Chrome automation issues
14-12-23 01:31 PM
Hello Team,
I'm facing this issue after upgrading to 7.2.1 version.
When we have two applications to run on chrome. First application/object launch works fine and when we are trying to launch second application via different object it is not launching anything and in the second object if you try to attach to application it is attaching to the first application launched irrespective what window titles collection you provide.
Has anyone faced this sort of issue and overcome this. or am I missing anything here
Uday Arikatla
Tech Specialist
Personal
johannesburg
15-12-23 12:10 AM
Hi Uday Arikatla,
Looks like this issue might be fixed - Check below KB article.
If the workaround is not resolving I would suggest to open a ticket with BP
https://support.blueprism.com/en/support/solutions/articles/7000083230
Harish Mogulluri
Lead developer
America/New_York TX
Harish Mogulluri
18-12-23 02:18 PM
This seems to be same issue as what we were facing in 7.1.0. Another problem with "Launch" action in BP 7.1 is that it cannot manage the profiles. Example, if you have 2 Chrome application opening in different user profiles then it doesn't work. Type "chrome://version/" in address bar of both application and check the "Profile Path". As long as it is same, below suggestion might work.
The workaround we applied is to avoid using "Launch" action at all. Use Utility - Environment to Launch application and then add dynamic waits; 1st for Chrome.exe to appear and 2nd for "BluePrismMessagingHost.exe". Now use "Attach" action. This seems to have worked for us so far.
Harshil Mehta
