-Create.sql, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Scripts\, Size: 940
ActionData: File: [Files]-002-Set-Unique-To-Column-Ident-Of-Table-Files.sql, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Scripts\, Size: 110
ActionData: File: AddEmailSender.sql, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Scripts\Senders\, Size: 152
ActionData: File: AddFile.sql, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Scripts\Single\, Size: 208
ActionData: File: appsettings.json, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 508
ActionData: File: appsettings.json, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 4830
ActionData: File: appsettings.json, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 4730
ActionData: File: appsettings.json, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 23086
ActionData: File: appsettings.json, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 966
ActionData: File: appsettings.json, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 1382
ActionData: File: appsettings.json, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 947
ActionData: File: appsettings.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 12482
ActionData: File: appsettings.json, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 1192
ActionData: File: appsettings.json, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 1470
ActionData: File: AspNetCore.Proxy.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 43520
ActionData: File: asset-manifest.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\, Size: 1544
ActionData: File: AuditDB.sql, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Scripts\, Size: 2666
ActionData: File: auth-server-de.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\auth-server\de\, Size: 2362
ActionData: File: auth-server-en.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\auth-server\en\, Size: 2089
ActionData: File: auth-server-es.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\auth-server\es\, Size: 2416
ActionData: File: auth-server-fr.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\auth-server\fr\, Size: 2503
ActionData: File: auth-server-ja.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\auth-server\ja\, Size: 2682
ActionData: File: auth-server-pt.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\auth-server\pt\, Size: 2140
ActionData: File: auth-server-ru.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\auth-server\ru\, Size: 3062
ActionData: File: auth-server-zh.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\auth-server\zh\, Size: 2007
ActionData: File: AutoMapper.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 288768
ActionData: File: AutoMapper.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 288768
ActionData: File: Automatonymous.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 252416
ActionData: File: Automatonymous.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 252416
ActionData: File: Automatonymous.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 252416
ActionData: File: Automatonymous.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 252416
ActionData: File: Automatonymous.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 252416
ActionData: File: Automatonymous.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 252416
ActionData: File: Automatonymous.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 252416
ActionData: File: Automatonymous.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 252416
ActionData: File: Automatonymous.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 252416
ActionData: File: Automatonymous.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 252416
ActionData: File: Automatonymous.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 252416
ActionData: File: Automatonymous.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 252416
ActionData: File: Azure.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 220024
ActionData: File: Azure.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 220024
ActionData: File: Azure.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 127864
ActionData: File: Azure.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 220024
ActionData: File: Azure.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 220024
ActionData: File: Azure.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 220024
ActionData: File: Azure.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 220024
ActionData: File: Azure.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 220024
ActionData: File: Azure.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 220024
ActionData: File: Azure.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 150408
ActionData: File: Azure.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 220024
ActionData: File: Azure.Identity.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 213888
ActionData: File: Azure.Monitor.OpenTelemetry.Exporter.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 179080
ActionData: File: Azure.Monitor.OpenTelemetry.Exporter.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 179080
ActionData: File: Azure.Monitor.OpenTelemetry.Exporter.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 179080
ActionData: File: Azure.Monitor.OpenTelemetry.Exporter.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 179080
ActionData: File: Azure.Monitor.OpenTelemetry.Exporter.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 179080
ActionData: File: Azure.Monitor.OpenTelemetry.Exporter.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 179080
ActionData: File: Azure.Monitor.OpenTelemetry.Exporter.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 179080
ActionData: File: Azure.Monitor.OpenTelemetry.Exporter.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 179080
ActionData: File: Azure.Monitor.OpenTelemetry.Exporter.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 179080
ActionData: File: Azure.Storage.Blobs.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 598920
ActionData: File: Azure.Storage.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 67448
ActionData: File: Azure.Storage.Queues.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 200568
ActionData: File: BluePrism.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 106544
ActionData: File: BluePrism.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 106544
ActionData: File: BluePrismCloud.ExtCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 21496
ActionData: File: BluePrismCloud.ExtCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 21496
ActionData: File: BouncyCastle.Crypto.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 2905648
ActionData: File: BPC.Audit.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 18944
ActionData: File: BPC.Audit.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 18944
ActionData: File: BPC.Audit.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 18944
ActionData: File: BPC.Audit.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 18944
ActionData: File: BPC.Audit.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 21464
ActionData: File: BPC.Audit.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 21464
ActionData: File: BPC.Audit.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 19416
ActionData: File: BPC.AuditService.deps.json, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 180304
ActionData: File: BPC.AuditService.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 32232
ActionData: File: BPC.AuditService.exe, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 181200
ActionData: File: BPC.AuditService.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 157
ActionData: File: BPC.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 19424
ActionData: File: BPC.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 18912
ActionData: File: BPC.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 18912
ActionData: File: BPC.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 19424
ActionData: File: BPC.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 19424
ActionData: File: BPC.Contracts.InteractForms.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 20480
ActionData: File: BPC.Contracts.InteractForms.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 20480
ActionData: File: BPC.Data.Sql.Encryption.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 15024
ActionData: File: BPC.Data.Sql.Encryption.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 15024
ActionData: File: BPC.EmailService.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 17408
ActionData: File: BPC.EmailService.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 17408
ActionData: File: BPC.EmailService.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 17408
ActionData: File: BPC.EmailService.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 12272
ActionData: File: BPC.EmailService.Data.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 20464
ActionData: File: BPC.EmailService.Logic.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 32248
ActionData: File: BPC.EmailService.Messages.Commands.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 6144
ActionData: File: BPC.EmailService.Messages.Commands.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 6144
ActionData: File: BPC.EmailService.Messages.Commands.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 6144
ActionData: File: BPC.EmailService.Migrator.deps.json, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 89231
ActionData: File: BPC.EmailService.Migrator.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 18936
ActionData: File: BPC.EmailService.Migrator.exe, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 181224
ActionData: File: BPC.EmailService.Migrator.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 154
ActionData: File: BPC.EmailService.Web.deps.json, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 317204
ActionData: File: BPC.EmailService.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 41968
ActionData: File: BPC.EmailService.Web.exe, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 174592
ActionData: File: BPC.EmailService.Web.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 224
ActionData: File: BPC.Extensions.ActionResults.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 14544
ActionData: File: BPC.Extensions.ActionResults.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 14528
ActionData: File: BPC.Extensions.ActionResults.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 14544
ActionData: File: BPC.Extensions.ActionResults.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 13512
ActionData: File: BPC.Extensions.ActionResults.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 13016
ActionData: File: BPC.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 13528
ActionData: File: BPC.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 13840
ActionData: File: BPC.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 13528
ActionData: File: BPC.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 13840
ActionData: File: BPC.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 13840
ActionData: File: BPC.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 13840
ActionData: File: BPC.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 13840
ActionData: File: BPC.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 13840
ActionData: File: BPC.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 13840
ActionData: File: BPC.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 13840
ActionData: File: BPC.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 13840
ActionData: File: BPC.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 13840
ActionData: File: BPC.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 13528
ActionData: File: BPC.Extensions.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 15032
ActionData: File: BPC.Extensions.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 15344
ActionData: File: BPC.Extensions.Linq.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 13496
ActionData: File: BPC.Extensions.Linq.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 13496
ActionData: File: BPC.Extensions.Middleware.ExceptionHandler.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 15392
ActionData: File: BPC.Extensions.Middleware.ExceptionHandler.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 15080
ActionData: File: BPC.Extensions.Middleware.ExceptionHandler.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 15392
ActionData: File: BPC.Extensions.Middleware.ExceptionHandler.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 15392
ActionData: File: BPC.Extensions.Middleware.ExceptionHandler.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 15080
ActionData: File: BPC.Extensions.Middleware.ExceptionHandler.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 15392
ActionData: File: BPC.Extensions.Middleware.ExceptionHandler.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 15080
ActionData: File: BPC.Extensions.Middleware.ExceptionHandler.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 15392
ActionData: File: BPC.Extensions.String.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 11456
ActionData: File: BPC.Extensions.String.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 11456
ActionData: File: BPC.Extensions.Tasks.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 11456
ActionData: File: BPC.Extensions.Tasks.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 11456
ActionData: File: BPC.Extensions.Tasks.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 11760
ActionData: File: BPC.Extensions.Tasks.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 11760
ActionData: File: BPC.Extensions.Tasks.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 11456
ActionData: File: BPC.Extensions.Tasks.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 11456
ActionData: File: BPC.Extensions.Telemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 14848
ActionData: File: BPC.Extensions.Telemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 14848
ActionData: File: BPC.Extensions.Telemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 15360
ActionData: File: BPC.Extensions.Telemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 14848
ActionData: File: BPC.Extensions.Telemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 14848
ActionData: File: BPC.Extensions.Telemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 15360
ActionData: File: BPC.Extensions.Telemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 15360
ActionData: File: BPC.Extensions.Telemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 14848
ActionData: File: BPC.Extensions.Telemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 14848
ActionData: File: BPC.FileStorage.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 56808
ActionData: File: BPC.FileStorage.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 56808
ActionData: File: BPC.FileStorage.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 56808
ActionData: File: BPC.FileStorage.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 56808
ActionData: File: BPC.FileStorage.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 56808
ActionData: File: BPC.FileStorageApi.deps.json, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 349734
ActionData: File: BPC.FileStorageApi.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 45552
ActionData: File: BPC.FileStorageApi.exe, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 174592
ActionData: File: BPC.FileStorageApi.Migrator.deps.json, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 186590
ActionData: File: BPC.FileStorageApi.Migrator.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 1619968
ActionData: File: BPC.FileStorageApi.Migrator.exe, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 181224
ActionData: File: BPC.FileStorageApi.Migrator.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 154
ActionData: File: BPC.FileStorageApi.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 311
ActionData: File: BPC.Hub.Messages.Commands.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 8704
ActionData: File: BPC.Hub.Messages.Commands.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 8192
ActionData: File: BPC.Iada.Messages.Commands.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 6656
ActionData: File: BPC.Ims.Messages.Commands.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 6656
ActionData: File: BPC.Ims.Messages.Commands.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 6656
ActionData: File: BPC.IMS.Messages.Events.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 8704
ActionData: File: BPC.Interact.Messages.Commands.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 17408
ActionData: File: BPC.Interact.Messages.Commands.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 16896
ActionData: File: BPC.LicenseManager.BusinessLogic.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 28680
ActionData: File: BPC.LicenseManager.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 7168
ActionData: File: BPC.LicenseManager.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 12496
ActionData: File: BPC.LicenseManager.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 12496
ActionData: File: BPC.LicenseManager.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 13312
ActionData: File: BPC.LicenseManager.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 12280
ActionData: File: BPC.LicenseManager.DataAccess.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 23040
ActionData: File: BPC.LicenseManager.Logic.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 11264
ActionData: File: BPC.LicenseManager.Messages.Events.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 12816
ActionData: File: BPC.LicenseManager.Messages.Events.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 6144
ActionData: File: BPC.LicenseManager.Messages.Events.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 6144
ActionData: File: BPC.LicenseManager.Migrator.deps.json, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 87583
ActionData: File: BPC.LicenseManager.Migrator.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 13824
ActionData: File: BPC.LicenseManager.Migrator.exe, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 174592
ActionData: File: BPC.LicenseManager.Migrator.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 154
ActionData: File: BPC.LicenseManager.Web.deps.json, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 309542
ActionData: File: BPC.LicenseManager.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 51192
ActionData: File: BPC.LicenseManager.Web.exe, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 174592
ActionData: File: BPC.LicenseManager.Web.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 311
ActionData: File: BPC.Logger.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 16352
ActionData: File: BPC.Logger.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 16352
ActionData: File: BPC.Logger.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 16352
ActionData: File: BPC.Logger.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 16352
ActionData: File: BPC.Logger.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 16352
ActionData: File: BPC.Logger.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 16352
ActionData: File: BPC.Logger.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 16352
ActionData: File: BPC.Logger.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 16352
ActionData: File: BPC.Logger.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 16352
ActionData: File: BPC.Logger.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 16352
ActionData: File: BPC.Logger.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 16352
ActionData: File: BPC.Logger.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 13976
ActionData: File: BPC.Messaging.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 17408
ActionData: File: BPC.Messaging.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 17408
ActionData: File: BPC.Messaging.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 17408
ActionData: File: BPC.Messaging.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 17408
ActionData: File: BPC.Messaging.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 17408
ActionData: File: BPC.Messaging.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 17408
ActionData: File: BPC.Messaging.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 17408
ActionData: File: BPC.Messaging.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 17408
ActionData: File: BPC.Messaging.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 17408
ActionData: File: BPC.NotificationCenter.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 23056
ActionData: File: BPC.NotificationCenter.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 23056
ActionData: File: BPC.NotificationCenter.BusinessLogic.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 45584
ActionData: File: BPC.NotificationCenter.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 34304
ActionData: File: BPC.NotificationCenter.Core.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\zh\, Size: 11264
ActionData: File: BPC.NotificationCenter.Core.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\es\, Size: 11776
ActionData: File: BPC.NotificationCenter.Core.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\fr\, Size: 12288
ActionData: File: BPC.NotificationCenter.Core.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\ru\, Size: 10240
ActionData: File: BPC.NotificationCenter.Core.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\ja\, Size: 12288
ActionData: File: BPC.NotificationCenter.Core.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\pt\, Size: 9216
ActionData: File: BPC.NotificationCenter.Core.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\de\, Size: 11776
ActionData: File: BPC.NotificationCenter.DataAccess.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 73736
ActionData: File: BPC.NotificationCenter.Messages.Commands.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 8704
ActionData: File: BPC.NotificationCenter.Messages.Commands.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 8704
ActionData: File: BPC.NotificationCenter.Migrator.deps.json, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 87595
ActionData: File: BPC.NotificationCenter.Migrator.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 22024
ActionData: File: BPC.NotificationCenter.Migrator.exe, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 175104
ActionData: File: BPC.NotificationCenter.Migrator.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 154
ActionData: File: BPC.NotificationCenter.Web.deps.json, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 319564
ActionData: File: BPC.NotificationCenter.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 63488
ActionData: File: BPC.NotificationCenter.Web.exe, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 174592
ActionData: File: BPC.NotificationCenter.Web.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 311
ActionData: File: BPC.Repository.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 30184
ActionData: File: BPC.Repository.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 30184
ActionData: File: BPC.Repository.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 30184
ActionData: File: BPC.Repository.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 30184
ActionData: File: BPC.Search.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 11768
ActionData: File: BPC.Search.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 11768
ActionData: File: BPC.Search.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 38384
ActionData: File: BPC.Search.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 37360
ActionData: File: BPC.Search.Services.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 18928
ActionData: File: BPC.Search.Services.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 18928
ActionData: File: BPC.SettingsProtection.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 13824
ActionData: File: BPC.SettingsProtection.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 13824
ActionData: File: BPC.SettingsProtection.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 13824
ActionData: File: BPC.SettingsProtection.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 13824
ActionData: File: BPC.SettingsProtection.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 13824
ActionData: File: BPC.SettingsProtection.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 13824
ActionData: File: BPC.SettingsProtection.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 13824
ActionData: File: BPC.SettingsProtection.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 13824
ActionData: File: BPC.SettingsProtection.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 13824
ActionData: File: BPC.SettingsProtection.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 13824
ActionData: File: BPC.SettingsProtection.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 13824
ActionData: File: BPC.SettingsProtection.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 13824
ActionData: File: BPC.SettingsProtection.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 29176
ActionData: File: BPC.SettingsProtection.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 29176
ActionData: File: BPC.SettingsProtection.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 29176
ActionData: File: BPC.SettingsProtection.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 29176
ActionData: File: BPC.SettingsProtection.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 29176
ActionData: File: BPC.SettingsProtection.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 29176
ActionData: File: BPC.SettingsProtection.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 29176
ActionData: File: BPC.SettingsProtection.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 29176
ActionData: File: BPC.SettingsProtection.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 29176
ActionData: File: BPC.SettingsProtection.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 29176
ActionData: File: BPC.SettingsProtection.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 29176
ActionData: File: BPC.SettingsProtection.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 29176
ActionData: File: BPC.SettingsProtection.Services.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 11784
ActionData: File: BPC.SettingsProtection.Services.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 11784
ActionData: File: BPC.SettingsProtection.Services.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 11784
ActionData: File: BPC.SettingsProtection.Services.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 11784
ActionData: File: BPC.SettingsProtection.Services.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 11784
ActionData: File: BPC.SettingsProtection.Services.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 11784
ActionData: File: BPC.SettingsProtection.Services.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 11784
ActionData: File: BPC.SettingsProtection.Services.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 11784
ActionData: File: BPC.SettingsProtection.Services.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 11784
ActionData: File: BPC.SettingsProtection.Services.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 11784
ActionData: File: BPC.SettingsProtection.Services.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 11784
ActionData: File: BPC.SettingsProtection.Services.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 11784
ActionData: File: BPC.SignalR.deps.json, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 298145
ActionData: File: BPC.SignalR.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 53728
ActionData: File: BPC.SignalR.exe, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 174592
ActionData: File: BPC.SignalR.Messages.Commands.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 5632
ActionData: File: BPC.SignalR.Messages.Commands.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 5632
ActionData: File: BPC.SignalR.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 311
ActionData: File: BPC.WindowsAudit.DataAccess.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 14848
ActionData: File: BPC.WindowsAudit.Migrator.deps.json, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 87577
ActionData: File: BPC.WindowsAudit.Migrator.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 19448
ActionData: File: BPC.WindowsAudit.Migrator.exe, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 181224
ActionData: File: BPC.WindowsAudit.Migrator.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 154
ActionData: File: BPC.WindowsAudit.Web.deps.json, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 301173
ActionData: File: BPC.WindowsAudit.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 33776
ActionData: File: BPC.WindowsAudit.Web.exe, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 174592
ActionData: File: BPC.WindowsAudit.Web.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 311
ActionData: File: BPC.WindowsLogsGathererWorkerService.deps.json, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 39116
ActionData: File: BPC.WindowsLogsGathererWorkerService.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 21520
ActionData: File: BPC.WindowsLogsGathererWorkerService.exe, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 181752
ActionData: File: BPC.WindowsLogsGathererWorkerService.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 157
ActionData: File: CommandLine.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 217088
ActionData: File: CommandLine.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 217088
ActionData: File: CommandLine.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 217088
ActionData: File: CommandLine.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 217088
ActionData: File: CommandLine.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 217088
ActionData: File: CommandLine.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 217088
ActionData: File: CommandLine.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 217088
ActionData: File: common-de.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\common\de\, Size: 14472
ActionData: File: common-en.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\common\en\, Size: 12681
ActionData: File: common-es.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\common\es\, Size: 14131
ActionData: File: common-fr.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\common\fr\, Size: 14714
ActionData: File: common-ja.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\common\ja\, Size: 16161
ActionData: File: common-pt.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\common\pt\, Size: 10333
ActionData: File: common-ru.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\common\ru\, Size: 13959
ActionData: File: common-zh.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\locales\common\zh\, Size: 11651
ActionData: File: Connect.Authentication.Forms.4.6.0.99.nupkg, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\, Size: 72456
ActionData: File: Connect.Authentication.Forms.BusinessLogic.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 74320
ActionData: File: Connect.Authentication.Forms.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 30776
ActionData: File: Connect.Authentication.Forms.Frontend.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 53832
ActionData: File: Connect.Core.4.6.0.99.nupkg, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\, Size: 44759851
ActionData: File: Connect.Core.Data.4.6.0.99.nupkg, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\, Size: 286747
ActionData: File: Connect.Core.Data.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 13368
ActionData: File: Connect.Core.Data.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 13368
ActionData: File: Connect.Core.Data.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 18464
ActionData: File: Connect.Core.Data.Entities.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 92720
ActionData: File: Connect.Core.Data.Entities.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 92720
ActionData: File: Connect.Core.Data.EntityFramework.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 1442392
ActionData: File: Connect.Core.Data.EntityFramework.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 1442392
ActionData: File: Connect.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 49176
ActionData: File: Connect.Core.Environment.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 24624
ActionData: File: Connect.Core.Environment.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 24624
