Is MV2 Manifest Support will be ended 2022 for Microsoft EDGE?
10-11-22 05:47 AM
Hi All,
Someone please confirms, Is it mandatory to update MV3 Manifest (BP browser extension 1.0) in our existing BP 6.10.1 platform which supports JAVASCRIPT before end of December 2022?
How to check an existing robot are using JAVASCRIPT or not? Which tool is available to check from BP side?
Also advise, Is Microsoft extending the MV2 support from their end?
Kalai
Kalai
10-11-22 02:36 PM
Hi Kalai,
Your questions here are all addressed within our Knowledge Base documentation, "URGENT NOTIFICATION RELATED TO USE OF CHROME AND EDGE BROWSERS AS PART OF BLUE PRISM AUTOMATIONS". I would recommend a thorough review of this to help you determine your options, review the updated Google/Microsoft timelines for removal of MV2 support, and for information on the MV3 Assessment Tool which can help you determine which of your automations may be affected.
