Could not get process defenition
EddaBurheim
When we try to open a process in process studio, we get the error message:
Facts about the process:
- It is locked and we can't remove the lock
- It started happening after we imported a release of the process with the problem
- We have tried to make a new release, and new import, and get the same error. (Does this mean the problem is in the initial process which we made a release of)
Any sugestions or ideas would help 🙂
Edda Burheim
Senior Consultant
Avo Consulting
Europe/Oslo
vivek.kumar.goel
Q1: Are both environment having same BP version?
Q2: Did you try to create an XML for the particular process and import in the second environment?
Q3: Wil it be possible for you to share a screenshot of the error?
Vivek Goel
RPA Architect
Asia/Singapore
+6594554364
https://www.rpatools.com/
AdrianLaw
@EddaBurheim Hi
Have you already solved the problem?
