How to assign acending numbers in priority in work queue
Miya
  I have a collection around some 15-20 rows have sorted  in the ascending order, i want to load them in the work queue with ascending priority eg: row1 --priority 1,row 2 priority 2 etc.. Can some one help on this scenario.
Arthi
Miya
Hi @Miya,
Create a logic to append Priority column inside your collection as shown below:
25518.pngOnce the Priority is available as column Name, then you can write the below logic to achieve the functionality:
  • Loop through the TestData collection (I am using TestData Collection in this example)
  • Add row to the "QueueColl". This will be the collection which we will be adding to the queue.
  • Copy the content of the TestData collection to QueueColl. Since the Start Row starts with 0 in a collection hence reducing 1 from it.
  • Adding data to the queue
  • Finally removing all rows from the QueueColl to loop through the second record.
Hope it helps !!
    Manpreet Kaur
    Manager
    Deloitte
    Hello Miya,
    You can create a Number data item called Priority. Keep this number incrementing in your loop.
    In your Load Queue action pass this Data item in the Priority input parameter.
    This will keep incrementing your priority for each row and you will see items getting added to the queue with increasing priority order.
    Thanks & Regards,
    Tejaskumar Darji
    Sr. Consultant-Technical Lead
       Thank You for quick reply, i have 1 issue when i add, add to queue each time all the rows in the collection added for eg for priority 1, adds priority 1 to all the 15 rows my requirement is row 1 shd have priority1 and row 2 have priority 2etc
    Arthi
    Miya
    Hi @Miya,
    Hope it helps !!
      Manpreet Kaur
      Manager
      Deloitte
