Launch and attach issues while working with IBM iAccess Client Solutions
TanyaSachdev
Trying to launch the mainframe application IBM iAccess Client Solutions using the IBM iAccess (EHLLAPI) connector of Blue Prism.
The error received during launch of the application is as follows:
"Error - Failed to launch application - Could not load dll - PCSHLL32.dll " .
  • Also, while attaching to a running instance, the error received is as follows: "Internal : Failed to perform Step 1 in Navigate Stage 'Attach' on page 'Action 1' - Terminal Emulation - Could not load the dll - PCSHLL32.dll"
Tanya Sachdev
Software Engineer
Persistent Systems Ltd
Pune
14 REPLIES 14
JeroenOosterhol
We faced the same issue. Solution for us was to install the EHLLAPI bridge (google "HOD_EHLLAPI_Library-V305_h11_020120419_1020" and use step 2 of the first result).
I use three objects to then use the application:
  1. One to launch the .hod (session file) using start process and then wait for process window
  2. I then attach with a Java object to login the Java part
  3. I then attach with Mainframe IBM Personal Communicator (HLLAPI) for all mainframe actions
Hopefully this solution works for you as well
Jeroen Oosterholt
Automation Designer
DHL
Maastricht
Hi Jeroen,
Tried the above mentioned steps but it did not resolve the issue. Also, the application used is IBM iAccess Client Solutions.
Please let me know if any more steps can be tried.
Tanya Sachdev
Tanya Sachdev
Software Engineer
MarcoMatuttis1
We are also using IBM Mainframe Application in our company. The attach also never worked for us.
I used the informations on this page:
https://www.ibm.com/support/knowledgecenter/SSEQ5Y_6.0.0/com.ibm.pcomm.doc/books/html/host_access08.htm
To create codestage functions in the HOST business object like:
Read from HOST
Dim autECLPSObj As Object
autECLPSObj = CreateObject ("PCOMM.autECLPS")
autECLPSObj.SetConnectionByName("A")
DIM autECLOIA as Object
autECLOIA = CreateObject("PCOMM.autECLOIA")
autECLOIA.SetConnectionByName("A")
if (autECLOIA.WaitForInputReady()) then
	outputstring = autECLPSObj.GetTextRect(y,x,y,(x+zeichen-1))
end if
Write to HOST
	autECLPSObj.SetCursorPos(y,x)
	autECLPSObj.SendKeys (Inputstring)
end if
Set Cursor
end if
Send Key to HOST
	autECLPSObj.SendKeys (translated_Inputkey)
end if
Marco Matuttis
Robot Process Automation Developer
INTER Krankenversicherung AG
Mannheim
Suresh_BabuYada
Hi Tanya,
I am facing the same issue now.
you got any solution to this ?
it would be great if you can tell us the solution
Suresh.
Suresh Babu Yadagiri
Solution Architect
Aviva Singapore
Singapore
Hi Suresh,
BluePrism does not support IBM iAccess Client Solutions setup. Thus, we receive this error. We developed using a workaround, to first launch the application using a command and then, attach it and automate using surface automation.
If possible, please check with your client if they can use other IBM PCOMM or any other emulator supported by BP.
Please let me know in case you have any other questions.
Tanya Sachdev
Tanya Sachdev
Software Engineer
Please below link it will resolve your all issue.
https://portal.blueprism.com/system/files/documents/IBM%20iAccess%20Client%20Solutions%20Implementation%20Steps%20for%20Blue%20Prism%20Guide.pdf
If issue is resolve,please mark best answer
Nilesh
Nilesh Jadhav
Senior RPA Specialist
ADP
India
Nilesh Jadhav.
Consultant
ADP,India
Hi Nilesh,
Thanks for the reply,
I already have that Guide with me and followed it.
But No Luck and i wrote to BP support for help.
Suresh.
Solution Architect
Aviva Singapore
Singapore
Thanks Tanya.
If we have to go by surface automation then the effort will be huge i guess.
Waiting for the BP support response for now.
Suresh.
Solution Architect
Aviva Singapore
Singapore
Hi Suresh,
Thanks for reply...BP team will help you soon,
Nilesh
Nilesh Jadhav
ADP
India
Nilesh Jadhav.
Consultant
ADP,India
