How to Start Training Now
mcandrewe
I have 1165 documents processed. I updated the .config.exe file on the Automated Client Server and switched the Machine learning capability on. However, it just seems to stay in a state of Last Trained N/A.
Also when I go to my training data I can't see a record of anything? Export doesn't do anything either.
Eoin McAndrew
5 REPLIES 5
Ben.Lyons1
Hi Eoin,
I'm assuming you restarted the automated client service after making that change. In addition there are some tips on our troubleshooting page, if you scroll down, you'll see the topic "Machine learning training doesn't seem to be working".
Let me know if you're still having issues after trying these and I'll see if there's anything else we can try.
Ben Lyons
Product Consultant
UK
Ben Lyons
SS&C Blue Prism
UK based
Hi Ben,
Thanks for coming back here. So I have taken a look at the troubleshooting page and restarted the servers. Still no luck.
Eoin
Eoin McAndrew
Hi Eoin,
The most common cause of this is where the services have started in the incorrect order. This can happen if the machine/server is restarted or if there's an issue during the install that prevents the Decipher Server Service from starting. There's a way you can check if this is the cause.
1. Locate your capture client logs (C:\Windows\SysWOW64\config\systemprofile\AppData\Local\Blue Prism\DataCaptureClient\Logs)
2. There will likely be multiple for the same time period as the default is to run as many capture services as the system can reasonably handle
3. Open each of the most recent logs and search for the phrase "The ML plugin is not installed"
If this is found anywhere in one of thee logs, the Capture Client Service has been started prior to the Server Service. There are few steps to resolve this, let me know if you find it.
If not, I would recommend you raise a support ticket so we can investigate further.
Ben Lyons
Product Consultant - Decipher Specialist
UK
Ben Lyons
SS&C Blue Prism
UK based
Thanks for the help Ben,
I had an approx. 2.5 hour call today as part of a support ticket and we managed to resolve a lot of issues.
To summarise the main culprits where:
  • Our DFD being far to simplistic and rebuilding using best practices
  • Machine learning model was not being updated because the 'DataCaptureWorker.exe' process (which is responsible for building the machine learning model), was not running on the automated clients server.
  • An issue with the permissions of the service account running the Decipher services on the web server
Eoin
Eoin McAndrew  Senior RPA Developer  |  Solution Delivery
Laya Healthcare, Eastgate Road, Eastgate Business Park, Little Island, Co Cork.
T: +353 21 202 2363  |   E: Eoin.McAndrew@layahealthcare.ie
W: www.layahealthcare.ie  |  Find Us On Facebook  |  Follow Us On Twitter   |  We provide Health Insurance, Life Insurance and Travel Insurance
The information contained in this email and in any attachments is confidential and is designated solely for the attention and use of the intended recipient(s). Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon this information by persons or entities, other than the intended recipient is prohibited. If you have received this email in error, please notify us immediately and delete all copies of this email from your computer system(s). Any view whatsoever expressed in this message is that of the individual sender, except where the sender specifies, and with authority states, that the view expressed is on behalf of Laya Healthcare Limited. Laya Healthcare Limited trading as laya healthcare is regulated by the Central Bank of Ireland. Laya Healthcare Limited is a private company limited by shares. Registered in Ireland Number 242048. Registered office: Eastgate Road, Eastgate Business Park, Little Island, Co. Cork. Directors: D. Clancy (Managing Director), D.O. O'Connor, Prof. A. O'Doherty, M. Condon, L. O'Dwyer, P. Willcock (United Kingdom), T. Solash (United States). Please consider the environment, do you really need to print this email? Rest assured, Laya Healthcare is committed to protecting your privacy and we take great care in handling your personal information. You can find out more about how we use Personal Information by reading our Privacy Policy available at https://www.layahealthcare.ie/privacypolicy/
Hi Eoin,
That's a great outcome, happy they could get those resolved for you.
Ben Lyons
UK
Ben Lyons
SS&C Blue Prism
UK based
