C# and J#
BaskaranChidamb
Hi Forum,    Could you kindly help how to create and execute c# and j# codes in global code stage. If you can provide me samples for finding sum of two numbers and using mathematical functions
Firstly, you change your chosen language from the default VB.Net. Then in the Global section you create your method, class, global variable, whatever. Then in a code stage on one of your pages, you call the method. See the Excel VBO for an example.
