Hot Keys
JustinBishop
Are there any hot keys available for the tool bar items?
ChrisSneddon
Hi Justin, This is the existing set of short-cuts: F1 Help F2 Arrow F3 Link F4 Action F5 Run process F6 Decision F7 Calculation F8 Data Item F9 Collection F10 Step F11 Step Over Shift+F11 Step Out F12 Full Screen CTRL+2 Transparency 20% CTRL+4 Transparency 40% CTRL+8 Transparency 80% CTRL+0 Transparency 100% CTRL+S Save CTRL+Z Undo CTRL+Y Redo CTRL+X Cut CTRL+C Copy CTRL+V Paste CTRL+A Select All SHIFT+Mouse Scroll Zoom CTRL+Mouse Scroll Horizontal scroll CTRL+Q Close ALT+F4 Exit
Hi Chris, Thank you very much. Those are extremely helpful. Justin