ActionData: File: Connect.Core.Frontend.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 61942824
ActionData: File: Connect.Core.Services.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 277544
ActionData: File: Connect.Core.Services.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\fr\, Size: 111616
ActionData: File: Connect.Core.Services.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\de\, Size: 106496
ActionData: File: Connect.Core.Services.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\pt\, Size: 69120
ActionData: File: Connect.Core.Services.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\es\, Size: 107520
ActionData: File: Connect.Core.Services.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\ru\, Size: 95744
ActionData: File: Connect.Core.Services.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\ja\, Size: 111616
ActionData: File: Connect.Core.Services.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\zh\, Size: 95232
ActionData: File: Connect.Core.Thoughtonomy.Data.4.6.0.99.nupkg, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\, Size: 229947
ActionData: File: Connect.Core.Thoughtonomy.Data.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 22104
ActionData: File: Connect.Core.Thoughtonomy.Data.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 22104
ActionData: File: Connect.Core.Thoughtonomy.Data.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 20024
ActionData: File: Connect.Core.Thoughtonomy.Data.Entities.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 199760
ActionData: File: Connect.Core.Thoughtonomy.Data.Entities.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 199760
ActionData: File: Connect.Core.Thoughtonomy.Data.EntityFramework.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 518264
ActionData: File: Connect.Core.Thoughtonomy.Data.EntityFramework.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 518264
ActionData: File: Connect.Dashboard.4.6.0.99.nupkg, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\, Size: 979445
ActionData: File: Connect.Dashboard.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 24096
ActionData: File: Connect.Dashboard.Frontend.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 4036144
ActionData: File: Connect.Installer.4.6.0.99.nupkg, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\, Size: 1060847
ActionData: File: Connect.Installer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 18976
ActionData: File: Connect.Installer.Frontend.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 104496
ActionData: File: Connect.ProjectManagement.4.6.0.99.nupkg, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\, Size: 4032406
ActionData: File: Connect.SelfServe.Forms.4.6.0.99.nupkg, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\, Size: 915756
ActionData: File: Connect.Web.deps.json, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 307130
ActionData: File: Connect.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 30744
ActionData: File: Connect.Web.exe, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 174592
ActionData: File: Connect.Web.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 224
ActionData: File: CreateAuditDB.ps1, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Scripts\, Size: 169
ActionData: File: CsvHelper.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 145920
ActionData: File: Dapper.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 177152
ActionData: File: Dapper.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 197632
ActionData: File: Dapper.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 177152
ActionData: File: Dapper.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 197120
ActionData: File: Dapper.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 192512
ActionData: File: Dapper.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 192512
ActionData: File: dbup-core.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 121344
ActionData: File: dbup-core.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 121344
ActionData: File: dbup-core.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 121344
ActionData: File: dbup-core.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 121344
ActionData: File: dbup-core.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 121344
ActionData: File: dbup-core.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 121344
ActionData: File: dbup-core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 121344
ActionData: File: dbup-sqlserver.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 18944
ActionData: File: dbup-sqlserver.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 18944
ActionData: File: dbup-sqlserver.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 18944
ActionData: File: dbup-sqlserver.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 18944
ActionData: File: dbup-sqlserver.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 18944
ActionData: File: dbup-sqlserver.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 18944
ActionData: File: dbup-sqlserver.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 18944
ActionData: File: dotnet-aspnet-codegenerator-design.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 52840
ActionData: File: dotnet-aspnet-codegenerator-design.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 52840
ActionData: File: e_sqlite3.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win-x86\native\, Size: 989184
ActionData: File: e_sqlite3.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win-x64\native\, Size: 1265664
ActionData: File: e_sqlite3.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win-arm\native\, Size: 870400
ActionData: File: e_sqlite3.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win-x64\native\, Size: 1265664
ActionData: File: e_sqlite3.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win-arm64\native\, Size: 1300992
ActionData: File: e_sqlite3.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win-arm64\native\, Size: 1300992
ActionData: File: e_sqlite3.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win-x86\native\, Size: 989184
ActionData: File: e_sqlite3.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win-arm\native\, Size: 870400
ActionData: File: e_sqlite3.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win-arm\native\, Size: 870400
ActionData: File: e_sqlite3.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win-arm64\native\, Size: 1300992
ActionData: File: e_sqlite3.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win-x64\native\, Size: 1265664
ActionData: File: e_sqlite3.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win-x86\native\, Size: 989184
ActionData: File: EFCore.BulkExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 84992
ActionData: File: EFCore.BulkExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 84992
ActionData: File: EFCore.BulkExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 84992
ActionData: File: EFCore.BulkExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 84992
ActionData: File: Elasticsearch.Net.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 814080
ActionData: File: Elasticsearch.Net.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 814080
ActionData: File: Elasticsearch.Net.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 814080
ActionData: File: Elasticsearch.Net.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 814080
ActionData: File: Elasticsearch.Net.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 814080
ActionData: File: Elasticsearch.Net.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 814080
ActionData: File: Elasticsearch.Net.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 814080
ActionData: File: Elasticsearch.Net.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 814080
ActionData: File: Elasticsearch.Net.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 814080
ActionData: File: Elasticsearch.Net.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 814080
ActionData: File: Elasticsearch.Net.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 814080
ActionData: File: Elasticsearch.Net.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 814080
ActionData: File: ElmahCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 62464
ActionData: File: ElmahCore.Mvc.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 236032
ActionData: File: ExtCore.Data.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 5120
ActionData: File: ExtCore.Data.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 5120
ActionData: File: ExtCore.Data.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 6656
ActionData: File: ExtCore.Data.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 6656
ActionData: File: ExtCore.Data.Entities.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 4608
ActionData: File: ExtCore.Data.Entities.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 4608
ActionData: File: ExtCore.Infrastructure.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 8192
ActionData: File: ExtCore.Infrastructure.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 8192
ActionData: File: ExtCore.Infrastructure.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 8192
ActionData: File: ExtCore.Mvc.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 10240
ActionData: File: ExtCore.Mvc.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 10240
ActionData: File: ExtCore.Mvc.Infrastructure.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 5120
ActionData: File: ExtCore.Mvc.Infrastructure.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 5120
ActionData: File: ExtCore.WebApplication.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 11776
ActionData: File: ExtCore.WebApplication.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 11776
ActionData: File: ExtCore.WebApplication.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 11776
ActionData: File: FastMember.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 26624
ActionData: File: FastMember.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 26624
ActionData: File: FastMember.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 26624
ActionData: File: FastMember.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 26624
ActionData: File: favicon.ico, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\, Size: 47186
ActionData: File: FluentValidation.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 66560
ActionData: File: FluentValidation.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 64512
ActionData: File: FluentValidation.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 66560
ActionData: File: FluentValidation.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 64512
ActionData: File: FluentValidation.DependencyInjectionExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 14336
ActionData: File: FluentValidation.DependencyInjectionExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 14848
ActionData: File: FluentValidation.DependencyInjectionExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 14336
ActionData: File: FluentValidation.DependencyInjectionExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 14848
ActionData: File: FluentValidation.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 416768
ActionData: File: FluentValidation.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 421376
ActionData: File: FluentValidation.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 364544
ActionData: File: FluentValidation.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 364544
ActionData: File: FSharp.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 2617008
ActionData: File: FSharp.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 2617008
ActionData: File: FSharp.Core.optdata, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\any\native\, Size: 428758
ActionData: File: FSharp.Core.sigdata, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\any\native\, Size: 571071
ActionData: File: GetEmailSender.sql, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Scripts\Senders\, Size: 91
ActionData: File: Google.Protobuf.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 390256
ActionData: File: Google.Protobuf.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 390256
ActionData: File: Google.Protobuf.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 390256
ActionData: File: Google.Protobuf.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 390256
ActionData: File: Google.Protobuf.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 390256
ActionData: File: Google.Protobuf.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 390256
ActionData: File: Google.Protobuf.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 390256
ActionData: File: Google.Protobuf.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 390256
ActionData: File: Google.Protobuf.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 390256
ActionData: File: GreenPipes.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 274432
ActionData: File: GreenPipes.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 274432
ActionData: File: GreenPipes.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 274944
ActionData: File: GreenPipes.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 274944
ActionData: File: GreenPipes.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 274432
ActionData: File: GreenPipes.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 274432
ActionData: File: GreenPipes.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 274432
ActionData: File: GreenPipes.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 274944
ActionData: File: GreenPipes.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 274432
ActionData: File: GreenPipes.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 274432
ActionData: File: GreenPipes.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 274432
ActionData: File: GreenPipes.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 274432
ActionData: File: Grpc.Core.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 52720
ActionData: File: Grpc.Core.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 52720
ActionData: File: Grpc.Core.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 52720
ActionData: File: Grpc.Core.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 52720
ActionData: File: Grpc.Core.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 52720
ActionData: File: Grpc.Core.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 52720
ActionData: File: Grpc.Core.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 52720
ActionData: File: Grpc.Core.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 52720
ActionData: File: Grpc.Core.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 52720
ActionData: File: Grpc.Net.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 93680
ActionData: File: Grpc.Net.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 93680
ActionData: File: Grpc.Net.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 93680
ActionData: File: Grpc.Net.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 93680
ActionData: File: Grpc.Net.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 93680
ActionData: File: Grpc.Net.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 93680
ActionData: File: Grpc.Net.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 93680
ActionData: File: Grpc.Net.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 93680
ActionData: File: Grpc.Net.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 93680
ActionData: File: Grpc.Net.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 18416
ActionData: File: Grpc.Net.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 18416
ActionData: File: Grpc.Net.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 18416
ActionData: File: Grpc.Net.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 18416
ActionData: File: Grpc.Net.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 18416
ActionData: File: Grpc.Net.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 18416
ActionData: File: Grpc.Net.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 18416
ActionData: File: Grpc.Net.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 18416
ActionData: File: Grpc.Net.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 18416
ActionData: File: HealthChecks.AzureStorage.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 12288
ActionData: File: HealthChecks.IdSvr.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 9216
ActionData: File: HealthChecks.IdSvr.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 9216
ActionData: File: HealthChecks.IdSvr.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 9216
ActionData: File: HealthChecks.IdSvr.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 9216
ActionData: File: HealthChecks.IdSvr.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 9216
ActionData: File: HealthChecks.IdSvr.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 9216
ActionData: File: HealthChecks.IdSvr.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 9216
ActionData: File: HealthChecks.Network.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 38912
ActionData: File: HealthChecks.RabbitMQ.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 9728
ActionData: File: HealthChecks.RabbitMQ.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 9728
ActionData: File: HealthChecks.RabbitMQ.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 9728
ActionData: File: HealthChecks.RabbitMQ.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 9728
ActionData: File: HealthChecks.RabbitMQ.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 9728
ActionData: File: HealthChecks.RabbitMQ.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 9728
ActionData: File: HealthChecks.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 8704
ActionData: File: HealthChecks.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 8704
ActionData: File: HealthChecks.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 8704
ActionData: File: HealthChecks.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 8704
ActionData: File: HealthChecks.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 8704
ActionData: File: HealthChecks.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 8704
ActionData: File: HealthChecks.System.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 14336
ActionData: File: HealthChecks.Uris.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 15872
ActionData: File: Hub.AutomationLifecycle.BusinessProcesses.4.6.0.99.nupkg, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\, Size: 1105400
ActionData: File: Hub.BluePrismDecision.4.6.0.99.nupkg, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\, Size: 1909933
ActionData: File: Hub.Core.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 30240
ActionData: File: Hub.Core.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 30240
ActionData: File: Hub.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 12304
ActionData: File: Hub.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 12304
ActionData: File: Hub.WebBasedControlRoom.4.6.0.99.nupkg, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\LocalStore\, Size: 4045153
ActionData: File: HubMigrations.deps.json, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 182199
ActionData: File: HubMigrations.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 16384
ActionData: File: HubMigrations.exe, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 182272
ActionData: File: HubMigrations.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 157
ActionData: File: IdentityModel.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 135568
ActionData: File: IdentityModel.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 135568
ActionData: File: IdentityModel.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 135568
ActionData: File: IdentityModel.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 135568
ActionData: File: IdentityModel.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 135568
ActionData: File: IdentityServer4.AspNetIdentity.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 32656
ActionData: File: IdentityServer4.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 682384
ActionData: File: IdentityServer4.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 682384
ActionData: File: IdentityServer4.EntityFramework.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 23440
ActionData: File: IdentityServer4.EntityFramework.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 23440
ActionData: File: IdentityServer4.EntityFramework.Storage.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 112528
ActionData: File: IdentityServer4.EntityFramework.Storage.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 112528
ActionData: File: IdentityServer4.Storage.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 45968
ActionData: File: IdentityServer4.Storage.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 45968
ActionData: File: ims.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\, Size: 20282
ActionData: File: ImsMigrations.deps.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 257931
ActionData: File: ImsMigrations.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 27136
ActionData: File: ImsMigrations.exe, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 182272
ActionData: File: ImsMigrations.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 157
ActionData: File: ImsServer.BusinessLogic.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 688640
ActionData: File: ImsServer.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 45056
ActionData: File: ImsServer.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 45056
ActionData: File: ImsServer.DataAccess.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 709120
ActionData: File: ImsServer.DataAccess.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 709120
ActionData: File: ImsServer.IntegrationServices.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 15360
ActionData: File: ImsServer.Web.deps.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 437841
ActionData: File: ImsServer.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 267264
ActionData: File: ImsServer.Web.exe, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 174592
ActionData: File: ImsServer.Web.runtimeconfig.json, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 224
ActionData: File: ImsServer.Web.Views.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 10752
ActionData: File: index.html, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\, Size: 3886
ActionData: File: IsFileByPurposeExisted.sql, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Scripts\Single\, Size: 138
ActionData: File: KintoSans-Bold.31112dfb.woff2, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\media\, Size: 4324008
ActionData: File: KintoSans-Regular.377fc131.woff2, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\media\, Size: 4180388
ActionData: File: libe_sqlite3.dylib, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\osx-x64\native\, Size: 1584496
ActionData: File: libe_sqlite3.dylib, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\osx-x64\native\, Size: 1584496
ActionData: File: libe_sqlite3.dylib, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\osx-x64\native\, Size: 1584496
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\alpine-x64\native\, Size: 1093816
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\linux-x86\native\, Size: 1159452
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\linux-musl-x64\native\, Size: 1093816
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\linux-arm64\native\, Size: 1027048
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\alpine-x64\native\, Size: 1093816
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\linux-armel\native\, Size: 1047940
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\linux-musl-x64\native\, Size: 1093816
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\linux-arm64\native\, Size: 1027048
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\linux-arm64\native\, Size: 1027048
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\linux-x64\native\, Size: 1116048
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\linux-arm\native\, Size: 740004
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\linux-arm\native\, Size: 740004
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\linux-x64\native\, Size: 1116048
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\linux-armel\native\, Size: 1047940
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\linux-x86\native\, Size: 1159452
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\linux-armel\native\, Size: 1047940
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\linux-x86\native\, Size: 1159452
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\linux-arm\native\, Size: 740004
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\linux-musl-x64\native\, Size: 1093816
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\alpine-x64\native\, Size: 1093816
ActionData: File: libe_sqlite3.so, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\linux-x64\native\, Size: 1116048
ActionData: File: Linq.Expression.Optimizer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 43520
ActionData: File: Linq.Expression.Optimizer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 43520
ActionData: File: login.422d7535.svg, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\media\, Size: 9994
ActionData: File: logo_sq.fb35e635.png, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\media\, Size: 22053
ActionData: File: MailKit.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 825856
ActionData: File: main.db03a044.chunk.js.map, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\js\, Size: 818114
ActionData: File: main.db03a044.chunk.js, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\js\, Size: 306547
ActionData: File: main.fab92ab7.chunk.css.map, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\css\, Size: 16173
ActionData: File: main.fab92ab7.chunk.css, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\css\, Size: 10927
ActionData: File: MassTransit.AspNetCoreIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 14848
ActionData: File: MassTransit.AspNetCoreIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 14848
ActionData: File: MassTransit.AspNetCoreIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 14848
ActionData: File: MassTransit.AspNetCoreIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 14848
ActionData: File: MassTransit.AspNetCoreIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 14848
ActionData: File: MassTransit.AspNetCoreIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 14848
ActionData: File: MassTransit.AspNetCoreIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 14848
ActionData: File: MassTransit.AspNetCoreIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 14848
ActionData: File: MassTransit.AspNetCoreIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 14848
ActionData: File: MassTransit.Azure.ServiceBus.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 248832
ActionData: File: MassTransit.Azure.ServiceBus.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 248832
ActionData: File: MassTransit.Azure.ServiceBus.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 248832
ActionData: File: MassTransit.Azure.ServiceBus.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 248832
ActionData: File: MassTransit.Azure.ServiceBus.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 248832
ActionData: File: MassTransit.Azure.ServiceBus.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 248832
ActionData: File: MassTransit.Azure.ServiceBus.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 248832
ActionData: File: MassTransit.Azure.ServiceBus.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 248832
ActionData: File: MassTransit.Azure.ServiceBus.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 248832
ActionData: File: MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 2699264
ActionData: File: MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 2699264
ActionData: File: MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 2699264
ActionData: File: MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 2670080
ActionData: File: MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 2670080
ActionData: File: MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 2699264
ActionData: File: MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 2699264
ActionData: File: MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 2670080
ActionData: File: MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 2699264
ActionData: File: MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 2699264
ActionData: File: MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 2699264
ActionData: File: MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 2699264
ActionData: File: MassTransit.ExtensionsDependencyInjectionIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 73728
ActionData: File: MassTransit.ExtensionsDependencyInjectionIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 73728
ActionData: File: MassTransit.ExtensionsDependencyInjectionIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 73728
ActionData: File: MassTransit.ExtensionsDependencyInjectionIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 73728
ActionData: File: MassTransit.ExtensionsDependencyInjectionIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 73728
ActionData: File: MassTransit.ExtensionsDependencyInjectionIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 73728
ActionData: File: MassTransit.ExtensionsDependencyInjectionIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 72704
ActionData: File: MassTransit.ExtensionsDependencyInjectionIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 72704
ActionData: File: MassTransit.ExtensionsDependencyInjectionIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 73728
ActionData: File: MassTransit.ExtensionsDependencyInjectionIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 73728
ActionData: File: MassTransit.ExtensionsDependencyInjectionIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 72704
ActionData: File: MassTransit.ExtensionsDependencyInjectionIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 73728
ActionData: File: MassTransit.Platform.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 5632
ActionData: File: MassTransit.Platform.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 5632
ActionData: File: MassTransit.Platform.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 5632
ActionData: File: MassTransit.Platform.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 5632
ActionData: File: MassTransit.Platform.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 5632
ActionData: File: MassTransit.Platform.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 5632
ActionData: File: MassTransit.Platform.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 5632
ActionData: File: MassTransit.Platform.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 5632
ActionData: File: MassTransit.Platform.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 5632
ActionData: File: MassTransit.RabbitMqTransport.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 227328
ActionData: File: MassTransit.RabbitMqTransport.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 227328
ActionData: File: MassTransit.RabbitMqTransport.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 227328
ActionData: File: MassTransit.RabbitMqTransport.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 227328
ActionData: File: MassTransit.RabbitMqTransport.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 227328
ActionData: File: MassTransit.RabbitMqTransport.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 227328
ActionData: File: MassTransit.RabbitMqTransport.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 227328
ActionData: File: MassTransit.RabbitMqTransport.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 227328
ActionData: File: MassTransit.RabbitMqTransport.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 227328
ActionData: File: MassTransit.SignalR.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 46080
ActionData: File: MassTransit.SignalR.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 46080
ActionData: File: MassTransit.SignalR.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 46080
ActionData: File: MassTransit.SignalR.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 46080
ActionData: File: MassTransit.SignalR.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 46080
ActionData: File: MassTransit.SignalR.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 46080
