Intermittently Bot not able to identify "SaveAs" window
SandeepKutwal
Hi Team , We can see below exception while saving temporary file at its system temp folder as intermittently Bot not able to identify "SaveAs" window while saving file from IE: Could not save report in C:\Users\bot1\AppData\Local\Temp\tmpxxxx.tmp Please suggest . Thanks, Sandeep
it is impossible to solve this for you without being able to see your flow.  The most likely issue is that your wait logic is not best practice - how are you waiting to ensure your save as dialog exists before attaching to it and using it?
SandeepKutwal
Thanks Denis
SandeepKutwal
Hi Denis, We are using conditional wait time and waiting until save as dialog box is appearing on to the  screen. Once Dialog box appears then we are attaching to it and writing file name.    Please suggest if there is any other way to handle this system popup.
