Effect way of running multiple bots in one server with the help of Login agent
VishnuEnukonda1
Hi, I am looking to run multiple bots in one server, to achieve this i am trying to explore the below two options. concurrently running of different bots in different logins using login agent in one server, Running one bot at a time in one user login in one server. Please suggest any other effective ways for effectively using the server to run multiple bots. Thank You!!
Running parallel Windows sessions is not recommended. Although Blue Prism will run on a server OS it is designed for a desktop OS (and desktop applications) and it's best to stay at 1:1. You can have different user accounts, but it's best to use them in series and not in parallel.
