Global send keys Enter is not working in loop
NarendraSingh
Thanks for response Manish Rawat
Yes I did try using "~" but the issue continues the same, On the 1st flow it perfectly work fine but on next cycle it's not operating,
Thanks for ref link
Naren
Voip +91 3046277072| Cell +91 9742053564
KrishnaA
Hello Naren,
Did you share your response as a new post instead of a reply?  Could not find the details that Manish shared with you?
Consider moving the loop logic to the process and limit the object design to include only application integration logic.
Also, suggest trying an arbitrary wait of 1 sec for each iteration.
Best regards,
Krishna A
Krishna A [CompanyName]
Hi Krishna,
Think the original thread is here:https://community.blueprism.com/communities/community-home/digestviewer/viewthread?MessageKey=c1751db0-f60d-4844-a5e1-eead17e088f7&CommunityKey=3743dbaa-6766-4a4d-b7ed-9a98b6b1dd01&tab=digestviewer#bm...
Norah
Norah Alsudani
Communities Strategy Director
*Search for the #quick_tip hashtag to get up to speed with everything you need to know about the Community*
