Informatica automation
20-09-17 05:07 PM
Hi all ,
can i automate informatica application with blue prism ?
22-09-17 02:37 PM
Hello Subham,
I have never heard of Informatica, but the presumption is you can interface with absolutely any application using Blue Prism. You would use either one of the technical adaptors (Windows/Accessibility/Java/Mainframe Hllapi/Hooking/Browser/etc) or you could use a WebService or API oif Informatica has one that is robust and easy to use or you would use Surface Automation if no elements are exposed in a way that allows those adaptors to work.
So instead of 'can i automate application x' - the question is how best to interface with the appliaction and how difficult will it be (so that I can more accurately schedule the development work that will be required). For that Analysis there is an Applicaiton Assessment template in the Resources/Robotic Operating Model area of this Portal.
25-09-17 09:25 AM
Yes, with Region mode you can create Mappings, you can import Sources,Targets.. in Informatica Powercenter
But i doubt if Linking will be possible, b/t the ports..
:Anusha