ActionData: File: MassTransit.SignalR.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 46080
ActionData: File: MassTransit.SignalR.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 46080
ActionData: File: MassTransit.SignalR.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 46080
ActionData: File: MediatR.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 33280
ActionData: File: MediatR.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 33280
ActionData: File: MediatR.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 33280
ActionData: File: MediatR.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 33280
ActionData: File: MediatR.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 33280
ActionData: File: MediatR.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 33280
ActionData: File: MediatR.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 33280
ActionData: File: MediatR.Extensions.Microsoft.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 16384
ActionData: File: MediatR.Extensions.Microsoft.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 16384
ActionData: File: MediatR.Extensions.Microsoft.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 16384
ActionData: File: MediatR.Extensions.Microsoft.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 16384
ActionData: File: MediatR.Extensions.Microsoft.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 16384
ActionData: File: MediatR.Extensions.Microsoft.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 16384
ActionData: File: MediatR.Extensions.Microsoft.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 16384
ActionData: File: Microsoft.AI.DependencyCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 126848
ActionData: File: Microsoft.AI.DependencyCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 131448
ActionData: File: Microsoft.AI.DependencyCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 131448
ActionData: File: Microsoft.AI.DependencyCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 131448
ActionData: File: Microsoft.AI.DependencyCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 131448
ActionData: File: Microsoft.AI.DependencyCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 131448
ActionData: File: Microsoft.AI.DependencyCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 131448
ActionData: File: Microsoft.AI.DependencyCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 131448
ActionData: File: Microsoft.AI.DependencyCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 126848
ActionData: File: Microsoft.AI.DependencyCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 131448
ActionData: File: Microsoft.AI.DependencyCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 131448
ActionData: File: Microsoft.AI.EventCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 42384
ActionData: File: Microsoft.AI.EventCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 42384
ActionData: File: Microsoft.AI.EventCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 42384
ActionData: File: Microsoft.AI.EventCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 38992
ActionData: File: Microsoft.AI.EventCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 42384
ActionData: File: Microsoft.AI.EventCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 42384
ActionData: File: Microsoft.AI.EventCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 42384
ActionData: File: Microsoft.AI.EventCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 42384
ActionData: File: Microsoft.AI.EventCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 42384
ActionData: File: Microsoft.AI.EventCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 38992
ActionData: File: Microsoft.AI.EventCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 42384
ActionData: File: Microsoft.AI.PerfCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 212368
ActionData: File: Microsoft.AI.PerfCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 212368
ActionData: File: Microsoft.AI.PerfCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 212368
ActionData: File: Microsoft.AI.PerfCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 212368
ActionData: File: Microsoft.AI.PerfCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 212368
ActionData: File: Microsoft.AI.PerfCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 212368
ActionData: File: Microsoft.AI.PerfCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 212368
ActionData: File: Microsoft.AI.PerfCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 207440
ActionData: File: Microsoft.AI.PerfCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 212368
ActionData: File: Microsoft.AI.PerfCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 212368
ActionData: File: Microsoft.AI.PerfCounterCollector.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 207440
ActionData: File: Microsoft.AI.ServerTelemetryChannel.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 119176
ActionData: File: Microsoft.AI.ServerTelemetryChannel.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 119176
ActionData: File: Microsoft.AI.ServerTelemetryChannel.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 109136
ActionData: File: Microsoft.AI.ServerTelemetryChannel.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 119176
ActionData: File: Microsoft.AI.ServerTelemetryChannel.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 119176
ActionData: File: Microsoft.AI.ServerTelemetryChannel.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 119176
ActionData: File: Microsoft.AI.ServerTelemetryChannel.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 109136
ActionData: File: Microsoft.AI.ServerTelemetryChannel.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 119176
ActionData: File: Microsoft.AI.ServerTelemetryChannel.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 119176
ActionData: File: Microsoft.AI.ServerTelemetryChannel.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 119176
ActionData: File: Microsoft.AI.ServerTelemetryChannel.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 119176
ActionData: File: Microsoft.AI.WindowsServer.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 70032
ActionData: File: Microsoft.AI.WindowsServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 70032
ActionData: File: Microsoft.AI.WindowsServer.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 70032
ActionData: File: Microsoft.AI.WindowsServer.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 70032
ActionData: File: Microsoft.AI.WindowsServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 70032
ActionData: File: Microsoft.AI.WindowsServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 70032
ActionData: File: Microsoft.AI.WindowsServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 70032
ActionData: File: Microsoft.AI.WindowsServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 70032
ActionData: File: Microsoft.AI.WindowsServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 66640
ActionData: File: Microsoft.AI.WindowsServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 66640
ActionData: File: Microsoft.AI.WindowsServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 70032
ActionData: File: Microsoft.ApplicationInsights.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 102776
ActionData: File: Microsoft.ApplicationInsights.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 102776
ActionData: File: Microsoft.ApplicationInsights.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 102776
ActionData: File: Microsoft.ApplicationInsights.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 99192
ActionData: File: Microsoft.ApplicationInsights.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 102776
ActionData: File: Microsoft.ApplicationInsights.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 102776
ActionData: File: Microsoft.ApplicationInsights.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 102776
ActionData: File: Microsoft.ApplicationInsights.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 102776
ActionData: File: Microsoft.ApplicationInsights.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 99192
ActionData: File: Microsoft.ApplicationInsights.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 102776
ActionData: File: Microsoft.ApplicationInsights.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 102776
ActionData: File: Microsoft.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 383376
ActionData: File: Microsoft.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 383376
ActionData: File: Microsoft.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 383376
ActionData: File: Microsoft.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 383376
ActionData: File: Microsoft.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 383376
ActionData: File: Microsoft.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 383376
ActionData: File: Microsoft.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 383376
ActionData: File: Microsoft.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 383376
ActionData: File: Microsoft.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 383376
ActionData: File: Microsoft.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 383376
ActionData: File: Microsoft.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 343144
ActionData: File: Microsoft.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 383376
ActionData: File: Microsoft.ApplicationInsights.NLogTarget.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 23432
ActionData: File: Microsoft.ApplicationInsights.NLogTarget.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 23432
ActionData: File: Microsoft.ApplicationInsights.NLogTarget.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 23432
ActionData: File: Microsoft.ApplicationInsights.NLogTarget.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 23432
ActionData: File: Microsoft.ApplicationInsights.NLogTarget.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 23632
ActionData: File: Microsoft.ApplicationInsights.NLogTarget.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 23432
ActionData: File: Microsoft.ApplicationInsights.NLogTarget.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 23432
ActionData: File: Microsoft.ApplicationInsights.NLogTarget.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 23432
ActionData: File: Microsoft.ApplicationInsights.NLogTarget.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 23432
ActionData: File: Microsoft.ApplicationInsights.NLogTarget.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 23432
ActionData: File: Microsoft.ApplicationInsights.NLogTarget.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 23432
ActionData: File: Microsoft.ApplicationInsights.NLogTarget.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 23432
ActionData: File: Microsoft.ApplicationInsights.WorkerService.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 43896
ActionData: File: Microsoft.ApplicationInsights.WorkerService.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 43896
ActionData: File: Microsoft.ApplicationInsights.WorkerService.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 43896
ActionData: File: Microsoft.AspNetCore.Antiforgery.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 23432
ActionData: File: Microsoft.AspNetCore.Antiforgery.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 54136
ActionData: File: Microsoft.AspNetCore.Authentication.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 29048
ActionData: File: Microsoft.AspNetCore.Authentication.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 22912
ActionData: File: Microsoft.AspNetCore.Authentication.Cookies.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 22408
ActionData: File: Microsoft.AspNetCore.Authentication.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 38264
ActionData: File: Microsoft.AspNetCore.Authentication.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17792
ActionData: File: Microsoft.AspNetCore.Authentication.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 29576
ActionData: File: Microsoft.AspNetCore.Authentication.JwtBearer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 37240
ActionData: File: Microsoft.AspNetCore.Authentication.JwtBearer.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 37760
ActionData: File: Microsoft.AspNetCore.Authentication.JwtBearer.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 37248
ActionData: File: Microsoft.AspNetCore.Authentication.JwtBearer.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 37248
ActionData: File: Microsoft.AspNetCore.Authentication.JwtBearer.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 37240
ActionData: File: Microsoft.AspNetCore.Authentication.JwtBearer.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 37240
ActionData: File: Microsoft.AspNetCore.Authentication.JwtBearer.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 37256
ActionData: File: Microsoft.AspNetCore.Authentication.JwtBearer.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 37240
ActionData: File: Microsoft.AspNetCore.Authentication.JwtBearer.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 37248
ActionData: File: Microsoft.AspNetCore.Authentication.OAuth.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 23944
ActionData: File: Microsoft.AspNetCore.Authentication.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 96136
ActionData: File: Microsoft.AspNetCore.Authentication.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 96128
ActionData: File: Microsoft.AspNetCore.Authentication.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 96120
ActionData: File: Microsoft.AspNetCore.Authentication.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 96128
ActionData: File: Microsoft.AspNetCore.Authentication.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 96128
ActionData: File: Microsoft.AspNetCore.Authentication.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 96120
ActionData: File: Microsoft.AspNetCore.Authentication.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 96120
ActionData: File: Microsoft.AspNetCore.Authorization.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 22920
ActionData: File: Microsoft.AspNetCore.Authorization.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 40016
ActionData: File: Microsoft.AspNetCore.Authorization.Policy.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 20344
ActionData: File: Microsoft.AspNetCore.Authorization.Policy.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17288
ActionData: File: Microsoft.AspNetCore.Components.Authorization.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17800
ActionData: File: Microsoft.AspNetCore.Components.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 48520
ActionData: File: Microsoft.AspNetCore.Components.Forms.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17800
ActionData: File: Microsoft.AspNetCore.Components.Server.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 35712
ActionData: File: Microsoft.AspNetCore.Components.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 40328
ActionData: File: Microsoft.AspNetCore.Connections.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 32136
ActionData: File: Microsoft.AspNetCore.CookiePolicy.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17800
ActionData: File: Microsoft.AspNetCore.Cors.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 21896
ActionData: File: Microsoft.AspNetCore.Cors.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 38776
ActionData: File: Microsoft.AspNetCore.Cryptography.Internal.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 41344
ActionData: File: Microsoft.AspNetCore.Cryptography.Internal.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 41344
ActionData: File: Microsoft.AspNetCore.Cryptography.Internal.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 41336
ActionData: File: Microsoft.AspNetCore.Cryptography.Internal.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 41344
ActionData: File: Microsoft.AspNetCore.Cryptography.Internal.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 41344
ActionData: File: Microsoft.AspNetCore.Cryptography.Internal.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 31112
ActionData: File: Microsoft.AspNetCore.Cryptography.KeyDerivation.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 21376
ActionData: File: Microsoft.AspNetCore.Cryptography.KeyDerivation.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16264
ActionData: File: Microsoft.AspNetCore.Cryptography.KeyDerivation.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 21376
ActionData: File: Microsoft.AspNetCore.Cryptography.KeyDerivation.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 21376
ActionData: File: Microsoft.AspNetCore.Cryptography.KeyDerivation.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 21376
ActionData: File: Microsoft.AspNetCore.DataProtection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17288
ActionData: File: Microsoft.AspNetCore.DataProtection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 24680
ActionData: File: Microsoft.AspNetCore.DataProtection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 23416
ActionData: File: Microsoft.AspNetCore.DataProtection.AzureStorage.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 25472
ActionData: File: Microsoft.AspNetCore.DataProtection.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 43904
ActionData: File: Microsoft.AspNetCore.DataProtection.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 155216
ActionData: File: Microsoft.AspNetCore.DataProtection.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 153976
ActionData: File: Microsoft.AspNetCore.DataProtection.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17792
ActionData: File: Microsoft.AspNetCore.Diagnostics.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 17272
ActionData: File: Microsoft.AspNetCore.Diagnostics.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17288
ActionData: File: Microsoft.AspNetCore.Diagnostics.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 25480
ActionData: File: Microsoft.AspNetCore.Diagnostics.HealthChecks.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17280
ActionData: File: Microsoft.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15752
ActionData: File: Microsoft.AspNetCore.HostFiltering.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16264
ActionData: File: Microsoft.AspNetCore.Hosting.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 22904
ActionData: File: Microsoft.AspNetCore.Hosting.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 20864
ActionData: File: Microsoft.AspNetCore.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 34184
ActionData: File: Microsoft.AspNetCore.Hosting.Server.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 15224
ActionData: File: Microsoft.AspNetCore.Hosting.Server.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16264
ActionData: File: Microsoft.AspNetCore.Html.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 19832
ActionData: File: Microsoft.AspNetCore.Html.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17288
ActionData: File: Microsoft.AspNetCore.Http.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 48520
ActionData: File: Microsoft.AspNetCore.Http.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 76152
ActionData: File: Microsoft.AspNetCore.Http.Connections.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16776
ActionData: File: Microsoft.AspNetCore.Http.Connections.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 20872
ActionData: File: Microsoft.AspNetCore.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 82296
ActionData: File: Microsoft.AspNetCore.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 36232
ActionData: File: Microsoft.AspNetCore.Http.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 21896
ActionData: File: Microsoft.AspNetCore.Http.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 38776
ActionData: File: Microsoft.AspNetCore.Http.Features.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 26504
ActionData: File: Microsoft.AspNetCore.Http.Features.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 32120
ActionData: File: Microsoft.AspNetCore.HttpOverrides.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 19840
ActionData: File: Microsoft.AspNetCore.HttpsPolicy.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17288
ActionData: File: Microsoft.AspNetCore.Identity.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 27528
ActionData: File: Microsoft.AspNetCore.Identity.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 98176
ActionData: File: Microsoft.AspNetCore.Identity.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 98176
ActionData: File: Microsoft.AspNetCore.Identity.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 98176
ActionData: File: Microsoft.AspNetCore.JsonPatch.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 53136
ActionData: File: Microsoft.AspNetCore.JsonPatch.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 53112
ActionData: File: Microsoft.AspNetCore.JsonPatch.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 52608
ActionData: File: Microsoft.AspNetCore.JsonPatch.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 52608
ActionData: File: Microsoft.AspNetCore.JsonPatch.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 53112
ActionData: File: Microsoft.AspNetCore.JsonPatch.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 52600
ActionData: File: Microsoft.AspNetCore.JsonPatch.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 53112
ActionData: File: Microsoft.AspNetCore.JsonPatch.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 52600
ActionData: File: Microsoft.AspNetCore.JsonPatch.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 52608
ActionData: File: Microsoft.AspNetCore.JsonPatch.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 52616
ActionData: File: Microsoft.AspNetCore.Localization.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 19840
ActionData: File: Microsoft.AspNetCore.Localization.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 30072
ActionData: File: Microsoft.AspNetCore.Localization.Routing.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15744
ActionData: File: Microsoft.AspNetCore.Metadata.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15240
ActionData: File: Microsoft.AspNetCore.Mvc.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 67464
ActionData: File: Microsoft.AspNetCore.Mvc.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 103800
ActionData: File: Microsoft.AspNetCore.Mvc.ApiExplorer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 18312
ActionData: File: Microsoft.AspNetCore.Mvc.ApiExplorer.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 36216
ActionData: File: Microsoft.AspNetCore.Mvc.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 670072
ActionData: File: Microsoft.AspNetCore.Mvc.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 223624
ActionData: File: Microsoft.AspNetCore.Mvc.Cors.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 25976
ActionData: File: Microsoft.AspNetCore.Mvc.Cors.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 18824
ActionData: File: Microsoft.AspNetCore.Mvc.DataAnnotations.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 47480
ActionData: File: Microsoft.AspNetCore.Mvc.DataAnnotations.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 24968
ActionData: File: Microsoft.AspNetCore.Mvc.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 18808
ActionData: File: Microsoft.AspNetCore.Mvc.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15744
ActionData: File: Microsoft.AspNetCore.Mvc.Formatters.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14728
ActionData: File: Microsoft.AspNetCore.Mvc.Formatters.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 41848
ActionData: File: Microsoft.AspNetCore.Mvc.Formatters.Xml.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 23944
ActionData: File: Microsoft.AspNetCore.Mvc.Localization.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 25976
ActionData: File: Microsoft.AspNetCore.Mvc.Localization.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 20872
ActionData: File: Microsoft.AspNetCore.Mvc.NewtonsoftJson.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 62336
ActionData: File: Microsoft.AspNetCore.Mvc.NewtonsoftJson.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 59776
ActionData: File: Microsoft.AspNetCore.Mvc.NewtonsoftJson.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 59776
ActionData: File: Microsoft.AspNetCore.Mvc.NewtonsoftJson.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 62328
ActionData: File: Microsoft.AspNetCore.Mvc.NewtonsoftJson.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 61816
ActionData: File: Microsoft.AspNetCore.Mvc.NewtonsoftJson.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 62328
ActionData: File: Microsoft.AspNetCore.Mvc.NewtonsoftJson.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 59776
ActionData: File: Microsoft.AspNetCore.Mvc.Razor.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 45440
ActionData: File: Microsoft.AspNetCore.Mvc.Razor.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 143736
ActionData: File: Microsoft.AspNetCore.Mvc.Razor.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 88952
ActionData: File: Microsoft.AspNetCore.Mvc.Razor.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 79736
ActionData: File: Microsoft.AspNetCore.Mvc.Razor.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 88952
ActionData: File: Microsoft.AspNetCore.Mvc.Razor.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 88952
ActionData: File: Microsoft.AspNetCore.Mvc.Razor.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 88952
ActionData: File: Microsoft.AspNetCore.Mvc.Razor.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 88952
ActionData: File: Microsoft.AspNetCore.Mvc.Razor.RuntimeCompilation.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 62336
ActionData: File: Microsoft.AspNetCore.Mvc.RazorPages.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 67464
ActionData: File: Microsoft.AspNetCore.Mvc.RazorPages.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 170360
ActionData: File: Microsoft.AspNetCore.Mvc.TagHelpers.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 123256
ActionData: File: Microsoft.AspNetCore.Mvc.TagHelpers.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 49024
ActionData: File: Microsoft.AspNetCore.Mvc.Versioning.ApiExplorer.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 46480
ActionData: File: Microsoft.AspNetCore.Mvc.Versioning.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 142208
ActionData: File: Microsoft.AspNetCore.Mvc.ViewFeatures.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 105344
ActionData: File: Microsoft.AspNetCore.Mvc.ViewFeatures.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 268664
ActionData: File: Microsoft.AspNetCore.NodeServices.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 62568
ActionData: File: Microsoft.AspNetCore.NodeServices.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 62328
ActionData: File: Microsoft.AspNetCore.OData.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 901368
ActionData: File: Microsoft.AspNetCore.Razor.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 24968
ActionData: File: Microsoft.AspNetCore.Razor.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 33656
ActionData: File: Microsoft.AspNetCore.Razor.Language.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 483192
ActionData: File: Microsoft.AspNetCore.Razor.Language.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 483192
ActionData: File: Microsoft.AspNetCore.Razor.Language.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 483192
ActionData: File: Microsoft.AspNetCore.Razor.Language.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 937032
ActionData: File: Microsoft.AspNetCore.Razor.Language.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 936832
ActionData: File: Microsoft.AspNetCore.Razor.Language.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 937032
ActionData: File: Microsoft.AspNetCore.Razor.Runtime.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 19848
ActionData: File: Microsoft.AspNetCore.Razor.Runtime.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 32336
ActionData: File: Microsoft.AspNetCore.ResponseCaching.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 14712
ActionData: File: Microsoft.AspNetCore.ResponseCaching.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15240
ActionData: File: Microsoft.AspNetCore.ResponseCaching.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 24968
ActionData: File: Microsoft.AspNetCore.ResponseCompression.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 20872
ActionData: File: Microsoft.AspNetCore.Rewrite.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 35720
ActionData: File: Microsoft.AspNetCore.Routing.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 41040
ActionData: File: Microsoft.AspNetCore.Routing.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 19848
ActionData: File: Microsoft.AspNetCore.Routing.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 63368
ActionData: File: Microsoft.AspNetCore.Routing.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 212552
ActionData: File: Microsoft.AspNetCore.Server.HttpSys.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 57728
ActionData: File: Microsoft.AspNetCore.Server.IIS.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 23432
ActionData: File: Microsoft.AspNetCore.Server.IISIntegration.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17800
ActionData: File: Microsoft.AspNetCore.Server.Kestrel.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 126344
ActionData: File: Microsoft.AspNetCore.Server.Kestrel.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15240
ActionData: File: Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 20864
ActionData: File: Microsoft.AspNetCore.Session.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17800
ActionData: File: Microsoft.AspNetCore.SignalR.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 20872
ActionData: File: Microsoft.AspNetCore.SignalR.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 31624
ActionData: File: Microsoft.AspNetCore.SignalR.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17288
ActionData: File: Microsoft.AspNetCore.SignalR.Protocols.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16776
ActionData: File: Microsoft.AspNetCore.SpaServices.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 53328
ActionData: File: Microsoft.AspNetCore.SpaServices.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 53120
ActionData: File: Microsoft.AspNetCore.SpaServices.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 65920
ActionData: File: Microsoft.AspNetCore.SpaServices.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 66128
ActionData: File: Microsoft.AspNetCore.StaticFiles.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 23432
ActionData: File: Microsoft.AspNetCore.WebSockets.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16768
ActionData: File: Microsoft.AspNetCore.WebUtilities.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 25984
ActionData: File: Microsoft.AspNetCore.WebUtilities.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 66424
ActionData: File: Microsoft.Azure.Amqp.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 407928
ActionData: File: Microsoft.Azure.Amqp.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 407928
ActionData: File: Microsoft.Azure.Amqp.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 407928
ActionData: File: Microsoft.Azure.Amqp.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 407928
ActionData: File: Microsoft.Azure.Amqp.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 407928
ActionData: File: Microsoft.Azure.Amqp.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 407928
ActionData: File: Microsoft.Azure.Amqp.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 407928
ActionData: File: Microsoft.Azure.Amqp.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 407928
ActionData: File: Microsoft.Azure.Amqp.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 407928
ActionData: File: Microsoft.Azure.Cosmos.Table.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 621432
ActionData: File: Microsoft.Azure.DocumentDB.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 1886104
ActionData: File: Microsoft.Azure.KeyVault.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 22208
ActionData: File: Microsoft.Azure.KeyVault.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 22208
ActionData: File: Microsoft.Azure.KeyVault.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 22208
