Href links that execute javascript issue
11-03-24 11:00 PM
Good day,
Found this item describing my issue exactly: https://community.blueprism.com/question/chrome-browser-plugin-in-bp-712-is-not-able-to-click-hyperlink-that-wants-to-execute-javascriptdocumentformloginsubmit
It references workarounds: http://portal.blueprism.com/customer-support/support-center#/path/1937431312 which does not seem to exist.
Can someone please advise on workarounds that do work?
Anton Botha
11-03-24 11:28 PM
Hi Antin Botha,
Open this URLhttps://support.blueprism.com/en/support/login and select Are you a customer? Login
Enter the same credentials used for Blue Prism Portal and search with "href" you will find the
Or other way is login to Blue Prism Portal> Select Customer Support>Support> Are you customer? Login> Enter Portal Credentials> Search for href
https://support.blueprism.com/en/support/solutions/articles/7000078851-how-do-i-work-around-the-href-javascript-issue-in-browser-automations-
Harish Mogulluri
Lead developer
America/New_York TX
Harish Mogulluri
12-03-24 12:10 AM
Thank you for your prompt reply, Harish.
Option one is not viable as BP does not recognize the element after restarting the browser.
Option 2 worked only if I did not update the "href" to "". For reference, this is on V6.10.5.
Anton Botha
