Integration IBM ACS Client and BP v6
PABLOPEREZ-ENCI
We are integrating the IBM ACS Client
Blue Prism version 6.3.2
We create the mainframe object which interacts with the emulator. When executing the "launch", BP shows the following error with the application Appman32.exe
Can you give us a solution?
PABLO PEREZ-ENCISO
Gouthamreddy
Hi
Did you got any solution with IBM i access?
Goutham Ch