ActionData: File: Microsoft.Azure.KeyVault.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 22208
ActionData: File: Microsoft.Azure.KeyVault.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 22208
ActionData: File: Microsoft.Azure.KeyVault.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 485240
ActionData: File: Microsoft.Azure.KeyVault.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 485240
ActionData: File: Microsoft.Azure.KeyVault.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 485240
ActionData: File: Microsoft.Azure.KeyVault.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 569424
ActionData: File: Microsoft.Azure.KeyVault.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 485240
ActionData: File: Microsoft.Azure.KeyVault.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 485240
ActionData: File: Microsoft.Azure.KeyVault.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 485240
ActionData: File: Microsoft.Azure.KeyVault.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 485240
ActionData: File: Microsoft.Azure.KeyVault.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 569424
ActionData: File: Microsoft.Azure.KeyVault.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 485240
ActionData: File: Microsoft.Azure.KeyVault.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 485240
ActionData: File: Microsoft.Azure.KeyVault.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 485240
ActionData: File: Microsoft.Azure.KeyVault.WebKey.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 57208
ActionData: File: Microsoft.Azure.KeyVault.WebKey.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 57208
ActionData: File: Microsoft.Azure.KeyVault.WebKey.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 57208
ActionData: File: Microsoft.Azure.KeyVault.WebKey.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 61024
ActionData: File: Microsoft.Azure.KeyVault.WebKey.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 61024
ActionData: File: Microsoft.Azure.KeyVault.WebKey.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 57208
ActionData: File: Microsoft.Azure.KeyVault.WebKey.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 57208
ActionData: File: Microsoft.Azure.KeyVault.WebKey.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 57208
ActionData: File: Microsoft.Azure.KeyVault.WebKey.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 57208
ActionData: File: Microsoft.Azure.KeyVault.WebKey.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 57208
ActionData: File: Microsoft.Azure.KeyVault.WebKey.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 57208
ActionData: File: Microsoft.Azure.KeyVault.WebKey.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 57208
ActionData: File: Microsoft.Azure.ServiceBus.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 465296
ActionData: File: Microsoft.Azure.ServiceBus.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 465296
ActionData: File: Microsoft.Azure.ServiceBus.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 465296
ActionData: File: Microsoft.Azure.ServiceBus.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 465296
ActionData: File: Microsoft.Azure.ServiceBus.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 465296
ActionData: File: Microsoft.Azure.ServiceBus.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 465296
ActionData: File: Microsoft.Azure.ServiceBus.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 465296
ActionData: File: Microsoft.Azure.ServiceBus.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 465296
ActionData: File: Microsoft.Azure.ServiceBus.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 465296
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 88952
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 88440
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 88440
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 88440
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 88952
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 88440
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 88952
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 88952
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 88952
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 88440
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 88440
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 88952
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 88952
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 88440
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 88952
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 88952
ActionData: File: Microsoft.Azure.Services.AppAuthentication.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 88952
ActionData: File: Microsoft.Azure.Storage.Blob.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 417144
ActionData: File: Microsoft.Azure.Storage.Blob.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 417144
ActionData: File: Microsoft.Azure.Storage.Blob.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 417144
ActionData: File: Microsoft.Azure.Storage.Blob.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 417144
ActionData: File: Microsoft.Azure.Storage.Blob.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 417144
ActionData: File: Microsoft.Azure.Storage.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 360824
ActionData: File: Microsoft.Azure.Storage.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 360824
ActionData: File: Microsoft.Azure.Storage.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 360824
ActionData: File: Microsoft.Azure.Storage.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 360824
ActionData: File: Microsoft.Azure.Storage.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 360824
ActionData: File: Microsoft.Bcl.AsyncInterfaces.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 14720
ActionData: File: Microsoft.Bcl.AsyncInterfaces.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 14720
ActionData: File: Microsoft.Bcl.AsyncInterfaces.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 14720
ActionData: File: Microsoft.Bcl.AsyncInterfaces.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 14720
ActionData: File: Microsoft.Bcl.AsyncInterfaces.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 14720
ActionData: File: Microsoft.Bcl.AsyncInterfaces.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 14720
ActionData: File: Microsoft.Bcl.AsyncInterfaces.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 14720
ActionData: File: Microsoft.Bcl.AsyncInterfaces.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 14920
ActionData: File: Microsoft.Bcl.AsyncInterfaces.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 14720
ActionData: File: Microsoft.Bcl.AsyncInterfaces.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 14720
ActionData: File: Microsoft.Bcl.AsyncInterfaces.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 14720
ActionData: File: Microsoft.Bcl.AsyncInterfaces.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 14720
ActionData: File: Microsoft.Bcl.AsyncInterfaces.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 14720
ActionData: File: Microsoft.Bcl.HashCode.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 14440
ActionData: File: Microsoft.Bcl.HashCode.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 14208
ActionData: File: Microsoft.Bcl.HashCode.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 14208
ActionData: File: Microsoft.Bcl.HashCode.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 14208
ActionData: File: Microsoft.Bcl.HashCode.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 14208
ActionData: File: Microsoft.Bcl.HashCode.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 14208
ActionData: File: Microsoft.Bcl.HashCode.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 14440
ActionData: File: Microsoft.Bcl.HashCode.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 14440
ActionData: File: Microsoft.CodeAnalysis.CSharp.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 5211000
ActionData: File: Microsoft.CodeAnalysis.CSharp.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 5218168
ActionData: File: Microsoft.CodeAnalysis.CSharp.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 4681136
ActionData: File: Microsoft.CodeAnalysis.CSharp.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 4681136
ActionData: File: Microsoft.CodeAnalysis.CSharp.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 5218168
ActionData: File: Microsoft.CodeAnalysis.CSharp.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 4681136
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\pt-BR\, Size: 316792
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ja\, Size: 359800
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\zh-Hant\, Size: 280440
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\zh-Hant\, Size: 279928
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\pl\, Size: 331640
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\fr\, Size: 328568
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\ko\, Size: 330104
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\zh-Hans\, Size: 279416
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\pl\, Size: 331640
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hans\, Size: 279416
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\de\, Size: 328056
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\ja\, Size: 359800
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\de\, Size: 327032
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\fr\, Size: 327032
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\es\, Size: 321400
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\tr\, Size: 311672
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\cs\, Size: 308600
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\zh-Hans\, Size: 279928
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\it\, Size: 326520
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\ja\, Size: 357240
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\it\, Size: 326520
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\ru\, Size: 427896
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ko\, Size: 331640
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ru\, Size: 433016
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\tr\, Size: 313208
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\es\, Size: 320376
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\pt-BR\, Size: 315768
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\tr\, Size: 313208
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\cs\, Size: 308088
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\ko\, Size: 331640
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\pl\, Size: 330104
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\pt-BR\, Size: 316792
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\cs\, Size: 308600
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\ru\, Size: 433016
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\de\, Size: 328056
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\it\, Size: 324984
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hant\, Size: 279928
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\es\, Size: 321400
ActionData: File: Microsoft.CodeAnalysis.CSharp.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\fr\, Size: 328568
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 761208
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 761208
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ja\, Size: 16248
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\zh-Hant\, Size: 15736
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\it\, Size: 16248
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\ru\, Size: 16760
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\fr\, Size: 16248
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\pt-BR\, Size: 16248
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\fr\, Size: 16248
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\ja\, Size: 16248
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\pt-BR\, Size: 16248
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\tr\, Size: 15736
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\ko\, Size: 15736
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ko\, Size: 15736
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hans\, Size: 15736
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\it\, Size: 16248
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\es\, Size: 16248
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\cs\, Size: 15736
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hant\, Size: 15736
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\cs\, Size: 15736
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ru\, Size: 16760
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\pl\, Size: 16248
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\de\, Size: 16248
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\es\, Size: 16248
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\tr\, Size: 15736
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\zh-Hans\, Size: 15736
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\de\, Size: 16248
ActionData: File: Microsoft.CodeAnalysis.CSharp.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\pl\, Size: 16248
ActionData: File: Microsoft.CodeAnalysis.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 2496376
ActionData: File: Microsoft.CodeAnalysis.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 2465144
ActionData: File: Microsoft.CodeAnalysis.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 2496376
ActionData: File: Microsoft.CodeAnalysis.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 2414000
ActionData: File: Microsoft.CodeAnalysis.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 2414000
ActionData: File: Microsoft.CodeAnalysis.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 2414000
ActionData: File: Microsoft.CodeAnalysis.Razor.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 83840
ActionData: File: Microsoft.CodeAnalysis.Razor.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 84040
ActionData: File: Microsoft.CodeAnalysis.Razor.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 47992
ActionData: File: Microsoft.CodeAnalysis.Razor.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 47992
ActionData: File: Microsoft.CodeAnalysis.Razor.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 84040
ActionData: File: Microsoft.CodeAnalysis.Razor.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 47992
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\it\, Size: 37752
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\tr\, Size: 36728
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\ru\, Size: 44920
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\cs\, Size: 36216
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\pl\, Size: 37752
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\fr\, Size: 37752
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\cs\, Size: 36216
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\fr\, Size: 37752
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\pt-BR\, Size: 37240
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hant\, Size: 34680
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\de\, Size: 37240
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\fr\, Size: 37752
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\ru\, Size: 43896
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\de\, Size: 37752
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\it\, Size: 37752
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\ja\, Size: 39800
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\ko\, Size: 38264
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\zh-Hant\, Size: 34680
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\tr\, Size: 36728
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ko\, Size: 38264
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\pl\, Size: 37752
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ja\, Size: 40312
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\zh-Hans\, Size: 34680
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ru\, Size: 44920
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\it\, Size: 37752
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\pt-BR\, Size: 36728
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\es\, Size: 37240
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\pt-BR\, Size: 37240
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\es\, Size: 37240
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\ko\, Size: 37752
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hans\, Size: 34680
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\ja\, Size: 40312
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\de\, Size: 37752
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\cs\, Size: 36216
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\es\, Size: 37240
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\zh-Hans\, Size: 34680
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\zh-Hant\, Size: 34680
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\tr\, Size: 36728
ActionData: File: Microsoft.CodeAnalysis.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\pl\, Size: 37752
ActionData: File: Microsoft.CodeAnalysis.Workspaces.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 2916216
ActionData: File: Microsoft.CodeAnalysis.Workspaces.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 2916216
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ja\, Size: 84856
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\fr\, Size: 82808
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\zh-Hant\, Size: 71544
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\zh-Hans\, Size: 70520
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\es\, Size: 80248
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\pl\, Size: 80248
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\tr\, Size: 78200
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hant\, Size: 71544
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\pt-BR\, Size: 80760
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\ru\, Size: 103288
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ru\, Size: 103288
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\pt-BR\, Size: 80760
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ko\, Size: 79736
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\it\, Size: 82296
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\it\, Size: 82296
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hans\, Size: 70520
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\pl\, Size: 80248
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\de\, Size: 81784
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\ja\, Size: 84856
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\fr\, Size: 82808
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\cs\, Size: 78712
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\tr\, Size: 78200
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\de\, Size: 81784
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\es\, Size: 80248
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\ko\, Size: 79736
ActionData: File: Microsoft.CodeAnalysis.Workspaces.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\cs\, Size: 78712
ActionData: File: Microsoft.CSharp.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16488
ActionData: File: Microsoft.Data.Edm.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 681376
ActionData: File: Microsoft.Data.Edm.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\it\, Size: 76264
ActionData: File: Microsoft.Data.Edm.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hant\, Size: 71072
ActionData: File: Microsoft.Data.Edm.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\de\, Size: 78240
ActionData: File: Microsoft.Data.Edm.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ko\, Size: 77288
ActionData: File: Microsoft.Data.Edm.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\fr\, Size: 77800
ActionData: File: Microsoft.Data.Edm.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ja\, Size: 80984
ActionData: File: Microsoft.Data.Edm.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hans\, Size: 71072
ActionData: File: Microsoft.Data.Edm.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ru\, Size: 92576
ActionData: File: Microsoft.Data.Edm.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\es\, Size: 74840
ActionData: File: Microsoft.Data.OData.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 1543768
ActionData: File: Microsoft.Data.OData.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hant\, Size: 249944
ActionData: File: Microsoft.Data.OData.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\de\, Size: 291928
ActionData: File: Microsoft.Data.OData.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ru\, Size: 364120
ActionData: File: Microsoft.Data.OData.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\fr\, Size: 300632
ActionData: File: Microsoft.Data.OData.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hans\, Size: 253528
ActionData: File: Microsoft.Data.OData.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ko\, Size: 290904
ActionData: File: Microsoft.Data.OData.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\it\, Size: 285272
ActionData: File: Microsoft.Data.OData.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\es\, Size: 286808
ActionData: File: Microsoft.Data.OData.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ja\, Size: 324184
ActionData: File: Microsoft.Data.SqlClient.AlwaysEncrypted.AzureKeyVaultProvider.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 29680
ActionData: File: Microsoft.Data.SqlClient.AlwaysEncrypted.AzureKeyVaultProvider.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\unix\lib\netcoreapp2.1\, Size: 29680
ActionData: File: Microsoft.Data.SqlClient.AlwaysEncrypted.AzureKeyVaultProvider.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 29680
ActionData: File: Microsoft.Data.SqlClient.AlwaysEncrypted.AzureKeyVaultProvider.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win\lib\netcoreapp2.1\, Size: 29680
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 346584
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp2.1\, Size: 1266648
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 346576
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\runtimes\win\lib\netcoreapp2.1\, Size: 1227736
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\runtimes\win\lib\netcoreapp2.1\, Size: 1266648
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\unix\lib\netcoreapp2.1\, Size: 1155032
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\unix\lib\netcoreapp2.1\, Size: 1155032
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\unix\lib\netcoreapp2.1\, Size: 1156592
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 364008
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 346584
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\win\lib\netcoreapp2.1\, Size: 1266648
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 330712
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netcoreapp3.1\, Size: 1574896
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 346584
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\win\lib\netcoreapp2.1\, Size: 1266648
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\win\lib\netcoreapp2.1\, Size: 1266648
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\runtimes\unix\lib\netcoreapp2.1\, Size: 1155032
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 346584
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\unix\lib\netcoreapp2.1\, Size: 1155032
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\runtimes\unix\lib\netcoreapp2.1\, Size: 1117144
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 66008
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\unix\lib\netcoreapp2.1\, Size: 1158616
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\win\lib\netcoreapp2.1\, Size: 1268176
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 346584
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 346584
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\unix\lib\netcoreapp2.1\, Size: 1155032
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win\lib\netcoreapp2.1\, Size: 1270232
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 346584
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.1\, Size: 1266648
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 346584
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\unix\lib\netcoreapp2.1\, Size: 1155032
ActionData: File: Microsoft.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\unix\lib\netcoreapp3.1\, Size: 1494512
ActionData: File: Microsoft.Data.SqlClient.SNI.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win-arm\native\, Size: 458640
ActionData: File: Microsoft.Data.SqlClient.SNI.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win-x64\native\, Size: 498576
ActionData: File: Microsoft.Data.SqlClient.SNI.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win-arm64\native\, Size: 594320
ActionData: File: Microsoft.Data.SqlClient.SNI.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win-x86\native\, Size: 432528
ActionData: File: Microsoft.Data.Sqlite.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 147528
ActionData: File: Microsoft.Data.Sqlite.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 147528
ActionData: File: Microsoft.Data.Sqlite.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 147528
ActionData: File: Microsoft.Data.Sqlite.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 147528
ActionData: File: Microsoft.DotNet.PlatformAbstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 23416
ActionData: File: Microsoft.DotNet.PlatformAbstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 23416
ActionData: File: Microsoft.DotNet.PlatformAbstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 23416
ActionData: File: Microsoft.DotNet.PlatformAbstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 24024
ActionData: File: Microsoft.DotNet.PlatformAbstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 23416
ActionData: File: Microsoft.DotNet.PlatformAbstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 24024
ActionData: File: Microsoft.EntityFrameworkCore.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 21072
ActionData: File: Microsoft.EntityFrameworkCore.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 20864
ActionData: File: Microsoft.EntityFrameworkCore.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 21072
ActionData: File: Microsoft.EntityFrameworkCore.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 21072
ActionData: File: Microsoft.EntityFrameworkCore.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 21072
ActionData: File: Microsoft.EntityFrameworkCore.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 21072
ActionData: File: Microsoft.EntityFrameworkCore.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 21072
ActionData: File: Microsoft.EntityFrameworkCore.Design.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 264272
ActionData: File: Microsoft.EntityFrameworkCore.Design.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 264272
ActionData: File: Microsoft.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 1555536
ActionData: File: Microsoft.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 1555536
ActionData: File: Microsoft.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 1555536
ActionData: File: Microsoft.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 1555536
ActionData: File: Microsoft.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 1555536
ActionData: File: Microsoft.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 1555536
ActionData: File: Microsoft.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 1554304
ActionData: File: Microsoft.EntityFrameworkCore.Relational.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 857984
ActionData: File: Microsoft.EntityFrameworkCore.Relational.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 858192
ActionData: File: Microsoft.EntityFrameworkCore.Relational.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 858192
ActionData: File: Microsoft.EntityFrameworkCore.Relational.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 858192
ActionData: File: Microsoft.EntityFrameworkCore.Relational.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 858192
ActionData: File: Microsoft.EntityFrameworkCore.Relational.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 858192
ActionData: File: Microsoft.EntityFrameworkCore.Relational.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 858192
ActionData: File: Microsoft.EntityFrameworkCore.Sqlite.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 147016
ActionData: File: Microsoft.EntityFrameworkCore.Sqlite.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 147016
ActionData: File: Microsoft.EntityFrameworkCore.Sqlite.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 147016
ActionData: File: Microsoft.EntityFrameworkCore.Sqlite.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 147016
ActionData: File: Microsoft.EntityFrameworkCore.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 289872
ActionData: File: Microsoft.EntityFrameworkCore.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 289872
ActionData: File: Microsoft.EntityFrameworkCore.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 289664
ActionData: File: Microsoft.EntityFrameworkCore.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 289872
ActionData: File: Microsoft.EntityFrameworkCore.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 289872
ActionData: File: Microsoft.EntityFrameworkCore.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 289872
ActionData: File: Microsoft.EntityFrameworkCore.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 289872
ActionData: File: Microsoft.Extensions.Caching.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 26496
ActionData: File: Microsoft.Extensions.Caching.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 26496
ActionData: File: Microsoft.Extensions.Caching.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 26496
ActionData: File: Microsoft.Extensions.Caching.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 26496
ActionData: File: Microsoft.Extensions.Caching.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 26496
ActionData: File: Microsoft.Extensions.Caching.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 26496
ActionData: File: Microsoft.Extensions.Caching.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 26496
ActionData: File: Microsoft.Extensions.Caching.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 27016
ActionData: File: Microsoft.Extensions.Caching.Memory.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 32640
ActionData: File: Microsoft.Extensions.Caching.Memory.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 32640
ActionData: File: Microsoft.Extensions.Caching.Memory.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 32640
ActionData: File: Microsoft.Extensions.Caching.Memory.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 32640
ActionData: File: Microsoft.Extensions.Caching.Memory.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 32640
ActionData: File: Microsoft.Extensions.Caching.Memory.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 32640
ActionData: File: Microsoft.Extensions.Caching.Memory.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 32640
ActionData: File: Microsoft.Extensions.Caching.Memory.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 32640
ActionData: File: Microsoft.Extensions.Caching.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 46976
ActionData: File: Microsoft.Extensions.Caching.SqlServer.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 46984
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 21368
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 21376
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 21368
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 20360
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 21376
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 21376
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 20360
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 21376
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 20360
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 21376
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 21368
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 20360
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 21392
