How to get Navigate Drag and Drop actions to work
DT
I need to drag and drop and sign-in slider on a chrome webpage.
I have attempted navigate stage using UIA element drag & drop actions and also using AA element drag & drop actions without success.
element in question as below
18923.pngI see no BP documentation regarding use of drag and drop.
Is the Drag X & Y the starting point (it seems unintuitive to specify the X & Y if the element is already matched/identified by name/ID/class etc).
And I assume the drop is the ending point.
I have set the X & Y drag input being Top Left X & Y of the >> slider element.
And set the X as X + (width of slider bar - width of >> slider element) and Y = Top left of >> slider element.
Any assistance to effectively drag & drop would be appreciated.
Derek
Hi Derek,
Not sure whether you get chance to use  below option. If not I would try those first.
Use focus  before trying any of the option
1) global mouse click center
2) global  send keys
3) global send key events
You probably see the documentation in blue prism navigate stage.
Harish M
Lead developer
America/New_York
Harish Mogulluri
Check if this thread helps,
Link
Thanks & Regards,
Tejaskumar Darji
Sr. Consultant-Technical Lead
Hi Derek,
There is a documentation  for start and stop drag  actions.  in order to open the documentation for the actions.
1)  open  navigation stage and select the information icon in  the navigation stage it will redirect  the documentation based on the version  installed on the PC.
Below screenshot is from Navigate stage
Harish M
Lead developer
America/New_York TX
Harish Mogulluri
