Exception during remote set forground window . Exception (0X8000405) Access id denied
JaspreetSingh
Hi Team,
I am getting the following error while activating any application which is included in a process however the process was working till yesterday but today we have noticed this weird behavirour.
Failed to perform steps 1 in the navigate stage activate on page. Exception during remote set forground window . Exception (0X8000405) Access id denied
I am using an windows 2019 server for the BOT execution.
Can someone please look into this issue.
(Jaspreet Singh)
Jaspreet Singh
Hi Jaspreet,
Has there been any change in the application? Have you tried re-spying?
Is the process being run in unattended mode? Incase you are using RDP to login to the same VM, it would be advisable to use the Login agent first to LogIn to the VM first(after you have logged out from RDP) before running the process in unattended mode.
Shashank Kumar
Singapore
+6581326707