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 20360
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 21376
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 21376
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 20360
ActionData: File: Microsoft.Extensions.Configuration.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 20360
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 25472
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 25472
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 25472
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 28040
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 25472
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 25472
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 25472
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 25472
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 28040
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 25472
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 25472
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 28040
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 25472
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 25472
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 28040
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 28040
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 28040
ActionData: File: Microsoft.Extensions.Configuration.Binder.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 28040
ActionData: File: Microsoft.Extensions.Configuration.CommandLine.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 20072
ActionData: File: Microsoft.Extensions.Configuration.CommandLine.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 20072
ActionData: File: Microsoft.Extensions.Configuration.CommandLine.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15736
ActionData: File: Microsoft.Extensions.Configuration.CommandLine.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 20072
ActionData: File: Microsoft.Extensions.Configuration.CommandLine.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 20072
ActionData: File: Microsoft.Extensions.Configuration.CommandLine.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 20072
ActionData: File: Microsoft.Extensions.Configuration.CommandLine.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 20072
ActionData: File: Microsoft.Extensions.Configuration.CommandLine.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 20072
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 27520
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 27520
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 30600
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 27520
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 27520
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 30600
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 30600
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 30600
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 27520
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 27536
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 27520
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 30600
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 27520
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 27520
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 27520
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 30600
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 27520
ActionData: File: Microsoft.Extensions.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 30600
ActionData: File: Microsoft.Extensions.Configuration.EnvironmentVariables.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 20864
ActionData: File: Microsoft.Extensions.Configuration.EnvironmentVariables.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 20864
ActionData: File: Microsoft.Extensions.Configuration.EnvironmentVariables.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15224
ActionData: File: Microsoft.Extensions.Configuration.EnvironmentVariables.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 20864
ActionData: File: Microsoft.Extensions.Configuration.EnvironmentVariables.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 20864
ActionData: File: Microsoft.Extensions.Configuration.EnvironmentVariables.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 20864
ActionData: File: Microsoft.Extensions.Configuration.EnvironmentVariables.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 20864
ActionData: File: Microsoft.Extensions.Configuration.EnvironmentVariables.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 20864
ActionData: File: Microsoft.Extensions.Configuration.FileExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 22912
ActionData: File: Microsoft.Extensions.Configuration.FileExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 22912
ActionData: File: Microsoft.Extensions.Configuration.FileExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 22912
ActionData: File: Microsoft.Extensions.Configuration.FileExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 22912
ActionData: File: Microsoft.Extensions.Configuration.FileExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 22912
ActionData: File: Microsoft.Extensions.Configuration.FileExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 22912
ActionData: File: Microsoft.Extensions.Configuration.FileExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 22912
ActionData: File: Microsoft.Extensions.Configuration.FileExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 22928
ActionData: File: Microsoft.Extensions.Configuration.Ini.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15736
ActionData: File: Microsoft.Extensions.Configuration.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 22096
ActionData: File: Microsoft.Extensions.Configuration.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 21904
ActionData: File: Microsoft.Extensions.Configuration.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 22096
ActionData: File: Microsoft.Extensions.Configuration.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 22096
ActionData: File: Microsoft.Extensions.Configuration.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 22096
ActionData: File: Microsoft.Extensions.Configuration.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 22096
ActionData: File: Microsoft.Extensions.Configuration.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 22096
ActionData: File: Microsoft.Extensions.Configuration.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 22096
ActionData: File: Microsoft.Extensions.Configuration.KeyPerFile.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15736
ActionData: File: Microsoft.Extensions.Configuration.UserSecrets.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 21072
ActionData: File: Microsoft.Extensions.Configuration.UserSecrets.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 21072
ActionData: File: Microsoft.Extensions.Configuration.UserSecrets.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 21072
ActionData: File: Microsoft.Extensions.Configuration.UserSecrets.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15224
ActionData: File: Microsoft.Extensions.Configuration.UserSecrets.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 20856
ActionData: File: Microsoft.Extensions.Configuration.UserSecrets.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 21072
ActionData: File: Microsoft.Extensions.Configuration.UserSecrets.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 21072
ActionData: File: Microsoft.Extensions.Configuration.UserSecrets.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 21072
ActionData: File: Microsoft.Extensions.Configuration.Xml.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16248
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 37760
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 37760
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 37760
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 44416
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 44416
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 37760
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 37752
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 44416
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 44416
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 44416
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 37760
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 37752
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 37760
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 37760
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 44416
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 45680
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 45680
ActionData: File: Microsoft.Extensions.DependencyInjection.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 37760
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 74616
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 74616
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 72784
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 72784
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 72784
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 83072
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 72784
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 72784
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 74616
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 72784
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 83072
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 72784
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 74616
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 72784
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 72784
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 74616
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 74616
ActionData: File: Microsoft.Extensions.DependencyInjection.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 72784
ActionData: File: Microsoft.Extensions.DependencyModel.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 67976
ActionData: File: Microsoft.Extensions.DependencyModel.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 67968
ActionData: File: Microsoft.Extensions.DependencyModel.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 67960
ActionData: File: Microsoft.Extensions.DependencyModel.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 67960
ActionData: File: Microsoft.Extensions.DependencyModel.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 67960
ActionData: File: Microsoft.Extensions.DependencyModel.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 67960
ActionData: File: Microsoft.Extensions.DependencyModel.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 62944
ActionData: File: Microsoft.Extensions.DependencyModel.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 62944
ActionData: File: Microsoft.Extensions.DiagnosticAdapter.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 38912
ActionData: File: Microsoft.Extensions.DiagnosticAdapter.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 38912
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 20864
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 20864
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 20864
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 20864
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 20864
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 20864
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 20864
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17272
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 20864
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 20864
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 20864
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 20864
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 45952
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 45952
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 45952
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 45952
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17784
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 45952
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 45952
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 45952
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 45952
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 45952
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 45952
ActionData: File: Microsoft.Extensions.Diagnostics.HealthChecks.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 45952
ActionData: File: Microsoft.Extensions.FileProviders.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 17792
ActionData: File: Microsoft.Extensions.FileProviders.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 17792
ActionData: File: Microsoft.Extensions.FileProviders.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 17792
ActionData: File: Microsoft.Extensions.FileProviders.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 17792
ActionData: File: Microsoft.Extensions.FileProviders.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 17792
ActionData: File: Microsoft.Extensions.FileProviders.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 17792
ActionData: File: Microsoft.Extensions.FileProviders.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 17792
ActionData: File: Microsoft.Extensions.FileProviders.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 17792
ActionData: File: Microsoft.Extensions.FileProviders.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 17792
ActionData: File: Microsoft.Extensions.FileProviders.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 17784
ActionData: File: Microsoft.Extensions.FileProviders.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 17792
ActionData: File: Microsoft.Extensions.FileProviders.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 17792
ActionData: File: Microsoft.Extensions.FileProviders.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 17792
ActionData: File: Microsoft.Extensions.FileProviders.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 17792
ActionData: File: Microsoft.Extensions.FileProviders.Composite.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 16960
ActionData: File: Microsoft.Extensions.FileProviders.Composite.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15224
ActionData: File: Microsoft.Extensions.FileProviders.Embedded.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 31608
ActionData: File: Microsoft.Extensions.FileProviders.Embedded.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15736
ActionData: File: Microsoft.Extensions.FileProviders.Physical.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 35712
ActionData: File: Microsoft.Extensions.FileProviders.Physical.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 35712
ActionData: File: Microsoft.Extensions.FileProviders.Physical.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 35712
ActionData: File: Microsoft.Extensions.FileProviders.Physical.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 35712
ActionData: File: Microsoft.Extensions.FileProviders.Physical.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 35704
ActionData: File: Microsoft.Extensions.FileProviders.Physical.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 35712
ActionData: File: Microsoft.Extensions.FileProviders.Physical.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 35712
ActionData: File: Microsoft.Extensions.FileProviders.Physical.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 35712
ActionData: File: Microsoft.Extensions.FileSystemGlobbing.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 39296
ActionData: File: Microsoft.Extensions.FileSystemGlobbing.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 39296
ActionData: File: Microsoft.Extensions.FileSystemGlobbing.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 39296
ActionData: File: Microsoft.Extensions.FileSystemGlobbing.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 39296
ActionData: File: Microsoft.Extensions.FileSystemGlobbing.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 39296
ActionData: File: Microsoft.Extensions.FileSystemGlobbing.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 39296
ActionData: File: Microsoft.Extensions.FileSystemGlobbing.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 39288
ActionData: File: Microsoft.Extensions.FileSystemGlobbing.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 39296
ActionData: File: Microsoft.Extensions.Hosting.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 25984
ActionData: File: Microsoft.Extensions.Hosting.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 25984
ActionData: File: Microsoft.Extensions.Hosting.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 25984
ActionData: File: Microsoft.Extensions.Hosting.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 25984
ActionData: File: Microsoft.Extensions.Hosting.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 25464
ActionData: File: Microsoft.Extensions.Hosting.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 25984
ActionData: File: Microsoft.Extensions.Hosting.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 25984
ActionData: File: Microsoft.Extensions.Hosting.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 25464
ActionData: File: Microsoft.Extensions.Hosting.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 25464
ActionData: File: Microsoft.Extensions.Hosting.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 25984
ActionData: File: Microsoft.Extensions.Hosting.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 25984
ActionData: File: Microsoft.Extensions.Hosting.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 25984
ActionData: File: Microsoft.Extensions.Hosting.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 25464
ActionData: File: Microsoft.Extensions.Hosting.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 25984
ActionData: File: Microsoft.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 41344
ActionData: File: Microsoft.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 41344
ActionData: File: Microsoft.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 41344
ActionData: File: Microsoft.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 41344
ActionData: File: Microsoft.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 18808
ActionData: File: Microsoft.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 41344
ActionData: File: Microsoft.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 41344
ActionData: File: Microsoft.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 41344
ActionData: File: Microsoft.Extensions.Hosting.WindowsServices.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 21376
ActionData: File: Microsoft.Extensions.Hosting.WindowsServices.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 21376
ActionData: File: Microsoft.Extensions.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 57216
ActionData: File: Microsoft.Extensions.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 57216
ActionData: File: Microsoft.Extensions.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 57216
ActionData: File: Microsoft.Extensions.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 57216
ActionData: File: Microsoft.Extensions.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 57216
ActionData: File: Microsoft.Extensions.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 57216
ActionData: File: Microsoft.Extensions.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 18808
ActionData: File: Microsoft.Extensions.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 57216
ActionData: File: Microsoft.Extensions.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 57216
ActionData: File: Microsoft.Extensions.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 57216
ActionData: File: Microsoft.Extensions.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 57216
ActionData: File: Microsoft.Extensions.Identity.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 171392
ActionData: File: Microsoft.Extensions.Identity.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 171392
ActionData: File: Microsoft.Extensions.Identity.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 48008
ActionData: File: Microsoft.Extensions.Identity.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 171392
ActionData: File: Microsoft.Extensions.Identity.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 171392
ActionData: File: Microsoft.Extensions.Identity.Stores.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 40824
ActionData: File: Microsoft.Extensions.Identity.Stores.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 40824
ActionData: File: Microsoft.Extensions.Identity.Stores.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 40824
ActionData: File: Microsoft.Extensions.Identity.Stores.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 27008
ActionData: File: Microsoft.Extensions.Identity.Stores.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 40824
ActionData: File: Microsoft.Extensions.Localization.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 17784
ActionData: File: Microsoft.Extensions.Localization.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16248
ActionData: File: Microsoft.Extensions.Localization.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 17288
ActionData: File: Microsoft.Extensions.Localization.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 18296
ActionData: File: Microsoft.Extensions.Localization.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 29560
ActionData: File: Microsoft.Extensions.Localization.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 29576
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 52616
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 48520
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 48520
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 63600
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 52616
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 48520
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 52616
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 52616
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 48520
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 52616
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 48504
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 52616
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 48504
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 48504
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 52616
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 48504
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 63600
ActionData: File: Microsoft.Extensions.Logging.Abstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 48520
ActionData: File: Microsoft.Extensions.Logging.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 21376
ActionData: File: Microsoft.Extensions.Logging.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 24440
ActionData: File: Microsoft.Extensions.Logging.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 24440
ActionData: File: Microsoft.Extensions.Logging.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 24440
ActionData: File: Microsoft.Extensions.Logging.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 24440
ActionData: File: Microsoft.Extensions.Logging.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 24440
ActionData: File: Microsoft.Extensions.Logging.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 24440
ActionData: File: Microsoft.Extensions.Logging.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 21376
ActionData: File: Microsoft.Extensions.Logging.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 24440
ActionData: File: Microsoft.Extensions.Logging.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 24440
ActionData: File: Microsoft.Extensions.Logging.ApplicationInsights.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 24440
ActionData: File: Microsoft.Extensions.Logging.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 20360
ActionData: File: Microsoft.Extensions.Logging.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 20352
ActionData: File: Microsoft.Extensions.Logging.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 20360
ActionData: File: Microsoft.Extensions.Logging.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15736
ActionData: File: Microsoft.Extensions.Logging.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 20360
ActionData: File: Microsoft.Extensions.Logging.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 20352
ActionData: File: Microsoft.Extensions.Logging.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 20360
ActionData: File: Microsoft.Extensions.Logging.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 20360
ActionData: File: Microsoft.Extensions.Logging.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 20352
ActionData: File: Microsoft.Extensions.Logging.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 20360
ActionData: File: Microsoft.Extensions.Logging.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 20352
ActionData: File: Microsoft.Extensions.Logging.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 20360
ActionData: File: Microsoft.Extensions.Logging.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 20352
ActionData: File: Microsoft.Extensions.Logging.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 28024
ActionData: File: Microsoft.Extensions.Logging.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 49544
ActionData: File: Microsoft.Extensions.Logging.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 49544
ActionData: File: Microsoft.Extensions.Logging.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 28024
ActionData: File: Microsoft.Extensions.Logging.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 49544
ActionData: File: Microsoft.Extensions.Logging.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 28024
ActionData: File: Microsoft.Extensions.Logging.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15736
ActionData: File: Microsoft.Extensions.Logging.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 28024
ActionData: File: Microsoft.Extensions.Logging.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 49544
ActionData: File: Microsoft.Extensions.Logging.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 28024
ActionData: File: Microsoft.Extensions.Logging.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 49544
ActionData: File: Microsoft.Extensions.Logging.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 49544
ActionData: File: Microsoft.Extensions.Logging.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 49544
ActionData: File: Microsoft.Extensions.Logging.Debug.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 17792
ActionData: File: Microsoft.Extensions.Logging.Debug.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 17792
ActionData: File: Microsoft.Extensions.Logging.Debug.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 17792
ActionData: File: Microsoft.Extensions.Logging.Debug.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 17792
ActionData: File: Microsoft.Extensions.Logging.Debug.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14712
ActionData: File: Microsoft.Extensions.Logging.Debug.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 17792
ActionData: File: Microsoft.Extensions.Logging.Debug.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 17792
ActionData: File: Microsoft.Extensions.Logging.Debug.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 17792
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 34176
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 42376
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 42376
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 34176
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 34176
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 34176
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 34176
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 34176
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 42376
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 42376
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 42376
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 34176
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 34176
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 34176
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 42376
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 34176
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 42376
ActionData: File: Microsoft.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 34176
ActionData: File: Microsoft.Extensions.Logging.EventLog.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 21880
ActionData: File: Microsoft.Extensions.Logging.EventLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 21880
ActionData: File: Microsoft.Extensions.Logging.EventLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 21880
ActionData: File: Microsoft.Extensions.Logging.EventLog.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 21880
ActionData: File: Microsoft.Extensions.Logging.EventLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15736
ActionData: File: Microsoft.Extensions.Logging.EventLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 21880
ActionData: File: Microsoft.Extensions.Logging.EventLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 21880
ActionData: File: Microsoft.Extensions.Logging.EventLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 21880
ActionData: File: Microsoft.Extensions.Logging.EventSource.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 29568
ActionData: File: Microsoft.Extensions.Logging.EventSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 29568
ActionData: File: Microsoft.Extensions.Logging.EventSource.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 29568
ActionData: File: Microsoft.Extensions.Logging.EventSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 29568
ActionData: File: Microsoft.Extensions.Logging.EventSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 29568
ActionData: File: Microsoft.Extensions.Logging.EventSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 29568
ActionData: File: Microsoft.Extensions.Logging.EventSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15224
ActionData: File: Microsoft.Extensions.Logging.EventSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 29568
ActionData: File: Microsoft.Extensions.Logging.TraceSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15224
ActionData: File: Microsoft.Extensions.ObjectPool.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16248
ActionData: File: Microsoft.Extensions.ObjectPool.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 19520
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 18304
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 18816
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 18304
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 18304
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 18304
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 18816
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 18816
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 18304
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 18304
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 18304
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 18816
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 18816
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 18304
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 18816
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 18816
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 18304
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 18304
ActionData: File: Microsoft.Extensions.Options.ConfigurationExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 18304
ActionData: File: Microsoft.Extensions.Options.DataAnnotations.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14712
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 55176
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 50552
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 50560
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 55176
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 50576
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 55176
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 55176
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 55176
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 50552
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 50560
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 50560
