Microsoft Edge based Web Application
26-06-20 12:23 PM
Hello all,
I am trying to automate our web based internal application (which runs under edge) and I have some problems.
1. I can launch ms edge as an application with "C:\Windows\explorer.exe shell:Appsfolder\Microsoft.MicrosoftEdge_8wekyb3d8bbwe!MicrosoftEdge"
2. I can attach "microsoftedgecp" with specified name of tab
3. I cannot navigate
4. I cannot use Browser mode or HTML mode
Can anyone help?
Artem
Can anyone help?
Artem
[FirstName]
6 REPLIES 6
26-06-20 02:13 PM
Hi Artem,
What version of Blue Prism are you using?
Please see this knowledge base article on spying in Microsoft Edge.
Patrick Aucoin
Senior Product Consultant
Patrick Aucoin
26-06-20 02:20 PM
Hi Patrick,
BP Version 6.7.1
okaay, so BP does not support now edge.. I can switch to chrome, but there are no interaction between chrome and BP.. I will check it one more time and create a new topic.
Artem
BP Version 6.7.1
Artem
[FirstName]
26-06-20 07:05 PM
Have you installed the Blue Prism browser extension for Chrome? You can install it from the Chrome web store here:
https://chrome.google.com/webstore/detail/blue-prism-browser-extens/nadpbbdaaifbaebnniobcfpiifbfokij
With the browser extension, Blue Prism 6.7.1 is compatible with Chrome version 80.0.3987.106.
Patrick Aucoin
Patrick Aucoin
02-07-20 12:46 PM
Actually yes.
BP Version 6.7.1.21315
MS .Net 4.7
Chrome Version 83.0.4103.116 (Official Build) (64-bit)
Chrome Extension 2.1.0
And I cannot change chrome version due to company policies
Artem
MS .Net 4.7
Artem
[FirstName]
02-07-20 02:33 PM
HI Arten,
It will work irrespective of any chrome version. I am using 6.4.1 with latest chrome version. Try to restart your server and then start using it. Because may be someone might run any process from the control room. Then it will not work.
Amlan Sahoo
RPA Consultant
Equinix
Amlan Sahoo
RPA Consultant
Equinix
Amlan Sahoo
Amlan Sahoo
02-07-20 02:38 PM
Hello Amlan,
I have installation only on my laptop anf arter restart I have same issues.
I cannot access document, I cannot navigate to any url..
I tried web based app and win app mode.. with --forcerenderer-accessibility and without..
Artem
Artem
[FirstName]
