Could not open target process
JariKarlsson
Recently updated to BP 7.3.1 and updated the browser extension for Chrome to 7.3 as well.
Ever since then any time my process needs to restart the chrome browser, when it tries to relaunch it it runs into this error.
I have already went through the troubleshooting steps on the blue prism support which seems to suggest it is a UAC issue (it isnt).
Anybody else have any ideas for how to fix this? It doesn't happen when I first launch chrome only after I have to restart it.
7 REPLIES 7
michaeloneil
Hi @JariKarlsson
Im assuming its ms edge chrome and not google chrome? if so it might be that the browser doesn't close completely. If you let the bot close chrome and then check the task manager you'll see there are still some instances of chrome running. Try using the utility - Environment > Read memory stats to get the list of running chrome instances, then loop through the collection and use the action Kill Process for each instance in the collection. Then try relaunching chrome through the bot and see if it launches successfully.
#MVP
arghya.b
Hi @JariKarlsson ,
Try to close chrome/Browser by force kill method(/f). and then before opening browser provide some cooling time like 5 sec in between. And see if it works.
I've got the same issue now...
Same version, running on BPC Win11 machines.
When running as scheduler, I get the "Could not open target process" error, but when running manually, not.
I've gone through all the hoops, use taskkill /IM "msedge.exe" /F to kill edge, added a 10 s arbitrary wait, and also check for processes remaining in memory... all to no avail
I also added a check for the user name, and noticed that when the scheduler is running, the user name returned is actually "Scheduler".
There isn't such a user in the OS... could this be it?
If so... is this a bug? or was it added at some point deliberately? If so, whyyyy?
Andrzej Silarow
asilarow
Found a solution - Ensure that when running resourcepc on the target machine you are not using the /public argument when logging into a domain.
When a domain logon is used, use the /sso argument instead.
Andrzej Silarow
I am facing this issue. Does it work if SSO is not configured but the machine is domain joined? Is it now mandatory to use SSO on domain joined machines?
mparikh
Is there any latest version for Blue Prism Browser Extension then 2.1.0? This came along with the 7.3.0.9110
mparikh_0-1764144185213.pngmparikh_0-1764144185213.pngmparikh_1-1764144214050.pngmparikh_1-1764144214050.png
Edited reply: I fixed it by updating the Blue Prism Browser Extension to 7.3 from Edge addons page. Thanks!
naveed_raza
Level 9
as best practice , before launch close all application forcefully (msedge, chrome, iexplore, outlook) and add 10 secs of pause and post that Launch Stage.