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 55176
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 50560
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 50560
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 55176
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 50560
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 50552
ActionData: File: Microsoft.Extensions.Options.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 50552
ActionData: File: Microsoft.Extensions.PlatformAbstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 16376
ActionData: File: Microsoft.Extensions.PlatformAbstractions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 16376
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 39296
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 38784
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 39296
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 38792
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 38784
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 39296
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 38800
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 38784
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 38784
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 39296
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 39296
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 38784
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 38784
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 39296
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 38800
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 39296
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 38784
ActionData: File: Microsoft.Extensions.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 38784
ActionData: File: Microsoft.Extensions.WebEncoders.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16760
ActionData: File: Microsoft.Extensions.WebEncoders.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 19832
ActionData: File: Microsoft.FeatureManagement.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 31608
ActionData: File: Microsoft.FeatureManagement.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 51064
ActionData: File: Microsoft.Graph.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 141720
ActionData: File: Microsoft.Graph.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 7936376
ActionData: File: Microsoft.Identity.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 1310152
ActionData: File: Microsoft.Identity.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 1187176
ActionData: File: Microsoft.Identity.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 1187176
ActionData: File: Microsoft.Identity.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 1187176
ActionData: File: Microsoft.Identity.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 1187176
ActionData: File: Microsoft.Identity.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 1187176
ActionData: File: Microsoft.Identity.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 1333720
ActionData: File: Microsoft.Identity.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 1187176
ActionData: File: Microsoft.Identity.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 1187176
ActionData: File: Microsoft.Identity.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 1187176
ActionData: File: Microsoft.Identity.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 1187176
ActionData: File: Microsoft.Identity.Client.Extensions.Msal.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 52600
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 233584
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 333536
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 233584
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 333536
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 233584
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 233584
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 333536
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 333536
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 333536
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 333536
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 233584
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 233584
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 233584
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 333536
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 233584
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 233584
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 233584
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 21616
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 21616
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 21616
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 21616
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 21616
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 21616
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 21616
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 21616
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 21616
ActionData: File: Microsoft.IdentityModel.Clients.ActiveDirectory.Platform.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 21616
ActionData: File: Microsoft.IdentityModel.JsonWebTokens.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 66096
ActionData: File: Microsoft.IdentityModel.JsonWebTokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 66096
ActionData: File: Microsoft.IdentityModel.JsonWebTokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 66096
ActionData: File: Microsoft.IdentityModel.JsonWebTokens.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 66096
ActionData: File: Microsoft.IdentityModel.JsonWebTokens.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 62840
ActionData: File: Microsoft.IdentityModel.JsonWebTokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 66096
ActionData: File: Microsoft.IdentityModel.JsonWebTokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 65040
ActionData: File: Microsoft.IdentityModel.JsonWebTokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 66096
ActionData: File: Microsoft.IdentityModel.JsonWebTokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 66096
ActionData: File: Microsoft.IdentityModel.JsonWebTokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 66096
ActionData: File: Microsoft.IdentityModel.JsonWebTokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 66096
ActionData: File: Microsoft.IdentityModel.JsonWebTokens.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 64872
ActionData: File: Microsoft.IdentityModel.JsonWebTokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 66096
ActionData: File: Microsoft.IdentityModel.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 32296
ActionData: File: Microsoft.IdentityModel.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 32296
ActionData: File: Microsoft.IdentityModel.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 32296
ActionData: File: Microsoft.IdentityModel.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 24952
ActionData: File: Microsoft.IdentityModel.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 32296
ActionData: File: Microsoft.IdentityModel.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 32296
ActionData: File: Microsoft.IdentityModel.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 32488
ActionData: File: Microsoft.IdentityModel.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 32296
ActionData: File: Microsoft.IdentityModel.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 32296
ActionData: File: Microsoft.IdentityModel.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 32296
ActionData: File: Microsoft.IdentityModel.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 25656
ActionData: File: Microsoft.IdentityModel.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 24952
ActionData: File: Microsoft.IdentityModel.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 32296
ActionData: File: Microsoft.IdentityModel.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 37416
ActionData: File: Microsoft.IdentityModel.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 37416
ActionData: File: Microsoft.IdentityModel.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 37416
ActionData: File: Microsoft.IdentityModel.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 37416
ActionData: File: Microsoft.IdentityModel.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 37416
ActionData: File: Microsoft.IdentityModel.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 37416
ActionData: File: Microsoft.IdentityModel.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 37416
ActionData: File: Microsoft.IdentityModel.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 37416
ActionData: File: Microsoft.IdentityModel.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 37416
ActionData: File: Microsoft.IdentityModel.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 37416
ActionData: File: Microsoft.IdentityModel.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 37416
ActionData: File: Microsoft.IdentityModel.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 32632
ActionData: File: Microsoft.IdentityModel.Protocols.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 109096
ActionData: File: Microsoft.IdentityModel.Protocols.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 109096
ActionData: File: Microsoft.IdentityModel.Protocols.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 108920
ActionData: File: Microsoft.IdentityModel.Protocols.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 109096
ActionData: File: Microsoft.IdentityModel.Protocols.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 109096
ActionData: File: Microsoft.IdentityModel.Protocols.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 109096
ActionData: File: Microsoft.IdentityModel.Protocols.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 109096
ActionData: File: Microsoft.IdentityModel.Protocols.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 109096
ActionData: File: Microsoft.IdentityModel.Protocols.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 109096
ActionData: File: Microsoft.IdentityModel.Protocols.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 109096
ActionData: File: Microsoft.IdentityModel.Protocols.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 109096
ActionData: File: Microsoft.IdentityModel.Protocols.OpenIdConnect.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 109096
ActionData: File: Microsoft.IdentityModel.Tokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 155664
ActionData: File: Microsoft.IdentityModel.Tokens.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 164600
ActionData: File: Microsoft.IdentityModel.Tokens.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 870264
ActionData: File: Microsoft.IdentityModel.Tokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 164600
ActionData: File: Microsoft.IdentityModel.Tokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 164600
ActionData: File: Microsoft.IdentityModel.Tokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 164600
ActionData: File: Microsoft.IdentityModel.Tokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 164600
ActionData: File: Microsoft.IdentityModel.Tokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 164600
ActionData: File: Microsoft.IdentityModel.Tokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 164600
ActionData: File: Microsoft.IdentityModel.Tokens.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 862584
ActionData: File: Microsoft.IdentityModel.Tokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 164600
ActionData: File: Microsoft.IdentityModel.Tokens.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 160320
ActionData: File: Microsoft.IdentityModel.Tokens.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 164600
ActionData: File: Microsoft.JSInterop.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17784
ActionData: File: Microsoft.Net.Http.Headers.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 74616
ActionData: File: Microsoft.Net.Http.Headers.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 28040
ActionData: File: Microsoft.OData.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 1504808
ActionData: File: Microsoft.OData.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 1404528
ActionData: File: Microsoft.OData.Edm.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 881192
ActionData: File: Microsoft.OData.Edm.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 788592
ActionData: File: Microsoft.OpenApi.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 173960
ActionData: File: Microsoft.OpenApi.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 173960
ActionData: File: Microsoft.OpenApi.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 169848
ActionData: File: Microsoft.OpenApi.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 173960
ActionData: File: Microsoft.Rest.ClientRuntime.Azure.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 97672
ActionData: File: Microsoft.Rest.ClientRuntime.Azure.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 97672
ActionData: File: Microsoft.Rest.ClientRuntime.Azure.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 97872
ActionData: File: Microsoft.Rest.ClientRuntime.Azure.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 97672
ActionData: File: Microsoft.Rest.ClientRuntime.Azure.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 97672
ActionData: File: Microsoft.Rest.ClientRuntime.Azure.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 97672
ActionData: File: Microsoft.Rest.ClientRuntime.Azure.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 97872
ActionData: File: Microsoft.Rest.ClientRuntime.Azure.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 97672
ActionData: File: Microsoft.Rest.ClientRuntime.Azure.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 97672
ActionData: File: Microsoft.Rest.ClientRuntime.Azure.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 97672
ActionData: File: Microsoft.Rest.ClientRuntime.Azure.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 97672
ActionData: File: Microsoft.Rest.ClientRuntime.Azure.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 97672
ActionData: File: Microsoft.Rest.ClientRuntime.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 80264
ActionData: File: Microsoft.Rest.ClientRuntime.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 80264
ActionData: File: Microsoft.Rest.ClientRuntime.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 80264
ActionData: File: Microsoft.Rest.ClientRuntime.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 80264
ActionData: File: Microsoft.Rest.ClientRuntime.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 79736
ActionData: File: Microsoft.Rest.ClientRuntime.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 80264
ActionData: File: Microsoft.Rest.ClientRuntime.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 80264
ActionData: File: Microsoft.Rest.ClientRuntime.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 79736
ActionData: File: Microsoft.Rest.ClientRuntime.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 80264
ActionData: File: Microsoft.Rest.ClientRuntime.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 80264
ActionData: File: Microsoft.Rest.ClientRuntime.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 80264
ActionData: File: Microsoft.Rest.ClientRuntime.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 80264
ActionData: File: Microsoft.Spatial.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 146984
ActionData: File: Microsoft.Spatial.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 139888
ActionData: File: Microsoft.VisualBasic.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 52296
ActionData: File: Microsoft.VisualBasic.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16456
ActionData: File: Microsoft.VisualStudio.Web.CodeGeneration.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 23424
ActionData: File: Microsoft.VisualStudio.Web.CodeGeneration.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 23424
ActionData: File: Microsoft.VisualStudio.Web.CodeGeneration.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 73088
ActionData: File: Microsoft.VisualStudio.Web.CodeGeneration.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 73088
ActionData: File: Microsoft.VisualStudio.Web.CodeGeneration.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 35712
ActionData: File: Microsoft.VisualStudio.Web.CodeGeneration.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 35712
ActionData: File: Microsoft.VisualStudio.Web.CodeGeneration.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 69712
ActionData: File: Microsoft.VisualStudio.Web.CodeGeneration.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 69712
ActionData: File: Microsoft.VisualStudio.Web.CodeGeneration.Templating.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 29288
ActionData: File: Microsoft.VisualStudio.Web.CodeGeneration.Templating.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 29288
ActionData: File: Microsoft.VisualStudio.Web.CodeGeneration.Utils.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 34384
ActionData: File: Microsoft.VisualStudio.Web.CodeGeneration.Utils.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 34384
ActionData: File: Microsoft.VisualStudio.Web.CodeGenerators.Mvc.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 188496
ActionData: File: Microsoft.VisualStudio.Web.CodeGenerators.Mvc.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 188496
ActionData: File: Microsoft.Win32.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14920
ActionData: File: Microsoft.Win32.Registry.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 20040
ActionData: File: Microsoft.Win32.SystemEvents.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp3.0\, Size: 52104
ActionData: File: Microsoft.Win32.SystemEvents.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 27528
ActionData: File: Microsoft.Win32.SystemEvents.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netcoreapp3.0\, Size: 50248
ActionData: File: Microsoft.Win32.SystemEvents.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 27528
ActionData: File: Microsoft.Win32.SystemEvents.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp3.0\, Size: 52104
ActionData: File: Microsoft.Win32.SystemEvents.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 23112
ActionData: File: MimeKit.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 1012224
ActionData: File: mscorlib.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 55880
ActionData: File: netstandard.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 99704
ActionData: File: NewId.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 22016
ActionData: File: NewId.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 22016
ActionData: File: NewId.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 22016
ActionData: File: NewId.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 22016
ActionData: File: NewId.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 22016
ActionData: File: NewId.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 22016
ActionData: File: NewId.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 22016
ActionData: File: NewId.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 22016
ActionData: File: NewId.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 22016
ActionData: File: NewId.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 22016
ActionData: File: NewId.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 22016
ActionData: File: NewId.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 22016
ActionData: File: Newtonsoft.Json.Bson.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 97720
ActionData: File: Newtonsoft.Json.Bson.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 90624
ActionData: File: Newtonsoft.Json.Bson.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 97720
ActionData: File: Newtonsoft.Json.Bson.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 90624
ActionData: File: Newtonsoft.Json.Bson.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 97720
ActionData: File: Newtonsoft.Json.Bson.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 97720
ActionData: File: Newtonsoft.Json.Bson.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 90624
ActionData: File: Newtonsoft.Json.Bson.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 90624
ActionData: File: Newtonsoft.Json.Bson.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 90624
ActionData: File: Newtonsoft.Json.Bson.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 90624
ActionData: File: Newtonsoft.Json.Bson.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 97720
ActionData: File: Newtonsoft.Json.Bson.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 97720
ActionData: File: Newtonsoft.Json.Bson.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 97720
ActionData: File: Newtonsoft.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 693680
ActionData: File: Newtonsoft.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 693680
ActionData: File: Newtonsoft.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 693680
ActionData: File: Newtonsoft.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 693680
ActionData: File: Newtonsoft.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 693680
ActionData: File: Newtonsoft.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 693680
ActionData: File: Newtonsoft.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 693680
ActionData: File: Newtonsoft.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 693680
ActionData: File: Newtonsoft.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 656384
ActionData: File: Newtonsoft.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 693680
ActionData: File: Newtonsoft.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 693680
ActionData: File: Newtonsoft.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 693680
ActionData: File: Newtonsoft.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 693680
ActionData: File: Newtonsoft.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 693680
ActionData: File: Nito.AsyncEx.Coordination.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 40960
ActionData: File: Nito.AsyncEx.Tasks.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 35328
ActionData: File: Nito.Collections.Deque.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 16896
ActionData: File: Nito.Disposables.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 22528
ActionData: File: NLog.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 803328
ActionData: File: NLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 803328
ActionData: File: NLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 803328
ActionData: File: NLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 819712
ActionData: File: NLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 803328
ActionData: File: NLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 803328
ActionData: File: NLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 803328
ActionData: File: NLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 781824
ActionData: File: NLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 803328
ActionData: File: NLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 803328
ActionData: File: NLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 803328
ActionData: File: NLog.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 813568
ActionData: File: NLog.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 821248
ActionData: File: NLog.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 45056
ActionData: File: NLog.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 45056
ActionData: File: NLog.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 45056
ActionData: File: NLog.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 45056
ActionData: File: NLog.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 45056
ActionData: File: NLog.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 45056
ActionData: File: NLog.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 45056
ActionData: File: NLog.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 53248
ActionData: File: NLog.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 46080
ActionData: File: NLog.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 45056
ActionData: File: NLog.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 48128
ActionData: File: NLog.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 45056
ActionData: File: NLog.Extensions.Logging.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 45056
ActionData: File: NLog.Targets.ElasticSearch.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 30720
ActionData: File: NLog.Targets.ElasticSearch.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 30720
ActionData: File: NLog.Targets.ElasticSearch.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 30720
ActionData: File: NLog.Targets.ElasticSearch.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 30720
ActionData: File: NLog.Targets.ElasticSearch.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 30720
ActionData: File: NLog.Targets.ElasticSearch.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 30720
ActionData: File: NLog.Targets.ElasticSearch.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 30720
ActionData: File: NLog.Targets.ElasticSearch.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 30720
ActionData: File: NLog.Targets.ElasticSearch.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 30720
ActionData: File: NLog.Targets.ElasticSearch.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 30720
ActionData: File: NLog.Targets.ElasticSearch.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 30720
ActionData: File: NLog.Targets.ElasticSearch.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 30720
ActionData: File: NLog.Web.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 49152
ActionData: File: NLog.Web.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 43008
ActionData: File: NLog.Web.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 43008
ActionData: File: NLog.Web.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 43008
ActionData: File: NLog.Web.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 43008
ActionData: File: NLog.Web.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 43008
ActionData: File: NLog.Web.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 42496
ActionData: File: NLog.Web.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 42496
ActionData: File: NLog.Web.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 42496
ActionData: File: NLog.Web.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 43008
ActionData: File: NLog.Web.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 51712
ActionData: File: NLog.Web.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 43008
ActionData: File: NLog.Web.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 46592
ActionData: File: Novell.Directory.Ldap.NETStandard.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 238080
ActionData: File: NuGet.Commands.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 388288
ActionData: File: NuGet.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 81664
ActionData: File: NuGet.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 86224
ActionData: File: NuGet.ContentModel.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 44760
ActionData: File: NuGet.DependencyResolver.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 64248
ActionData: File: NuGet.Frameworks.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 108688
ActionData: File: NuGet.Frameworks.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 108688
ActionData: File: NuGet.Frameworks.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 107264
ActionData: File: NuGet.LibraryModel.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 44744
ActionData: File: NuGet.PackageManagement.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 341504
ActionData: File: NuGet.Packaging.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 49408
ActionData: File: NuGet.Packaging.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 251648
ActionData: File: NuGet.ProjectModel.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 141000
ActionData: File: NuGet.Protocol.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 623800
ActionData: File: NuGet.Resolver.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 69304
ActionData: File: NuGet.Versioning.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 50944
ActionData: File: NWebsec.AspNetCore.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 58368
ActionData: File: NWebsec.AspNetCore.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 58368
ActionData: File: NWebsec.AspNetCore.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 58368
ActionData: File: NWebsec.AspNetCore.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 58368
ActionData: File: NWebsec.AspNetCore.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 58368
ActionData: File: NWebsec.AspNetCore.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 58368
ActionData: File: NWebsec.AspNetCore.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 58368
ActionData: File: NWebsec.AspNetCore.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 58368
ActionData: File: NWebsec.AspNetCore.Middleware.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 18944
ActionData: File: NWebsec.AspNetCore.Middleware.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 18944
ActionData: File: NWebsec.AspNetCore.Middleware.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 18944
ActionData: File: NWebsec.AspNetCore.Middleware.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 18944
ActionData: File: NWebsec.AspNetCore.Middleware.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 18944
ActionData: File: NWebsec.AspNetCore.Middleware.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 18944
ActionData: File: NWebsec.AspNetCore.Middleware.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 18944
ActionData: File: NWebsec.AspNetCore.Middleware.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 18944
ActionData: File: OpenTelemetry.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 55808
ActionData: File: OpenTelemetry.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 55808
ActionData: File: OpenTelemetry.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 55808
ActionData: File: OpenTelemetry.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 55808
ActionData: File: OpenTelemetry.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 55808
ActionData: File: OpenTelemetry.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 55808
ActionData: File: OpenTelemetry.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 55808
ActionData: File: OpenTelemetry.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 55808
ActionData: File: OpenTelemetry.Api.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 55808
ActionData: File: OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.EntityFrameworkCore.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 36352
ActionData: File: OpenTelemetry.Contrib.Instrumentation.MassTransit.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 36352
ActionData: File: OpenTelemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 122880
ActionData: File: OpenTelemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 122880
ActionData: File: OpenTelemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 122880
ActionData: File: OpenTelemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 122880
ActionData: File: OpenTelemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 122880
ActionData: File: OpenTelemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 122880
ActionData: File: OpenTelemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 122880
ActionData: File: OpenTelemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 122880
ActionData: File: OpenTelemetry.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 122880
ActionData: File: OpenTelemetry.Exporter.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 19968
ActionData: File: OpenTelemetry.Exporter.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 19968
ActionData: File: OpenTelemetry.Exporter.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 19968
ActionData: File: OpenTelemetry.Exporter.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 19968
ActionData: File: OpenTelemetry.Exporter.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 19968
ActionData: File: OpenTelemetry.Exporter.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 19968
ActionData: File: OpenTelemetry.Exporter.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 19968
ActionData: File: OpenTelemetry.Exporter.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 19968
ActionData: File: OpenTelemetry.Exporter.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 19968
ActionData: File: OpenTelemetry.Exporter.Jaeger.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 81920
ActionData: File: OpenTelemetry.Exporter.Jaeger.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 81920
ActionData: File: OpenTelemetry.Exporter.Jaeger.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 81920
ActionData: File: OpenTelemetry.Exporter.Jaeger.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 81920
ActionData: File: OpenTelemetry.Exporter.Jaeger.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 81920
ActionData: File: OpenTelemetry.Exporter.Jaeger.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 81920
ActionData: File: OpenTelemetry.Exporter.Jaeger.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 81920
ActionData: File: OpenTelemetry.Exporter.Jaeger.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 81920
ActionData: File: OpenTelemetry.Exporter.Jaeger.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 81920
ActionData: File: OpenTelemetry.Exporter.OpenTelemetryProtocol.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 252416
ActionData: File: OpenTelemetry.Exporter.OpenTelemetryProtocol.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 252416
ActionData: File: OpenTelemetry.Exporter.OpenTelemetryProtocol.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 252416
ActionData: File: OpenTelemetry.Exporter.OpenTelemetryProtocol.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 252416
ActionData: File: OpenTelemetry.Exporter.OpenTelemetryProtocol.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 252416
ActionData: File: OpenTelemetry.Exporter.OpenTelemetryProtocol.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 252416
ActionData: File: OpenTelemetry.Exporter.OpenTelemetryProtocol.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 252416
ActionData: File: OpenTelemetry.Exporter.OpenTelemetryProtocol.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 252416
ActionData: File: OpenTelemetry.Exporter.OpenTelemetryProtocol.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 252416
ActionData: File: OpenTelemetry.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 16896
ActionData: File: OpenTelemetry.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 16896
ActionData: File: OpenTelemetry.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 16896
ActionData: File: OpenTelemetry.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 16896
ActionData: File: OpenTelemetry.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 16896
ActionData: File: OpenTelemetry.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 16896
ActionData: File: OpenTelemetry.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 16896
ActionData: File: OpenTelemetry.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 16896
ActionData: File: OpenTelemetry.Extensions.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 16896
ActionData: File: OpenTelemetry.Instrumentation.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 40960
ActionData: File: OpenTelemetry.Instrumentation.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 40960
ActionData: File: OpenTelemetry.Instrumentation.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 40960
ActionData: File: OpenTelemetry.Instrumentation.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 40960
ActionData: File: OpenTelemetry.Instrumentation.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 40960
ActionData: File: OpenTelemetry.Instrumentation.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 40960
ActionData: File: OpenTelemetry.Instrumentation.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 40960
ActionData: File: OpenTelemetry.Instrumentation.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 40960
ActionData: File: OpenTelemetry.Instrumentation.AspNetCore.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 40960
ActionData: File: OpenTelemetry.Instrumentation.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 38912
ActionData: File: OpenTelemetry.Instrumentation.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 38912
ActionData: File: OpenTelemetry.Instrumentation.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 38912
ActionData: File: OpenTelemetry.Instrumentation.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 38912
ActionData: File: OpenTelemetry.Instrumentation.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 38912
ActionData: File: OpenTelemetry.Instrumentation.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 38912
ActionData: File: OpenTelemetry.Instrumentation.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 38912
ActionData: File: OpenTelemetry.Instrumentation.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 38912
ActionData: File: OpenTelemetry.Instrumentation.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 38912
ActionData: File: OpenTelemetry.Instrumentation.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 37376
ActionData: File: OpenTelemetry.Instrumentation.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 37376
ActionData: File: OpenTelemetry.Instrumentation.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 37376
ActionData: File: OpenTelemetry.Instrumentation.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 37376
ActionData: File: OpenTelemetry.Instrumentation.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 37376
ActionData: File: OpenTelemetry.Instrumentation.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 37376
ActionData: File: OpenTelemetry.Instrumentation.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 37376
ActionData: File: OpenTelemetry.Instrumentation.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 37376
ActionData: File: OpenTelemetry.Instrumentation.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 37376
ActionData: File: packages.config, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\, Size: 427
ActionData: File: precache-manifest.5d0155ae2e2b0a02a86b7a45531a4c20.js, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\, Size: 1548
ActionData: File: RabbitMQ.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 272896
ActionData: File: RabbitMQ.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 272896
ActionData: File: RabbitMQ.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 272896
ActionData: File: RabbitMQ.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 272896
ActionData: File: RabbitMQ.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 272896
ActionData: File: RabbitMQ.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 272896
ActionData: File: RabbitMQ.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 272896
ActionData: File: RabbitMQ.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 272896
ActionData: File: RabbitMQ.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 272896
ActionData: File: RefreshTokenMigration.sql, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrations\SqlScripts\, Size: 692
ActionData: File: RefreshTokenMigration.sql, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Migrations\SqlScripts\, Size: 692
ActionData: File: RemoveAllEmailSenders.sql, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Scripts\Senders\, Size: 24
ActionData: File: RenameAuthenticationSettingsTable.sql, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Migrations\SqlScripts\, Size: 1448
ActionData: File: RenameAuthenticationSettingsTable.sql, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrations\SqlScripts\, Size: 1448
ActionData: File: Renci.SshNet.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 424448
ActionData: File: Roboto-Bold.f712717c.woff2, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\media\, Size: 19692
ActionData: File: Roboto-Regular.51095fe9.woff2, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\media\, Size: 19444
ActionData: File: runtime-main.88d2a8d5.js.map, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\js\, Size: 8314
ActionData: File: runtime-main.88d2a8d5.js, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\js\, Size: 1601
ActionData: File: Scrutor.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 50688
ActionData: File: Scrutor.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 50688
ActionData: File: Scrutor.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 50688
ActionData: File: Scrutor.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 50688
ActionData: File: SelectExistedIdents.sql, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\Scripts\Single\, Size: 116
ActionData: File: service-worker.js, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\, Size: 1181
ActionData: File: SixLabors.Fonts.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 104960
ActionData: File: SixLabors.Fonts.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 104960
ActionData: File: SixLabors.Fonts.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 104960
ActionData: File: SixLabors.Fonts.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 104960
ActionData: File: SixLabors.Fonts.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 104960
ActionData: File: SixLabors.ImageSharp.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 1198592
ActionData: File: SixLabors.ImageSharp.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 1198592
ActionData: File: SixLabors.ImageSharp.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 1198592
ActionData: File: SixLabors.ImageSharp.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 1198592
ActionData: File: SixLabors.ImageSharp.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 1198592
ActionData: File: SixLabors.ImageSharp.Drawing.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 177152
ActionData: File: SixLabors.ImageSharp.Drawing.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 177152
ActionData: File: SixLabors.ImageSharp.Drawing.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 177152
ActionData: File: SixLabors.ImageSharp.Drawing.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 177152
ActionData: File: SixLabors.ImageSharp.Drawing.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 177152
ActionData: File: SkiDiveCode.Ldap.Rfc2253.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 20480
ActionData: File: SkiDiveCode.Ldap.Rfc2253.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 20480
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\runtimes\win-x86\native\, Size: 136488
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win-x86\native\, Size: 136488
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win-x64\native\, Size: 160040
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\win-x86\native\, Size: 136488
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\win-x64\native\, Size: 160040
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\runtimes\win-x64\native\, Size: 160040
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\runtimes\win-x86\native\, Size: 136488
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win-x64\native\, Size: 160040
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\runtimes\win-x86\native\, Size: 136488
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\win-x86\native\, Size: 136488
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\runtimes\win-x64\native\, Size: 160040
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win-x64\native\, Size: 160040
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\win-x86\native\, Size: 136488
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\win-arm64\native\, Size: 174224
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\runtimes\win-arm64\native\, Size: 174224
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win-x86\native\, Size: 136488
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\runtimes\win-x86\native\, Size: 136488
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\runtimes\win-arm64\native\, Size: 174224
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win-arm64\native\, Size: 174224
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win-arm64\native\, Size: 174224
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win-arm64\native\, Size: 174224
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\win-x86\native\, Size: 136488
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\runtimes\win-arm64\native\, Size: 174224
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\runtimes\win-x64\native\, Size: 160040
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\win-x64\native\, Size: 160040
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\runtimes\win-x86\native\, Size: 136488
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\win-x64\native\, Size: 160040
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win-x86\native\, Size: 136488
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\runtimes\win-x64\native\, Size: 160040
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\win-arm64\native\, Size: 174224
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\runtimes\win-x86\native\, Size: 136488
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\win-x64\native\, Size: 160040
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\runtimes\win-arm64\native\, Size: 174224
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\win-arm64\native\, Size: 174224
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win-x86\native\, Size: 136488
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win-x64\native\, Size: 160040
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\runtimes\win-arm64\native\, Size: 174224
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\win-arm64\native\, Size: 174224
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\runtimes\win-x64\native\, Size: 160040
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\runtimes\win-arm64\native\, Size: 174224
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\runtimes\win-arm64\native\, Size: 174224
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\runtimes\win-x64\native\, Size: 160040
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\runtimes\win-x64\native\, Size: 160040
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win-arm64\native\, Size: 174224
ActionData: File: sni.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\runtimes\win-x86\native\, Size: 136488
ActionData: File: SQLitePCLRaw.batteries_v2.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 6144
ActionData: File: SQLitePCLRaw.batteries_v2.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 6144
ActionData: File: SQLitePCLRaw.batteries_v2.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 6144
ActionData: File: SQLitePCLRaw.batteries_v2.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 6144
ActionData: File: SQLitePCLRaw.core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 46080
ActionData: File: SQLitePCLRaw.core.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 46080
ActionData: File: SQLitePCLRaw.core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 46080
ActionData: File: SQLitePCLRaw.core.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 46080
ActionData: File: SQLitePCLRaw.nativelibrary.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 5632
ActionData: File: SQLitePCLRaw.nativelibrary.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 5632
ActionData: File: SQLitePCLRaw.nativelibrary.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 5632
ActionData: File: SQLitePCLRaw.nativelibrary.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 5632
ActionData: File: SQLitePCLRaw.provider.dynamic_cdecl.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 56832
ActionData: File: SQLitePCLRaw.provider.dynamic_cdecl.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 56832
ActionData: File: SQLitePCLRaw.provider.dynamic_cdecl.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 56832
ActionData: File: SQLitePCLRaw.provider.dynamic_cdecl.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 56832
ActionData: File: SqlScripts.resx, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\SqlScripts\, Size: 11698
ActionData: File: sqlserver.21.1.18235.nupkg, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Packages\, Size: 24920637
ActionData: File: SshNet.Security.Cryptography.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 34816
ActionData: File: swagger_custom_style.css, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\css\, Size: 242
ActionData: File: Swashbuckle.AspNetCore.Annotations.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 20992
ActionData: File: Swashbuckle.AspNetCore.Annotations.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 18432
ActionData: File: Swashbuckle.AspNetCore.Annotations.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 20480
ActionData: File: Swashbuckle.AspNetCore.Annotations.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 20480
ActionData: File: Swashbuckle.AspNetCore.Swagger.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 14848
ActionData: File: Swashbuckle.AspNetCore.Swagger.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 13824
ActionData: File: Swashbuckle.AspNetCore.Swagger.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 14848
ActionData: File: Swashbuckle.AspNetCore.Swagger.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 14848
ActionData: File: Swashbuckle.AspNetCore.SwaggerGen.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 73728
ActionData: File: Swashbuckle.AspNetCore.SwaggerGen.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 82944
ActionData: File: Swashbuckle.AspNetCore.SwaggerGen.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 82944
ActionData: File: Swashbuckle.AspNetCore.SwaggerGen.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 84480
ActionData: File: Swashbuckle.AspNetCore.SwaggerUI.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 3724800
ActionData: File: Swashbuckle.AspNetCore.SwaggerUI.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 1900544
ActionData: File: Swashbuckle.AspNetCore.SwaggerUI.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 3729408
ActionData: File: Swashbuckle.AspNetCore.SwaggerUI.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 3729408
ActionData: File: System.AppContext.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14408
ActionData: File: System.Buffers.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15224
ActionData: File: System.Collections.Concurrent.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 26184
ActionData: File: System.Collections.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 42056
ActionData: File: System.Collections.Immutable.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 59976
ActionData: File: System.Collections.NonGeneric.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 21576
ActionData: File: System.Collections.Specialized.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 23112
ActionData: File: System.ComponentModel.Annotations.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 89992
ActionData: File: System.ComponentModel.Annotations.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 28544
ActionData: File: System.ComponentModel.Annotations.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 89992
ActionData: File: System.ComponentModel.Annotations.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 89992
ActionData: File: System.ComponentModel.Annotations.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 89992
ActionData: File: System.ComponentModel.Annotations.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 89992
ActionData: File: System.ComponentModel.Annotations.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 89992
ActionData: File: System.ComponentModel.DataAnnotations.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15224
ActionData: File: System.ComponentModel.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14952
ActionData: File: System.ComponentModel.EventBasedAsync.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17992
ActionData: File: System.ComponentModel.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 22088
ActionData: File: System.ComponentModel.TypeConverter.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 90696
ActionData: File: System.Composition.AttributedModel.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 24840
ActionData: File: System.Composition.AttributedModel.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 24840
ActionData: File: System.Composition.Convention.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 59128
ActionData: File: System.Composition.Convention.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 59128
ActionData: File: System.Composition.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 62184
ActionData: File: System.Composition.Hosting.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 62184
ActionData: File: System.Composition.Runtime.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 29928
ActionData: File: System.Composition.Runtime.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 29928
ActionData: File: System.Composition.TypedParts.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 64760
ActionData: File: System.Composition.TypedParts.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 64760
ActionData: File: System.Configuration.ConfigurationManager.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 375912
ActionData: File: System.Configuration.ConfigurationManager.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 382096
ActionData: File: System.Configuration.ConfigurationManager.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 381832
ActionData: File: System.Configuration.ConfigurationManager.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 375912
ActionData: File: System.Configuration.ConfigurationManager.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 381832
ActionData: File: System.Configuration.ConfigurationManager.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 375912
ActionData: File: System.Configuration.ConfigurationManager.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 375912
ActionData: File: System.Configuration.ConfigurationManager.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 375912
ActionData: File: System.Configuration.ConfigurationManager.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 375912
ActionData: File: System.Configuration.ConfigurationManager.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 375912
ActionData: File: System.Configuration.ConfigurationManager.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 382096
ActionData: File: System.Configuration.ConfigurationManager.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 375912
ActionData: File: System.Configuration.ConfigurationManager.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 375912
ActionData: File: System.Configuration.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17992
ActionData: File: System.Console.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 23624
ActionData: File: System.Core.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 22088
ActionData: File: System.Data.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 130120
ActionData: File: System.Data.DataSetExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14408
ActionData: File: System.Data.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 22600
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\runtimes\unix\lib\netcoreapp2.1\, Size: 943152
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 260848
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 237424
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\runtimes\win\lib\netcoreapp2.1\, Size: 995072
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\runtimes\unix\lib\netcoreapp2.1\, Size: 943152
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win\lib\netcoreapp2.1\, Size: 995072
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\runtimes\unix\lib\netcoreapp2.1\, Size: 954752
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 260848
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 260848
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netcoreapp2.1\, Size: 995072
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\unix\lib\netcoreapp2.1\, Size: 943152
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\unix\lib\netcoreapp2.1\, Size: 943152
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\unix\lib\netcoreapp2.1\, Size: 943152
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\runtimes\win\lib\netcoreapp2.1\, Size: 995072
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 260848
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\runtimes\win\lib\netcoreapp2.1\, Size: 995072
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 260848
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\runtimes\unix\lib\netcoreapp2.1\, Size: 943152
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 260848
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 267136
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\runtimes\win\lib\netcoreapp2.1\, Size: 1023360
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.1\, Size: 995072
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 260848
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\runtimes\unix\lib\netcoreapp2.1\, Size: 943152
ActionData: File: System.Data.SqlClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\runtimes\win\lib\netcoreapp2.1\, Size: 995072
ActionData: File: System.Diagnostics.Contracts.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 19528
ActionData: File: System.Diagnostics.Debug.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 19528
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 83336
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 83336
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 152688
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 152688
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 152688
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 83336
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 152688
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 152688
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 152688
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 83336
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 83336
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 152688
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 83336
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 152688
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 83336
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 152688
ActionData: File: System.Diagnostics.DiagnosticSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 83336
ActionData: File: System.Diagnostics.EventLog.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 49256
ActionData: File: System.Diagnostics.EventLog.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netcoreapp2.0\, Size: 129608
ActionData: File: System.Diagnostics.EventLog.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 34168
ActionData: File: System.Diagnostics.FileVersionInfo.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15976
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 49224
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 49224
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\win\lib\netcoreapp2.0\, Size: 124488
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.0\, Size: 112272
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 49224
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 46224
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 49224
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\win\lib\netcoreapp2.0\, Size: 124488
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\runtimes\win\lib\netcoreapp2.0\, Size: 124488
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 49224
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 49224
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\win\lib\netcoreapp2.0\, Size: 124488
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\runtimes\win\lib\netcoreapp2.0\, Size: 124488
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\win\lib\netcoreapp2.0\, Size: 124488
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 49224
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\runtimes\win\lib\netcoreapp2.0\, Size: 124488
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp2.0\, Size: 124488
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 49224
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\runtimes\win\lib\netcoreapp2.0\, Size: 124488
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 25672
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 46224
ActionData: File: System.Diagnostics.PerformanceCounter.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 49224
ActionData: File: System.Diagnostics.Process.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 27208
ActionData: File: System.Diagnostics.StackTrace.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 22088
ActionData: File: System.Diagnostics.TextWriterTraceListener.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16456
ActionData: File: System.Diagnostics.Tools.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15944
ActionData: File: System.Diagnostics.TraceSource.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 25160
ActionData: File: System.Diagnostics.Tracing.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 26184
ActionData: File: System.DirectoryServices.AccountManagement.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp2.0\, Size: 275840
ActionData: File: System.DirectoryServices.AccountManagement.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.0\, Size: 275840
ActionData: File: System.DirectoryServices.AccountManagement.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 74112
ActionData: File: System.DirectoryServices.AccountManagement.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 74112
ActionData: File: System.DirectoryServices.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp2.0\, Size: 369544
ActionData: File: System.DirectoryServices.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 126344
ActionData: File: System.DirectoryServices.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.0\, Size: 369544
ActionData: File: System.DirectoryServices.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 126344
ActionData: File: System.DirectoryServices.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.0\, Size: 137096
ActionData: File: System.DirectoryServices.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\osx\lib\netcoreapp2.0\, Size: 138632
ActionData: File: System.DirectoryServices.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 74624
ActionData: File: System.DirectoryServices.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\linux\lib\netcoreapp2.0\, Size: 137600
ActionData: File: System.DirectoryServices.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp2.0\, Size: 137096
ActionData: File: System.DirectoryServices.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\linux\lib\netcoreapp2.0\, Size: 137600
ActionData: File: System.DirectoryServices.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\osx\lib\netcoreapp2.0\, Size: 138632
ActionData: File: System.DirectoryServices.Protocols.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 74624
ActionData: File: System.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 48712
ActionData: File: System.Drawing.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 173448
ActionData: File: System.Drawing.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 143408
ActionData: File: System.Drawing.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\unix\lib\netcoreapp3.0\, Size: 372840
ActionData: File: System.Drawing.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\unix\lib\netcoreapp3.0\, Size: 419208
ActionData: File: System.Drawing.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 173448
ActionData: File: System.Drawing.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp3.0\, Size: 437128
ActionData: File: System.Drawing.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netcoreapp3.0\, Size: 414280
ActionData: File: System.Drawing.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\unix\lib\netcoreapp3.0\, Size: 419208
ActionData: File: System.Drawing.Common.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp3.0\, Size: 437128
ActionData: File: System.Drawing.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 19560
ActionData: File: System.Drawing.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 32360
ActionData: File: System.Dynamic.Runtime.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15432
ActionData: File: System.Globalization.Calendars.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14920
ActionData: File: System.Globalization.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14408
ActionData: File: System.Globalization.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14408
ActionData: File: System.IdentityModel.Tokens.Jwt.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 81784
ActionData: File: System.IdentityModel.Tokens.Jwt.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 89640
ActionData: File: System.IdentityModel.Tokens.Jwt.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 89640
ActionData: File: System.IdentityModel.Tokens.Jwt.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 89640
ActionData: File: System.IdentityModel.Tokens.Jwt.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 89640
ActionData: File: System.IdentityModel.Tokens.Jwt.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 89640
ActionData: File: System.IdentityModel.Tokens.Jwt.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 89640
ActionData: File: System.IdentityModel.Tokens.Jwt.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 89640
ActionData: File: System.IdentityModel.Tokens.Jwt.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 89640
ActionData: File: System.IdentityModel.Tokens.Jwt.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 89640
ActionData: File: System.IdentityModel.Tokens.Jwt.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 82792
ActionData: File: System.IdentityModel.Tokens.Jwt.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 89640
ActionData: File: System.IdentityModel.Tokens.Jwt.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 89112
ActionData: File: System.IO.Compression.Brotli.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16456
ActionData: File: System.IO.Compression.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 18504
ActionData: File: System.IO.Compression.FileSystem.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 13896
ActionData: File: System.IO.Compression.ZipFile.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15432
ActionData: File: System.IO.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14920
ActionData: File: System.IO.FileSystem.AccessControl.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 19016
ActionData: File: System.IO.FileSystem.AccessControl.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netstandard2.0\, Size: 63368
ActionData: File: System.IO.FileSystem.AccessControl.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 31624
ActionData: File: System.IO.FileSystem.AccessControl.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 31624
ActionData: File: System.IO.FileSystem.AccessControl.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netstandard2.0\, Size: 63368
ActionData: File: System.IO.FileSystem.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 27240
ActionData: File: System.IO.FileSystem.DriveInfo.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15432
ActionData: File: System.IO.FileSystem.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14408
ActionData: File: System.IO.FileSystem.Watcher.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 18296
ActionData: File: System.IO.IsolatedStorage.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 21064
ActionData: File: System.IO.MemoryMappedFiles.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17480
ActionData: File: System.IO.Pipelines.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 19016
ActionData: File: System.IO.Pipes.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 20040
ActionData: File: System.IO.UnmanagedMemoryStream.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14408
ActionData: File: System.Linq.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 26696
ActionData: File: System.Linq.Expressions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 57448
ActionData: File: System.Linq.Parallel.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 28744
ActionData: File: System.Linq.Queryable.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 24440
ActionData: File: System.Memory.Data.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 21368
ActionData: File: System.Memory.Data.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 21368
ActionData: File: System.Memory.Data.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 21368
ActionData: File: System.Memory.Data.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 21368
ActionData: File: System.Memory.Data.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 21368
ActionData: File: System.Memory.Data.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 21368
ActionData: File: System.Memory.Data.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 21368
ActionData: File: System.Memory.Data.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 21368
ActionData: File: System.Memory.Data.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 21368
ActionData: File: System.Memory.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 38776
ActionData: File: System.Net.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15976
ActionData: File: System.Net.Http.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 41544
ActionData: File: System.Net.HttpListener.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 22904
ActionData: File: System.Net.Mail.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 27512
ActionData: File: System.Net.NameResolution.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16456
ActionData: File: System.Net.NetworkInformation.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 30792
ActionData: File: System.Net.Ping.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17992
ActionData: File: System.Net.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 30792
ActionData: File: System.Net.Requests.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 34376
ActionData: File: System.Net.Security.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 44616
ActionData: File: System.Net.ServicePoint.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 18296
ActionData: File: System.Net.Sockets.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 39288
ActionData: File: System.Net.WebClient.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 25464
ActionData: File: System.Net.WebHeaderCollection.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17784
ActionData: File: System.Net.WebProxy.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16248
ActionData: File: System.Net.WebSockets.Client.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16760
ActionData: File: System.Net.WebSockets.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 19320
ActionData: File: System.Net.WebSockets.WebSocketProtocol.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 56048
ActionData: File: System.Numerics.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14408
ActionData: File: System.Numerics.Vectors.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 33864
ActionData: File: System.ObjectModel.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 27512
ActionData: File: System.Reflection.DispatchProxy.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14408
ActionData: File: System.Reflection.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15432
ActionData: File: System.Reflection.Emit.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 36728
ActionData: File: System.Reflection.Emit.ILGeneration.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 20040
ActionData: File: System.Reflection.Emit.Lightweight.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 18296
ActionData: File: System.Reflection.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14200
ActionData: File: System.Reflection.Metadata.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 115272
ActionData: File: System.Reflection.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 21576
ActionData: File: System.Reflection.TypeExtensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17480
ActionData: File: System.Resources.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 56192
ActionData: File: System.Resources.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 56192
ActionData: File: System.Resources.NetStandard.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 704000
ActionData: File: System.Resources.Reader.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14408
ActionData: File: System.Resources.ResourceManager.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 19016
ActionData: File: System.Resources.Writer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14920
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 36496
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\win\lib\netcoreapp2.0\, Size: 93832
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\win\lib\netcoreapp2.0\, Size: 93832
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\runtimes\win\lib\netcoreapp2.0\, Size: 93832
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 83528
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\unix\lib\netcoreapp2.0\, Size: 91792
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 36496
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 36496
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\unix\lib\netcoreapp2.0\, Size: 91792
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.0\, Size: 93832
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netstandard2.0\, Size: 86088
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\win\lib\netcoreapp2.0\, Size: 93832
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\runtimes\win\lib\netcoreapp2.0\, Size: 93832
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\runtimes\unix\lib\netcoreapp2.0\, Size: 91792
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\runtimes\unix\lib\netcoreapp2.0\, Size: 91792
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 36496
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\unix\lib\netcoreapp2.0\, Size: 91792
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win\lib\netcoreapp2.0\, Size: 93832
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 36496
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\unix\lib\netcoreapp2.0\, Size: 91792
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 36496
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 36496
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\win\lib\netcoreapp2.0\, Size: 93832
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp2.0\, Size: 93832
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 36496
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\unix\lib\netcoreapp2.0\, Size: 91792
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 36496
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 36496
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\unix\lib\netcoreapp2.0\, Size: 91792
ActionData: File: System.Runtime.Caching.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\unix\lib\netcoreapp2.0\, Size: 91792
ActionData: File: System.Runtime.CompilerServices.Unsafe.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 18024
ActionData: File: System.Runtime.CompilerServices.Unsafe.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 18024
ActionData: File: System.Runtime.CompilerServices.Unsafe.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 18024
ActionData: File: System.Runtime.CompilerServices.Unsafe.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 18024
ActionData: File: System.Runtime.CompilerServices.Unsafe.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 18024
ActionData: File: System.Runtime.CompilerServices.Unsafe.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 18024
ActionData: File: System.Runtime.CompilerServices.Unsafe.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 18024
ActionData: File: System.Runtime.CompilerServices.Unsafe.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 18024
ActionData: File: System.Runtime.CompilerServices.Unsafe.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 18024
ActionData: File: System.Runtime.CompilerServices.Unsafe.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 18024
ActionData: File: System.Runtime.CompilerServices.VisualC.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15944
ActionData: File: System.Runtime.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 330824
ActionData: File: System.Runtime.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 80968
ActionData: File: System.Runtime.Handles.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14408
ActionData: File: System.Runtime.InteropServices.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 63560
ActionData: File: System.Runtime.InteropServices.RuntimeInformation.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15432
ActionData: File: System.Runtime.InteropServices.WindowsRuntime.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17480
ActionData: File: System.Runtime.Intrinsics.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 75128
ActionData: File: System.Runtime.Loader.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17992
ActionData: File: System.Runtime.Numerics.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 22088
ActionData: File: System.Runtime.Serialization.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15944
ActionData: File: System.Runtime.Serialization.Formatters.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 21064
ActionData: File: System.Runtime.Serialization.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 18504
ActionData: File: System.Runtime.Serialization.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17992
ActionData: File: System.Runtime.Serialization.Xml.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 32840
ActionData: File: System.Security.AccessControl.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.0\, Size: 102280
ActionData: File: System.Security.AccessControl.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 55688
ActionData: File: System.Security.AccessControl.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 33352
ActionData: File: System.Security.AccessControl.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp2.0\, Size: 102280
ActionData: File: System.Security.AccessControl.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 55688
ActionData: File: System.Security.Claims.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 30280
ActionData: File: System.Security.Cryptography.Algorithms.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 36424
ActionData: File: System.Security.Cryptography.Cng.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 27720
ActionData: File: System.Security.Cryptography.Csp.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 24648
ActionData: File: System.Security.Cryptography.Encoding.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 18504
ActionData: File: System.Security.Cryptography.Pkcs.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 186504
ActionData: File: System.Security.Cryptography.Pkcs.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netcoreapp2.1\, Size: 211088
ActionData: File: System.Security.Cryptography.Primitives.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 22600
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 17784
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 25232
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netstandard2.0\, Size: 33152
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\runtimes\win\lib\netstandard2.0\, Size: 25464
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 17784
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 17784
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 25232
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 17784
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 17784
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 17784
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\runtimes\win\lib\netstandard2.0\, Size: 25464
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netstandard2.0\, Size: 33152
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netstandard2.0\, Size: 25464
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\runtimes\win\lib\netstandard2.0\, Size: 25464
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 21384
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\runtimes\win\lib\netstandard2.0\, Size: 25464
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\runtimes\win\lib\netstandard2.0\, Size: 25464
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\runtimes\win\lib\netstandard2.0\, Size: 25464
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 17784
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\runtimes\win\lib\netstandard2.0\, Size: 32912
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 21384
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\runtimes\win\lib\netstandard2.0\, Size: 25464
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 17784
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\runtimes\win\lib\netstandard2.0\, Size: 25464
ActionData: File: System.Security.Cryptography.ProtectedData.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 17784
ActionData: File: System.Security.Cryptography.X509Certificates.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 34888
ActionData: File: System.Security.Cryptography.Xml.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 36216
ActionData: File: System.Security.Cryptography.Xml.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 167568
ActionData: File: System.Security.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 16968
ActionData: File: System.Security.Permissions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 97160
ActionData: File: System.Security.Permissions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 72056
ActionData: File: System.Security.Permissions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 92536
ActionData: File: System.Security.Permissions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 97160
ActionData: File: System.Security.Principal.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15432
ActionData: File: System.Security.Principal.Windows.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 37768
ActionData: File: System.Security.Principal.Windows.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp2.1\, Size: 81800
ActionData: File: System.Security.Principal.Windows.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp2.1\, Size: 81800
ActionData: File: System.Security.Principal.Windows.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 24952
ActionData: File: System.Security.Principal.Windows.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 37768
ActionData: File: System.Security.Principal.Windows.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\unix\lib\netcoreapp2.1\, Size: 37768
ActionData: File: System.Security.Principal.Windows.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\unix\lib\netcoreapp2.1\, Size: 37768
ActionData: File: System.Security.SecureString.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14408
ActionData: File: System.ServiceModel.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15224
ActionData: File: System.ServiceProcess.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14920
ActionData: File: System.ServiceProcess.ServiceController.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\runtimes\win\lib\netstandard2.0\, Size: 59768
ActionData: File: System.ServiceProcess.ServiceController.dll, Directory: C:\Program Files (x86)\Blue Prism\Log Service\, Size: 30584
ActionData: File: System.ServiceProcess.ServiceController.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\runtimes\win\lib\netstandard2.0\, Size: 59768
ActionData: File: System.ServiceProcess.ServiceController.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 30584
ActionData: File: System.ServiceProcess.ServiceController.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 37000
ActionData: File: System.Spatial.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 137632
ActionData: File: System.Spatial.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\de\, Size: 26720
ActionData: File: System.Spatial.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\fr\, Size: 27224
ActionData: File: System.Spatial.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hant\, Size: 25688
ActionData: File: System.Spatial.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\zh-Hans\, Size: 26200
ActionData: File: System.Spatial.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\es\, Size: 26712
ActionData: File: System.Spatial.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ja\, Size: 27744
ActionData: File: System.Spatial.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ru\, Size: 29272
ActionData: File: System.Spatial.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\ko\, Size: 27224
ActionData: File: System.Spatial.resources.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\it\, Size: 26712
ActionData: File: System.Text.Encoding.CodePages.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14408
ActionData: File: System.Text.Encoding.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14952
ActionData: File: System.Text.Encoding.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 19528
ActionData: File: System.Text.Encodings.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 170360
ActionData: File: System.Text.Encodings.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 56184
ActionData: File: System.Text.Encodings.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 170360
ActionData: File: System.Text.Encodings.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 170360
ActionData: File: System.Text.Encodings.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 170360
ActionData: File: System.Text.Encodings.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 170360
ActionData: File: System.Text.Encodings.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 170360
ActionData: File: System.Text.Encodings.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 170360
ActionData: File: System.Text.Encodings.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 56184
ActionData: File: System.Text.Encodings.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 170360
ActionData: File: System.Text.Encodings.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 56184
ActionData: File: System.Text.Encodings.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 170360
ActionData: File: System.Text.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 352128
ActionData: File: System.Text.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\Migrator\, Size: 351624
ActionData: File: System.Text.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\Migrator\, Size: 351624
ActionData: File: System.Text.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Migrator\, Size: 351624
ActionData: File: System.Text.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 351624
ActionData: File: System.Text.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 352128
ActionData: File: System.Text.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 352128
ActionData: File: System.Text.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 352128
ActionData: File: System.Text.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\Migrator\, Size: 351624
ActionData: File: System.Text.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 352128
ActionData: File: System.Text.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 351624
ActionData: File: System.Text.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 351624
ActionData: File: System.Text.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 352128
ActionData: File: System.Text.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 352128
ActionData: File: System.Text.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 352128
ActionData: File: System.Text.Json.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 352128
ActionData: File: System.Text.RegularExpressions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 28744
ActionData: File: System.Threading.Channels.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 49536
ActionData: File: System.Threading.Channels.dll, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 49536
ActionData: File: System.Threading.Channels.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 49536
ActionData: File: System.Threading.Channels.dll, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 49536
ActionData: File: System.Threading.Channels.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 49536
ActionData: File: System.Threading.Channels.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 49536
ActionData: File: System.Threading.Channels.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 49536
ActionData: File: System.Threading.Channels.dll, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 49536
ActionData: File: System.Threading.Channels.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Migrator\, Size: 49536
ActionData: File: System.Threading.Channels.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service Listener\, Size: 49536
ActionData: File: System.Threading.Channels.dll, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 49536
ActionData: File: System.Threading.Channels.dll, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 49536
ActionData: File: System.Threading.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 30280
ActionData: File: System.Threading.Overlapped.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17992
ActionData: File: System.Threading.Tasks.Dataflow.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 29256
ActionData: File: System.Threading.Tasks.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 21096
ActionData: File: System.Threading.Tasks.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14712
ActionData: File: System.Threading.Tasks.Parallel.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17992
ActionData: File: System.Threading.Thread.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 22088
ActionData: File: System.Threading.ThreadPool.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 17480
ActionData: File: System.Threading.Timer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15976
ActionData: File: System.Transactions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15432
ActionData: File: System.Transactions.Local.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 22904
ActionData: File: System.ValueTuple.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14200
ActionData: File: System.Web.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 13896
ActionData: File: System.Web.HttpUtility.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15736
ActionData: File: System.Windows.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14440
ActionData: File: System.Windows.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\, Size: 25480
ActionData: File: System.Windows.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\runtimes\win\lib\netcoreapp3.0\, Size: 56184
ActionData: File: System.Windows.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\runtimes\win\lib\netcoreapp3.0\, Size: 42376
ActionData: File: System.Windows.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\runtimes\win\lib\netcoreapp3.0\, Size: 42376
ActionData: File: System.Windows.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\File Service\Migrator\, Size: 25976
ActionData: File: System.Windows.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 25480
ActionData: File: System.Windows.Extensions.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 19320
ActionData: File: System.Xml.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 22600
ActionData: File: System.Xml.Linq.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14920
ActionData: File: System.Xml.ReaderWriter.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 106056
ActionData: File: System.Xml.Serialization.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14920
ActionData: File: System.Xml.XDocument.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 30792
ActionData: File: System.Xml.XmlDocument.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 14952
ActionData: File: System.Xml.XmlSerializer.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 45160
ActionData: File: System.Xml.XPath.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15432
ActionData: File: System.Xml.XPath.XDocument.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15432
ActionData: File: System.Xml.XPath.XmlDocument.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\Extensions\Enabled\, Size: 118520
ActionData: File: TestEmailBody.html, Directory: C:\Program Files (x86)\Blue Prism\Email Service\Resources\Emails\, Size: 131
ActionData: File: UpdateHubAndInteractClients.sql, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrations\SqlScripts\, Size: 988
ActionData: File: UpdateHubAndInteractClients.sql, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Migrations\SqlScripts\, Size: 988
ActionData: File: UpdateHubAndInteractClientsDown.sql, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrator\Migrations\SqlScripts\, Size: 1078
ActionData: File: UpdateHubAndInteractClientsDown.sql, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\Migrations\SqlScripts\, Size: 1078
ActionData: File: upload.bb2875a3.svg, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\wwwroot\static\media\, Size: 689
ActionData: File: web.config, Directory: C:\Program Files (x86)\Blue Prism\Audit Service\, Size: 564
ActionData: File: Web.config, Directory: C:\Program Files (x86)\Blue Prism\Hub\, Size: 1790
ActionData: File: web.config, Directory: C:\Program Files (x86)\Blue Prism\Notification Center\, Size: 573
ActionData: File: Web.config, Directory: C:\Program Files (x86)\Blue Prism\File Service\, Size: 1527
ActionData: File: web.config, Directory: C:\Program Files (x86)\Blue Prism\Email Service\, Size: 564
ActionData: File: Web.config, Directory: C:\Program Files (x86)\Blue Prism\SignalR\, Size: 1520
ActionData: File: Web.config, Directory: C:\Program Files (x86)\Blue Prism\License Manager\, Size: 1725
ActionData: File: web.config, Directory: C:\Program Files (x86)\Blue Prism\Authentication Server\, Size: 1860
ActionData: File: WindowsBase.dll, Directory: C:\Program Files (x86)\Blue Prism\Hub\refs\, Size: 15224
ActionStart: Action 14:38:45: ApplyDatabaseMigrations.
Info: SFXCA: Extracting custom action to temporary directory: C:\Windows\Installer\MSIA4B4.tmp-\
Info: SFXCA: Binding to CLR version v4.0.30319
Info: Calling custom action BluePrism.Cloud.Base.CustomActions!BluePrism.Cloud.Base.CustomActions.CustomActions.ApplyDatabaseMigrations
Info: Executing Hub migration ...
Info: Success execution result:
Exited with code: 0
OutputText:info: HubMigrations.Handlers.ApplyMigrationsHandlerSuccess execution result:
Exited with code: 0
OutputText:info: HubMigrations.Handlers.ApplyMigrationsHandler[0]
Started applying migrations
Migrations were applied successfully
ErrorText:
Exited with code: 0
ErrorText:
ErrorText:
Exited with code: 0
OutputText:info: HubMigrations.Handlers.InitializeDatabaseHandlerSuccess execution result:
Exited with code: 0
OutputText:info: HubMigrations.Handlers.InitializeDatabaseHandler[0]
Started initialization database
Database was initialized successfully
ErrorText:
Exited with code: 0
ErrorText:
ErrorText:
Info: Executing Authentication Server migration ...
Exited with code: 0
OutputText:info: ImsMigrations.Handlers.ApplyMigrationsHandlerSuccess execution result:
Exited with code: 0
OutputText:info: ImsMigrations.Handlers.ApplyMigrationsHandler[0]
ErrorText:
Exited with code: 0
ErrorText:
ErrorText:
Exited with code: 0
OutputText:info: ImsMigrations.Handlers.InitializeDatabaseHandlerSuccess execution result:
Exited with code: 0
OutputText:info: ImsMigrations.Handlers.InitializeDatabaseHandler[0]
ErrorText:
Exited with code: 0
ErrorText:
ErrorText:
Exited with code: 0
OutputText:info: ImsMigrations.Handlers.AddClientHandlerSuccess execution result:
Exited with code: 0
OutputText:info: ImsMigrations.Handlers.AddClientHandler[0]
Started adding client with id Hub to database
Removed existed client with id Hub
Client with id Hub was added successfully
ErrorText:
Exited with code: 0
ErrorText:
Exited with code: 0
ErrorText:
ErrorText:
Exited with code: 0
Exited with code: 0
Started adding client with id hub-system to database
Removed existed client with id hub-system
Client with id hub-system was added successfully
ErrorText:
Exited with code: 0
ErrorText:
Exited with code: 0
ErrorText:
ErrorText:
Exited with code: 0
Exited with code: 0
Started adding client with id automate to database
Removed existed client with id automate
